Question about Cyberhome CH-DVD 300 DVD Player
No picture i put in a burned dvd and a screen that had file folders on it that said root.. now on the dvd player remote i pushed setup and went to the video and changed something and now i get no pic with sound... please HELP!!
    Problem Solver:
  • 13 Answers
You might want to reset to factory defaults, but there is an error in the manual. In order to reset to factory defaults, turn on (with no disc inside), DO NOT OPEN THE DISC TRAY, just press the stop button on the player for 5 seconds (some solutions say 20 seconds).
Posted on Oct 27, 2008
  • 426 Answers
You have prbly changed the output of your device change the ports in the back(you might need to use a diff type of cable), or on the remote press the display button
Posted on May 28, 2008
  • Lee N.
    Lee N. May 28, 2008
    or turn off progressive scan you may need to unplug the dvd player for a few hours and make sure to hold down the power button for 10 seconds to discharge any residual power... also look for a reser sequence
"Bad Disc" message when reading a disc with JPEG files
Hi
Similar Issue happen to one of my client what we have done is putting the JPEG files into folders (Not Subfolder). It worked well however some JPEG images being skipped if the size is unusual. JPEG images will appear as tracks. Hope this will be helpful. If issue persist please post once more. Also let me know if WMA files are being played.
Good Luck
Jan 24, 2008 | Onkyo DV-CP704 DVD Player
I need a Philips DVP3100/79 region unlock code
-Open disc tray
-Press "Setup" (on the remote)
-Highlight "Preferences" (bottom of setup screen)
-Enter "138931" on the remote
-The current region code will now be shown
- Use up arrow button on remote to select 0 to make it multi-region
-Press "OK" on remote to confirm change
-Press "Setup" once more to return
Oct 21, 2010 | Philips Televison & Video
How can put background on my kvt-514
1. Plug a USB drive with the picture(s) you want on the KVT-514 into the USB input. - If there is any music or videos on the usb drive, the USB function of the player will try to take over. If this happens, change the function to something else (DVD or FM radio, etc... anything EXCEPT USB) 2. Go into Setup (is bottom button on main screen on US versions) 3. Select "User Interface" 4. on the first page, there should be some background options. The first is the current background (and a way to change to any loaded picture). The second is what you need to pay attention to. There is an "Eject" symbol Button and a "Memory" button. Select "Memory" - It may take a little while, as it will read the USB device. Be patient. 5. After it reads the USB drive, it will display the contents as a external drive (it displays files, folders, etc.). Folders with files that the radio recognizes (pictures, music, videos, etc) will be highlighted in a bright white text while folders not containing them will be grey. Select the folder that the file is in and then the file. Alternately, if the file is in the root (not in a folder), just select the file. The transfer may take a while, be patient.
Hope this helps you.
Mar 30, 2010 | Kenwood KVT-514 Car DVD Player
I Wanted To Make a BOOT CD For Windows XP But The Problem is That I Have Windows Vista and i Dont Know What To Do So What Can i Do
How to make a bootable Windows Vista ISO DVD media
  1. Put all 3 downloaded files (namely install.wim, boot.wim and an executable X13-49120.exe) in the same folder (for this tutorial, let’s assume the files are put on C:\ else you need to modify the path accordingly).
  2. Run the X13-49120.exe executable. Windows Vista Setup Preparation will create a new folder “Vista” inside the folder and will populate the folder with all necessary Vista setup files which takes up about 2.52 GB disk space.
  3. Exit from the Install Windows screen.
  4. Download CDimage 2.52.
  5. Extract CDimage from CDimage.zip to the C:\ root directory.
  6. Open a command prompt shell, and run the following command: cdimage.exe -lVISTA_EN_DVD -m -u2 -bC:\Vista\boot\etfsboot.com C:\Vista\ C:\Vistax86.iso
    Bootable Windows Vista x86 DVD ISO image in UDF format will be created as vistax86.iso in C:\ or any folder you specified above.
  7. Burn the newly create ISO with a CD/DVD burning software such as Nero or Alcohol 120%. Try to burn at low speed (i.e. 4X) and turn on verification to ensure that the DVD creation is fine.
Visit here for illustrative guide on using CDImage GUI version to make the bootable DVD ISO.
Create a Windows Vista ISO image and DVD with Oscdimg
Another possible way to create a bootable Vista ISO and DVD is by using Oscdimg CD-ROM and DVD-ROM Premastering Utility, available via WinPE (Windows Preinstallation Environment) via Business Desktop Deployment 2007 or Windows Automated Installation Kit (AIK).
  1. Complete step 1 – 3 as above.
  2. In the command prompt window, run the following command: oscdimg -bC:\Vista\boot\etfsboot.com -h -u2 -m -lVISTA_EN_DVD C:\Vista\ C:\VistaDVD.iso
    A VistaDVD.iso UDF DVD image will be created and can be used to boot the computer from DVD to install Vista.
  3. Burn the ISO image file by using last step above.
Visit the guide to create Vista bootable DVD using vLite.
Note: For 64-bit Windows Vista, download etfsboot.com and put it into “\Vista\boot” folder. Or users using WAIK (WinPE), the etfsboot.com can be found at %Programfiles%\Windows AIK\Tools\PETools\amd64\boot\ folder. So simply replace -bC:\Vista\boot\etfsboot.com with -bC:\Program Files\Windows AIK\Tools\PETools\amd64\boot\etfsboot.com when making 64-bit Vista DVD image.
Aug 02, 2009 | Computers & Internet
I lost everything in my root directory!
The upgrade should have put any pretinent files on the device that were needed. The easyRip application will write the necessary files when the transfer of media is done.
In answer to your question specifically...No, the player is not having issues because you don't have the root directory files. I would try re-installing the firmware again.
Jul 31, 2009 | RCA TH1611 MP3 Player
I cant figure out how to burn dvd after recording it?
put recorded disc in tray and let load
press setup on remote
use the arrow keys to the right of the setup button
press right arrow to highlight disc setup (on screen display)
press enter
use up down keys to scroll down to finalize disc
push enter
right left arrows for yes no
highlite yes then enter
disc will burn
Jan 11, 2009 | Sylvania DVR90VE DVD Recorder/VCR
I want to covert my toshibe sd 120e dvd player into a multiregional dvd player and play usadvds
The hack for the SD 220 works on the SD120e aswell. Itook the following off a website that tells you how to do it.
u need to dload the rar file at http://sd220e.chez.tiscali.fr/ to get your region 2 Toshiba sd220e region free. It works great. This is what you need to do
- Download the rar file at the link provided by Labman
- Unpack it using WinRAR
- Start Nero Burning ROM, click File, click Burn Image..., select the .cue file, click open, disable 'Determine maximum speed' and 'Simulation', at write method select Disc-at-once (this is very important), click write.
- Push setup on the SD220e remote control, select under picture:
PAL/Auto: Auto. Push setup again.
- Open your SD220e disc tray and insert the CD.
- Close the disc tray.
- The disc will be read and recognised as a VCD, you'll see the image on
your television flash and after a short while you will not see any image
at all. Wait about 10 seconds and take out the CD.
- Your player is now region free. Tested it with a region 1 DVD and it
worked great.
Jul 08, 2008 | Toshiba Televison & Video
ROOT
Root Folder/ Directory refers to the main Folder which contains all the important informations and commands your player has. It is similar to your Root Directory in your PC -- Drive C:/ where all the system files are located.
Root Directory includes sub folders such as your player's Master Boot Record (MBR - very crucial, this is the boot operating system), music file directory, audio record directory, data files directory such as organizer and phone directory (if your player has one).
Root Directory is very important for your player's performance as it contains all the valuable informations and commands so your player would run under normal condition. Once everything was erased in that root folder, you'll render your player useless. So be extra careful when you upgrade your player's firmware as this erases all files including those the OPERATING SYSTEM in the root folder.
It is safe however to format within your player as this erases only your data files and music. Just to be sure, avoid formating your player in your PC's MY COMPUTER/ WINDOWS EXPLORER unless it is specified in the users manual.
Luckily, MBR are usually erased when you entered your player's SERVICE MODE and you choose to erase the Firmware using some special keys. So, as long as you're using your player as mentioned in your users manual, you're okay with it. If you doesn't know all about mp3 player repairs or upgrades, leave the SERVICE MODE or PLAYER RECOVERY to the technicians.
MANNY DE GUZMAN, JR.
aka "TECH DATA"
SoundMagik Home Studio
Manila, Philippines
Visit my website: http://mannydeguzmanartist.wetpaint.com
My talents/ modeling site: http//teenmodels2007.wetpaint.com/
My YouTube Channel "mannydeguzmanjartist":
http://www.youtube.com/user/mannydeguzmanjartist
My imeem.com social media channel "mannydeguzmanartist", where all my music editing, remixes, creations, and voice demos can be found: http://mannydeguzmanartist.imeem.com/
Mar 31, 2008 | Alba DVD55 DVD Player
Windows vista
How To Make Vista Bootable DVD with WIM Downloaded Files If you have purchased Windows Vista online and taken the delivery of the latest operating system via web download from Windows Marketplace, you would ends up with a few downloads with .wim and .exe file extensions. Rather than paying additional shipping and handling charges, you can burn or create a bootable ISO DVD image from downloaded Vista files with the following trick, where the .iso image can subsequently write to a DVD. The DVD created will be the typical 32-bit Windows Vista DVD that available in retail channel, and can be used to clean install.
1. Complete step 1 - 3 as above.
Mar 24, 2008 | Computers & Internet
Cyberhome CH-DVD 300 DVD Player Logo
179 people viewed this question
Top Cyberhome Televison & Video Experts
zappal
Demonic-2011
Demonic-2011
Are you a Cyberhome Televison and Video Expert? Answer questions, earn points and help others
