Question about Mad Catz PS3 Bluetooth® Headset Wireless Headset
How do i sync my mad catz blue tooth headset to my ps3?
    Scholar:
  • 81 Answers
You'll need your controller, console, and headset to do this. Make sure your headset is off before you start, then follow these simple steps.
  1. Power on the PS3 console
  2. Within the "settings" menu, press X on "Accessory Settings"
  3. Press X on the icon labeled: "Register Bluetooth Device"
  4. Scroll down and press X on the icon labeled: "Register Headset/Microphone/Headphones"
  5. Prepare the headset to be paried by holding down the main buttong for 8 seconds.
  6. Once the LED flashes blue and red (indicatin the headset is ready to be paried), press X on "Start Scanning"
  7. Once Scan is complete, the PS3 will list all Bluetooth device visisble and within range.
  8. Locate your headset ID, most likely "8860" or something similar, and press X on it's icon.
  9. Enter 0000 (four zeros) as the Pass key and hit OK.
  10. Now enjoy your synced headset!
If any part of this confuses you, you can find the manual for your headset online here. You'll need a PDF reader to view the file. There are plenty of free ones on the web, but if you don't already have one, I'd recommend this one. It's free and simple.
Posted on Oct 05, 2010
2 Suggested Answers
  • 50 Answers
SOURCE: I cant find instructions to sync my Mad Catz PS3
Hope it helps:
Pairing is a process of associating Bluetooth devices with each other. It will establish a permanent security link between the devices and enable quick access to the services provided without the need to re-enter Pass Keys. You will only need to pair your PS3 and the Headset once.
Paired devices remain paired even when:
-One of the devices is powered off.
-A service connection is interrupted or stopped.
-One or both devices are restarted.
Pairing the Headset with the PS3
Before the Headset can be used with the PS3, the two devices must be 'paired' so they can communicate with each other. Use a gaming controller for this procedure and ensure that the Headset is powered on (flashing blue LED light) and that it is not being charged via USB cable.
1. Power on your PS3 console.
2. Within the "Settings" menu, press X on "Accessory Settings."
3. Press X on the icon labeled: "Manage Bluetooth® Devices."
4. Scroll down and press X on the icon labeled: "Register New Device."
IMPORTANT: Depending on your model of the 8860 Bluetooth® Headset, your power button is either an oval shape with an icon of a circle with a line going through it (5a) or it is a button with a phone icon (5b). Please follow the appropriate next step depending on your model of the 8860.
5a. Once at the next screen, prepare the Headset to be paired with the PS3 by holding down the K1 button until the LED flashes Blue and Red (hold K1 approx 12 seconds).
5b. Once at the next screen, prepare the Headset to be paired with the PS3 by tapping the pairing button located next to the volume controls on the side until the LED flashes BOTH Blue and Red.
6. Once the Headset's LED indicator is alternately flashing Blue and Red (indicating the Headset is ready to be paired), press X on "Start Scanning."
7. Once Scan is complete, the PS3 will recognize all Bluetooth devices within range.
8. Locate "8860" from the list of available devices and press X on its icon to be prompted for a Pass Key
9. Enter 0000 (four zeros) as the Pass Key and press X on OK
10. You should then be taken to a new screen stating: "Register completed"
Trouble Shooting
Q. The PS3 is unable find the Headset.
A. If the Headset has been paired with another Bluetooth device, the PS3 will have trouble finding the Headset. Either remove the Headset from the paired device or turn off the Bluetooth power on the paired device.
Q. The Headset cannot be activated after being charged for 20 minutes.
A. To activate the Headset, the battery needs to charge for at least 40 minutes. It is highly recommended to fully charge the battery before use.
Q. No indication of charging is shown.
A. If the Headset battery is empty or has not been used for a long time, it may take some time for the Headset LED indicator to show charging status with a steady Red light. Make sure the PLAYSTATION 3 is turned on. The 8860 cannot charge without the console being turned on.
Q. No sound can be heard from the Headset.
A. Please make sure of the following:
-Make sure that the two devices have been paired.
-Make sure that the Headset is turned on.
-Make sure that the two paired devices are within 30 Ft. (9.15 meters) of each other.
*** Do not try to pair the headset to the PLAYSTATION 3 when the headset is attached to the USB cable. If it is attached to the USB cable when trying to pair up, it won't pair with the PLAYSTATION 3. ***
Posted on Apr 29, 2011
Register my ear piece to a new ps3
go to accesory settings and go to manage your blue tooth then put in your pass key
Feb 27, 2013 | Mad Catz PS3 Bluetooth® Headset Wireless...
The mad catz blue tooth mic #8860 wont charge how can i fix it?
Try to charge it on a USB on the PC, If the red light doesn't stay on, meaning it's charging, then you have a faulty headset and you'll have to contact your retailer to ask for a replacement.
Unfortunately this is a know issue with this headsets...
Hope it helps
Mar 02, 2011 | Mad Catz PS3 Bluetooth® Headset Wireless...
I dont know the pass word for my blue tooth
If you did not yet set up a personal passcode for the blue tooth it should be 0000 or however zeros it may be. Im not exactly sure.
Apr 05, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
I have a mad catz head set for my ps3 and it's showing up on the ps3 but i cant talk to anyone.whats wrong?
The headset wouldn't connect so we deleted it. Then went back and tried to pair it again. And it wont flash blue and red, just blue.
Feb 01, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
How do I register my blue tooth headset to my ps3
The pairing code is 0000 (four zeros).
Also, you may want to review this guide for connecting a bluetooth headset to a PS3:
(Click here)
http://boardsus.playstation.com/playstation/board/message?message.uid=26900460
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thanks!!
Dec 14, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
How do i set up my Mad Catz bluetootth headset to my sony playstation 3?
go to were it says blue tooth on ur ps3 and pres search and on ur mad cats hold down the power button for 10sec.
Sep 24, 2009 | Mad Catz Bluetooth Headset for PS3
Blue tooth is not installing for the ps3
Registering
1) Go to accessory settings
2) Click on Register blue-tooth device
3) Click on Headset
4) Scan, while holding down the main power button on the headset
5) Enter your 4-digit password. The default is normally 0000
6) Done
Using
1) Go to Audio Options (under accessories)
2) Click "Connect Blue-Tooth device"
3) Change everything from "Do Not Use" to your headset name
4) Done..
Mar 31, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
For got pass key for my blue tooth trying to regster to new ps3
pass keys 4 headsets are normally 0000 or 1234 unless you've manually changed it. If so then you will have to go thru each number cycle from 0000, 0001, 0002, up to 9999. (",)
Jan 25, 2009 | Mad Catz PS3 Bluetooth® Headset Wireless...
Mad Catz PS3 Bluetooth® Headset Wireless Headset Logo
592 people viewed this question
Top Mad Catz Radio Communications Experts
Gene
Tom Chichester
Bill Boyd
Are you a Mad Catz Radio Communication Expert? Answer questions, earn points and help others
