Question about Vision Panini My X 60 Check Scanner
The driver was not installed. You did not accept the certificate required during installation. (DTD8008)
We have got the same issue too when using the desktop deposit function.
The tech support basically did 2 things to resolve the issue:
  • In Internet Explorer
Posted on Oct 08, 2010
  • kzhu Oct 08, 2010
    Please delete this solution. I'ii re-submit.
  • kzhu Oct 08, 2010
    a. In IE > Internet Options > Security > Trusted sites, add *.YourBank.com as the trusted website.
    b. In Control Panel, uninstall the Panini Scanner Driver and VisionX driver. Reinstall Panini VisionX driver. Restart the computer.
It can not install drivers of audio automatically
On windows 7 and up, you can't install your own drivers. You need drivers with a Microsoft certificate and you also can download them form Microsoft. Windows 7 or up, won't accept other drivers.
Mar 11, 2015 | Computers & Internet
My nokia N8-00 cannot download software ( mini opera ) lcd will display ' internal error : Jsr pugin com.nokia.mj.impl.chapi.core.utils.ServiceProviderInstaller ca ncelled installation...please h
Hello Restore your phone by typing *#7370# when the phone is in normal mode.Some of the Internet configuration setting/certificate may lost or failed to install in your phone.Before install any software, every phone should prompt coz the phone is having all the required certificate.Therefore,still After resetting the problem still persist you need to flash / update the phone to recover the missing certificate.During this time you need to visit mobile repairing shop.Good luck
Feb 10, 2012 | Nokia N Cell Phones
Am facing the prob during the installation of applicatn in my samsung chat3222 bt brwser net wrking properly.
OS's like symbian, java, etc.. basically come with application installation restrictions in-order to secure the software components of the mobile. The applications come with a digital certificate in-order to confirm that it's legal. Its recommended to use minimal third-party softwares. If there's a problem during the installation then the certificate signature needs to be checked!
May 26, 2011 | Computers & Internet
When i install smart movie v4.5 it's showing certificate expired what is the solution
Hello, go to menu locate installer, in the installer press option botton then select accepte all. Then try installing or loading again. But make sure the certificate is in date not out of date.
Mar 25, 2011 | Nokia e65 Cellular Phone
I cant download themes on my tel it tells my something about the certificato scaduto
hi, the reason why you can not download those themes is because your phone does not accept applications that the CERTIFICATE is not SECURED. i.e it does not accept scrap applications but i tell you, if you try to install themes from a web site where the certificate is secured, your phone will accept it.
cheers
Mar 10, 2011 | Nokia E71 Smartphone
I am having problems connecting VPN Connection on my Windows 7, it says there need to be a machine certificate installed before i can connect using L2TP/IPsec. error code :766
"Error 766: A certificate could not be found. Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate."
"Error 766: The L2TP connection attempt failed because the security layer could not authenticate the remote computer."
Cause: Connections that use the L2TP protocol over IPSec require the installation of a machine certificate, also known as a computer certificate. You will see this error message when such a certificate is not available.
Typically, this error is generated on a remote access server that has active L2TP ports configured, the remote access service started but there is no certificate in the computer certificate store. This generates an event log message that tells the administrator that L2TP ports will not be able to accept calls until a certificate is acquired and RRAS is restarted.
Resolutions: 1. If you use PPTP VPN, select Automatic in Type of VPN.
2. If you use L2TP, check the remote access server and make sure there is certificate in the computer certificate store.
Sep 18, 2010 | Computers & Internet
How to correct the certificate expired problem for n95 in downloading themes
You can download thesmes from http://gallery.mobile9.com/ and install it in your phone. Just accept it when installing it and it will work correctly. For the expired certificate you can restore the factory settings. Thanks
May 21, 2010 | Lands Phones
Cannot comunicate print with my printer
Go to your web browser's preferences (I'm using Firefox in this case), Go under Advanced tab, and click ask me every time. When the browser pops up with the message, click on override or whatever it gives you as an option so you can accept the certificate.
Nov 20, 2008 | Lexmark X1270 All-In-One InkJet Printer
I Have a Hp Deskjet F380 ALL-In-ONE Printer-Scanner-Copier,I Need Know How to install a print driver for my Hp Deskjet F380 Printer.Thank You, I Need Help????
How do I download and install the software? To download the software, do the following:
  1. Click here to go to the Software and Drivers page for your product.
  2. Click your operating system.
  3. In the Driver section, click the appropriate software driver.
  4. Follow the instructions on the page that appears to download and install the software.
How do I install from the CD? Two installation options are available when installing the software and drivers from the product CD. The recommended install installs everything your device requires to work, including a suite of software recommended for your installation. The custom install allows you to choose what software to install. The recommended install is designed to work for most users. Use the custom install only if you have one of the following reasons:
  • Low hard disk space on the computer.
  • You do not want the additional software.
  • Errors occur during the recommended installation. NOTE: If errors occur during the recommended install, fix them before doing a custom install.
Recommended install Complete the following instructions to install the software: CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Choose unblock or accept on all firewall messages or the install will fail.
  1. Insert the software CD into the CD-ROM drive of the computer. The software installer starts automatically. NOTE: The User Account Control screen might display. Click Continue .
  2. Click Install on the Thank you for purchasing from HP! screen.
  3. Click Next on the Welcome to the Install Wizard... screen.
  4. Click Next on the Do Not Block HP Install Wizard Processes screen.
  5. Select Yes or No on the Automatically Check For Updates screen and then click Next .
    • Choose the Yes (recommended) option to check for updates through an Internet connection.
    • Choose the No option if you do not want to check for updates.
  6. Select Recommended on the Installation Options screen, and then click Next .
  7. Follow the instructions on the screen that displays to finish installing the software.
Custom install CAUTION: Do not connect the USB cable until prompted to do so during software installation. HP recommends using a USB cable that is less than 10 feet (3 meters) long. NOTE: Select unblock or accept on all firewall messages or the install will fail.
  6. Select Custom on the Installation Options screen, and then click Next .
  7. Select which software to install by selecting or clicking to clear the check box next to each item on the Custom Installation screen. Click an item to see its description and the required disk space. NOTE: You must install the drivers and the HP Imaging Device Functions for the buttons on the front panel to be functional.
  8. Follow the instructions on the screen that displays to finish installing the software.
Aug 19, 2008 | HP Office Equipment & Supplies
2,472 people viewed this question
Top Vision Office Equipment & Supplies Experts
k24674
Are you a Vision Office Equipment and Supply Expert? Answer questions, earn points and help others
