Question about Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television
Hi. When I conect my compuer to a Toshiba lcd moniter . I got a message unsuport video signal.Could some one tell me whyand how to fix that .Thanks
    Problem Solver:
  • 11 Answers
This is probably because of the refresh rate difference from what the computer is set to in order to suit the monitor, and is either too low/or too high for the TV to handle. Try lowering the refresh rate to see if it's able to handle the signal.
Posted on Oct 05, 2010
Connect wii to vga moniter Hp s2031
Hi Dear Friend,
You have a monitor with in-built VGA Port and you have laptop in-built VGA Port then why you are not using simple VGA cable to both port, Please don't use any other type to Adapter.
Thanks to Visit on Fixya
Sep 13, 2012 | HP S2031 20-inch Diagonal Lcd Monitor -...
Monitert and tower not talking
So, the monitor works on the laptop but not on the tower. That tells me that the Video Card in the tower is bad. You need to replace it. If you're getting the message on the display that says "No Input Signal", then your video card has gone bad.
Apr 18, 2012 | Computers & Internet
Does my comp Video Card supports digital signal output through VGA function? If not, what kind of cable i have to use to connect it to TV Toshiba(flat ckreen, digital)? I'v tried many cables... just...
no vga is just analoge use a svideo cable and set it up as pal if your tv is a pal or ntsc if ur tv is ntsc the tv format is not right ntsc is us pal is japan it can be found the ati cfg utility
Jan 18, 2011 | Gateway MT6840 Notebook
How do I connect my Toshiba LCD television to my computer using hdmi
HDMI carries both "audio" and "video" signals, while DVI carries only "video" signals.
Does your computer have a HDMI-output port, or separate DVI-video and stereo-audio ports?
If the former, then one HMDI-to-HDMI cable will make all the necessary conections.
If the latter, you'll need a cable to connect "line-out" from your computer's sound-card to the left/right RCA-jacks stereo-inputs, and you'll need a DVI-to-DVI cable to transmit the "video" signals.
Oct 22, 2010 | Toshiba Computers & Internet
The moniter went all black and the power button on the moniter is flashing on and off
Please disconnect the monitor from the PC and if still the monitor is blank then monitor is defective because when you disconnect the monitor from the pc you should see a message on the screen about signal like no signal etc..
Jan 29, 2010 | Dell Computers & Internet
No signal on computer moniter
1. Check your cable
2. check your cable pins make sure there not bent.
3. Check your video card make sure its putting out the correct resolution for the monitor.
No signal is just what it is. You may have a bad cable,bent pin or video card is not operational.
Things you can try.
Hook it up to a diffrent computer
Check the pins on the cable.
Worse case would be the little board inside where the connector is could be bad.
Thanks I hope this helps
Dec 07, 2009 | Acer AL1715 17" LCD Monitor
All my connections are connected properly but I
try video reset
when ps3 is in standby mode(red light)
press and hold the power button till you hear a second beep.
standby mode press hold power........"beep"......"beep"..release power button
Oct 25, 2009 | Sony Playstation 3 (PS3) Console
My background as to much green
u must change ur lcd signal connector. mor signal cable of moniter.enjoy good luck plz vote on my comments
Sep 03, 2009 | Toshiba 50H82 50" Rear Projection...
Conecting thr camera to my computer
To view the pictures on the computer, remove the card from the battery compartment and put it in a card reader connected to your computer.
Mar 02, 2007 | Canon PowerShot A540 Digital Camera
Toshiba REGZA 42WLG66 42 in. HD-Ready LCD Television Logo
104 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
