Question about LG Studioworks 700S 17" CRT Monitor
Studiowork 700S wont turn on!
My Studiowork 700S will not turn on the litle light wont turn the 2 pugs r in
1 in the pc & 2nd in the powerpoint
i try 2 trun it on when the pc s off doesn't work
i try the pc is on nope wont work
  • 426 Answers
Have you tried using another screen? cable could be bad or a controller board has gone out time to either upgrade to a lcd or get a new crt they are nearly a dime a dozen now
Posted on May 28, 2008
I have a 84 Honda NightHawk 700s and I turn on my bike and the headlight does not turn on unless I hit the hi beam switch, what could be wrong in the wiring?
Hi, Anonymous if your headlight is not working the first thing to check is the headlight bulb for damaged filaments then check your light circuit fuse, that being said the usual suspects are:
1. Faulty ground or power supply to headlight bulb socket.
2. Faulty hi/lo beam switch.
3. Faulty ignition switch.
4. Fuse is good but no continuity on both sides.
5. Faulty wiring between battery positive and headlight bulb socket.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
Motorcycle Headlight Help
Headlight wiring Testing Pt 1
Honda Motorcycle Manuals 1980 to Now
https://www.tradebit.com/filesharing.php/search/0/1984+honda+nighthawk+700s
Dec 07, 2015 | Honda Motorcycles
I was trying to open my powerpoint from my HDD
If the file is not open, I want to make sure of some properties.
General, visit discussion below to know how it is easy to solve your issue:
http://www.filerepairforum.com/forum/microsoft/microsoft-aa/powerpoint/303-my-powerpoint-presentation-didnt-save
OR
1. Go to the directory where the file is located.
2. Right click on the file
3. Select properties
4. The Type of File, should be PowerPoint Presentation
5. Opens File field should be PowerPoint.
If it doesnt have this, then select the change button & select PowerPoint from the list of applications.
6. Select Ok & then Apply and OK again
Also you may try PowerPoint Repair Toolbox
It provide you free test service to know how great software is: http://www.pptrepairtoolbox.com/
Oct 12, 2014 | Microsoft PowerPoint 2003 for PC
My lg studiowork 700s has stopped working
look listen and dance not matter how you performance keep it calp and trust it
Feb 20, 2014 | LG Studioworks 700S 17" CRT Monitor
NO SIGNAL
1)PRESS NUM LOCK KEY IN YOUR KEYBOARD
2)IF A GREEN LIGHT IN KEYBOARD A GREEN LIGHT APPEARE IF CPU HAVE NO PROBLEM
2)REMOVE YOUR POWER CORD AND HOLD THE ON BUTTON FOR LIKE 30second TO A MINUTE AND THEN CONNECT IT BACK AND TURN IT ON
Nov 21, 2010 | LG Studioworks 700S 17" CRT Monitor
My LG Studiowork 17" monitor screen turns yellow. What is the solution for that?
1. Just move a little or bend the cable at the connector ends and see whether the color changes to normal. If it happens then get the cable replaced.
2. Try to restore to factory defaults using the buttons on the monitor.
Sep 11, 2010 | Computers & Internet
Can't see the dvd sometimes in the device manager or use it
drlane
Can you say what is your Notebook model?
For all model notebooks. Reverse notebook upside down and search for litle optical drive icon. Around it you will see litle hole with a screw (1) on it. Remove the screw (1) and pull out optical drive (2), then insert it again back. This will autoclean contact pin on your optical drive.
If this not solve your solution try to clean pins with dry contact cleaning spray. Be aware with electronical parts.
Oct 13, 2009 | Acer Aspire 5100-3357 Notebook
Hyperlinks in PowerPoint
it is because the compatible MS Office for windows vista is MS Office 2007. if you got a lower version, it is doesn't really work. try to get the latest version of MS Office.
Feb 26, 2008 | Microsoft Windows Vista Ultimate Edition
LG Studioworks 700S 17" CRT Monitor Logo
80 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
