Question about Woods INDUSTRIES 59112 INDOOR DIGITAL TIMER 24-HOUR
I'm having trouble setting this item. I can get it to come on, but it won't turn off at the set time. What am I doing wrong? Thanks, Janene
I don't have a Woods 59112 Manual
Here's link to Woods 49063 manual aka Woods TD1000 aka Noma TD1000
If manual is same/similar as your manual, then read solution given below
If solution below is incorrect, the write out your instructions ... I found that writing out instructions makes things clear.
Solution:
I think you have set ON time but did not set corresponding OFF time
Below is whole programming layout for you to read through
The important thing is to look at the display while programming
For example, lets say you are setting ON time for PROG1
For ON time, the display shows 3 things:
-display shows PROG in upper left corner
-display shows the number 1 to right of time
-display shows the word ON to the right of the number 1
Now you want to set OFF time for PROG1
For OFF, the display shows 3 things:
-display shows PROG as before
-display shows 1 as before
-display has changed and shows the word OFF to right of number 1
Here's how to set Woods TD1000 timer
Plug in timer to see if battery will recharge. Display shows when battery is charged. No display, then timer is no good.
TD-1000 timer has 8 on-off functions per 24-hour day
Timer has 5 buttons + reset:
TIME MODE PROG HOUR MIN
Set current time
Press and hold TIME > use Hour to set hour, Min to set minute
Release Time button ... correct time should show
Program: Capacity for 8 on-off times per day
Press PROG to set first ON time
ON and number 1 are displayed on left
Use hour and minute button to set ON time
Press PROG to confirm
Now, OFF and number 1 are displayed
Use hour and min key to set OFF time
When 8 programs are set, Press MODE key.
Choose Manual OFF. Manual ON, Auto ON, Auto Off
To use programs, select Auto ON
DST daylight savings time has to be done manually.
Press HOUR MIN button simultaneously > timer set up one hour
Repeat again and timer goes back one hour
Do not plug timer into extension cord > must be plugged into wall
Posted on Oct 06, 2010
I have a sharp aquos tv, model LC-42D62U, and had a sound bar attached that worked great. When I remove the soundbar I can’t get the TV sound to turn on. I have trouble shot a lot of things. The problem...
I do not have sharp manuals to reference - in general the TV sound - Variable vs Fixed just allows the set to control the volume output (variable) or Fixed will produce one level of output and your device (soundbar) volume control would adjust up or down from there. There is usually another location in the menu that allows you to turn off the TV speakers so they do not operate at the same time as your soundbar or other device. It should be simply Speaker ON / OFF. If you can locate this - you should be able to select it. If it is all greyed out - that means the TV believes based on the connections / setting / input selection - those cannot be changed. (you may try connecting the device and see if the greyed out menu items turn back white or are selectable. Sorry I don't have a specific answer - hope this helps
Dec 21, 2017 | Sharp Televison & Video
I have a 1999 Chevrolet Tahoe I just changed all the plugs the wires ignition rotor button distributor cap now When I crank it it runs fine until you mash the gas in it starts raining bad I tried turning...
Did you connect the vacuum hose to the timing advance diaphragm under the distributor? The other major item is the timing belt-even if it says you're perfect, the cams might be all out of whack. There's nothing wrong with 5 degrees BTDC if you have a lead foot.
Jul 31, 2013 | Cars & Trucks
How do i get back my video settings? put in wrong ones now won't work
turn the ps3 off....hold down the power button for 5 to 6 seconds til u hear a couple of beeps then turn it on....will reset your video settings to your avi cables.
Sep 11, 2012 | Sony Playstation 3 (PS3) Console
My right mirror won,t keep memory whenever i set it same with my seat position
Position items,press set ,then #1 or #2
No owners manual ?
Helm.com --- to buy one
For mirrors you need to move the switch to the side you want
Jul 09, 2012 | 2004 Lincoln Aviator
P4P800 - VM BIOS Version 1012 to Upgrade 1018 Now CMOS can't save Date & Time
I'm sorry to have to say this but your CMOS battery connection is bad. There is basically nothing you can do other than replace the whole motherboard if it is too much of a problem.
One of my many computers is like this as well. I'm lucky in that as long as I leave that computer plugged in (it doesn't need to be turned on just plugged in), the CMOS won't reset its self. If you aren't that lucky then I would seek out a replacement motherboard.
Jun 18, 2012 | ASUS P4P800-VM Motherboard
Dell Inspiron 530 won't start, CMOS
Sounds like the CMOS battery is dead. You will find this battery on the mother board. It is a round watch battery, pull it and take it to a store like Walmart to get a proper replacement. I bet if you check your system time, it is wrong too.
Feb 20, 2012 | Dell Inspiron 530 Desktop Computer
I changed my power supply. The fans now work but nothing else...What could be wrong?
In case the fan is ok then smps is ok the culprit is ram remove and clean instal it again and check.
Apr 26, 2011 | Computers & Internet
I have a new Sony HDMI LCD tv and a PS3 game system. I am having trouble playing Dead Rising 2 in 1080i mode. It will only play in 720 p mode, even though I changed the setting to 1080i on the...
Some hd tvs do that,,its not u,,try in ps3 settings turn only 1080i setting on,,only,,same on tv also,,if not try with evryone of them selected,,let hdmi cable do it automatic
Nov 04, 2010 | Video Game Consoles & Games
Oki 320 turbo, serial interface, how do I change
To change the settings, make sure you have a good ribbon installed.
Press the MODE button. The SEL light will go out. Menu light will come on.
Press the GROUP button until the printer prints something like:
Serial Interface Parity None
To change the Parity, press SET. A new line will print as:
Serial Interface Parity Odd
Press SET until the Item is the one you want.
Then Press the ITEM button. It will then print:
Serial Interface Serial Data 7 or 8 bits 8
Again if you want to change it, press SET. Otherwise go to the next Item.
Continue using the ITEM button to choose the item you want to review or change and the SET button to change the selection.
When you have made all the changes verify by going through all of the items with the ITEM button. When you are satisfied, Press the MODE button to save all of the changes. (The Menu light will go out.)
If you have any trouble Comment back.
Thanks for using Fixya.
Aug 11, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Woods  INDUSTRIES 59112 INDOOR DIGITAL TIMER 24-HOUR Logo
444 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
