Question about Nikon Laser 600 Rangefinder
My Nikon Laser 600 range finder stoped working. I tried a new battery but when you push the button once it comes up with a reading of 88.8 & when pushed a second time it displays just flat lines.What can be done?
SOURCE: Nikon Pro Staff 440 Range Finder
there is a silver quarter sized screw out cover on the battery compartment.  It has a slot so you can use a coin or screwdriver to remove the cover.
Posted on Oct 17, 2007
SOURCE: Nikon Laser 800 Rangefinder
For the "Guest" who needs a manual, down load one at http://www.nikonusa.com/pdf/sportoptics/rangefinders/LASER800Instructions.pdf
Posted on May 14, 2008
SOURCE: Won't range even after reset
Well after going through the reset procedure (holding both buttons down for 30 seconds) the unit didn't appear to be working. Being somewhat new to the proper use of this device it appears that it might be sensitive to low light conditions or certain objects. After playing with it more I'm now able to get it to work but there are still certain conditions where it won't give me a reading.
Posted on Feb 13, 2009
  • 75 Answers
SOURCE: I bought a used Nikon
Go to; www.nikonusa.com.
On that home page, look down the left side of the page and you will see a variety of choices to click on. You will click on 'DOWNLOAD CENTER'. Then, on this SAME page, look in the middle of the page and you will see a choice 'SPORTS OPTICS' which you will click on.
This will take you to the NIKON ANSWER page.
Scroll down the page until you find the 550, there's two(2) models of the 550 determine which is yours, then look over to the right hand side of the page and you will see the PDF/ADOBE logo which you will click on and in turn this will show you the OWNERS MANUAL which you can download and there you have it.
Good luck. :)
Posted on May 05, 2009
  • 2976 Answers
SOURCE: need the proper tool for a nikon prostaff range finder
Harbor Freight has a kit that has them in it and most industrial tool supply companies have them. It's a security screw. there are many kits availably with an assortment of bits in them. Drill Master has a 100 piece kit that's pretty cheap. Item#91310
Posted on Oct 29, 2009
Testimonial: "Perfect. Huge Help. Thanks"
Lost the battery cap for a Nikon LR550 range finder. need a replacement
I also lost the battery cap for the LR550. I signed up for an account on Nikon.com and asked how to get a replacement through the "Service and Support" section. Very delighted to report that they immediately FEDEXed a replacement part - free of charge!!!
Love my range finder, disappointed that the cap fell out but impressed with the service. Will put some tape over the battery cap from now on.
Apr 24, 2012 | Nikon Unisex LR550 Rangefinder
MY NIKON 550 RANGE FINDER WONT LOCK ON AFTER 40 YARDS IVE TRIED SEVERAL NEW BATTERYS
Same problem. Conclusion: just because it has the NIKON name does not mean it is not a piece of Chinese junk.
Oct 20, 2010 | Nikon ProStaff 550 Laser Rangefinder
Nikon laser 500G range finder I can not get reads above 30 or 50
On my laser 500 G I held both buttons down together for a short time and it began reading again. See if that works with yours.
Jul 28, 2010 | Nikon 7431 LaserCaddy Rangefinder
SB-600 Flash will not charge/everything else works.
check wire connection to capacitor measure voltage on it/
Be carefull high voltage!!!
May 12, 2009 | Nikon Speedlight SB-600 TTL Flash
Can't Find Battery.
The camera itself doesn't have a battery. If you have a light meter in the finder however, then the battery for it is in the finder itself. Press the button the back on the left side while at the same time, push the lever over on the finder. That will release the viewfinder.
Look underneath and you will see the battery cap. Unscrew that and you'll see the compartment. If it is an old FTn finder, then it will likely take the mercury batteries that are about 1.35V. They don't sell those anymore as mercury is illegal in consumer batteries, but if you do a search on eBay for 1.35V WEIN cells you should be able to track down replacement batteries.
You could put Duracell PX625 batteries in, but they ar 1.5V and thus will give inaccurate meter readings.
Dec 29, 2008 | Nikon Cameras
Battery cover for Laser 800 Rangefinder
Hi!
The model you have is the LASER 800 and it was made in 2000.
To obtain a replacement battery cover, follow this link:
http://support.nikontech.com/cgi-bin/nikonusa.cfg/php/enduser/std_adp.php?&p_faqid=238
Once the page loads, you can choose the option that you think best fits your need - either email, use the knowledge base or simply phone the listed service number to order your part.
Nov 15, 2007 | Nikon Laser 800 Rangefinder
Nikon 440 pro staff range finder wont read distance
I just got mine to work. It was doing the same thing. I guess I re-set it. I figured there had to be some way to re-set it. So I pushed the mode button and the power button simultaneously for 30 second. Then it worked! Wooptidoo :)
Nov 01, 2007 | Nikon ProStaff Laser 440 Rangefinder
Problem with SB-600!!!!
Batteries may have leaked. Open battery chamber and clean ---especially the contacts situated at the bottom -- with pencil erazor. Blow out any loose bits and with new batteries try to switch the unit on.
Sep 18, 2007 | Nikon Speedlight SB-600 TTL Flash
Nikon Laser 600 Rangefinder Logo
102 people viewed this question
Top Nikon Optics Experts
George Merkley
George Merkley
Are you a Nikon Optic Expert? Answer questions, earn points and help others
