Question about GE WSXH208A Front Load Washer
Water leaks into the washer all the time, i have hard water and i think the valve that allows water into the washer is not shuting off all the way. how do i replace it?
    Problem Solver:
  • 8 Answers
I have had the valve get stuck and not close on either cold/hot side. You will have to replace the valve. You will have to pop off the top and its fairly easy to see where the valve is because the hose connections are tied directly into it.
Posted on Oct 05, 2010
We have a hot point washer. That's washing ok spins ok some times. But once machines been turned off and I come to do another load. The machine is full of wTer why???
Maybe the cold/hot water inlet valve has a faulty seat or seal that is allowing water to leak thru to washer despite the valve being closed. Probably need to replace that valve. Look at some of these links on YouTube on repairing or diagnosing water problems:
hot point washer machine fills up with water with machine shut off YouTube
Mar 06, 2015 | Washing Machines
Fixed leaking faucet, now handles leak at the base & the water pressure is low
No, air can't get trapped in there. I don't think you did anything wrong. It sounds like the valve or internal parts are worn more than new washers take up for. Tightening down the valve just reduced travel for valve to open fully. Can't think of a fix; where's that joe da plumber?
Nov 23, 2011 | Plumbing
Water leaking at dishwasher above water line coming from under sink Problems. serial no. fu5006784
shut off valve may be leaking, valve location dishwasher supply line connect to it if washer over flows when not using the valve is not shuting of reolase valve
Oct 14, 2011 | Whirlpool GU2400XTP Built-in Dishwasher
How do I stop the water from leaking thru the water dispenser?
replace the water valve . it is not shuting of ( some do leak when older due to hard water and ect . in the valve . mm
Sep 30, 2010 | Frigidaire Refrigerators
My front loading washer always fills with water when i am not using it
It sounds like one of the automatic water fill valves in the machine is leaking water when washer is off and the valves are closed. There are two manual water supply valves at the wall behind the washer, one for hot water and one for cold. Close the manual hot water supply valve and allow the washer to sit and see if it fills with water. If it does fill, then the cold water automatic fill valve is leaking. If not, then open the hot water manual supply valve and close the cold water manual supply valve. Allow the washer to sit again and see if it fills. If it does then the hot water automatic fill valve is leaking. Replace the leaking valve in your washer. You can order the new valve online using washer brand and model number on a appliance parts web store, or maybe even find it at a local appliance parts store.
May 22, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Ice cube maker not working. I saw water frozen in the plastic shute leading to the ice trays.I used a hair dryer to melt the ice in the shute. The white gear IS turning. Still no filling of water. Door...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-fareast-font-family:"Times New Roman";} The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
Jan 02, 2010 | Whirlpool ED2FHEXN Side by Side...
Cycles take an exceedingly long time to complete
no, the problem is the the valve that stops water from draining is not working. or not shuting off all the way, water will try to fill but never does or does and leaks back out and try again. replace valve/pump, if you take it apart u will find your paperclip u left in u pocket
Sep 07, 2009 | Bosch Nexxt 100 Series WFMC1001UC Front...
Maytag washer - the water will not stop running
This is often, if not all the time, a faulty fill valve, the fill valve has mechanically stuck open and is not fully shutting off when not the washer is not in use. This normally will become worse and could flood over the top of the washer = big mess .... replace the fill valve. The fill valve is the part the hot and cold water hoses are attached to. the another possible fault can be ------------ The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Jul 13, 2009 | Maytag PAV2300 Top Load Washer
Having trouble shuting off hot water valve. sprays water when i tighten it
Ok this is a common problem when you do not use a valve for a long time the o-ring on the stem will get a impression on it making it leak when in the middle .  if you turn it on all the way it should stop leaking .  you can fix this by changing the o-ring but you need to shut off the water before that valve.  if you can shut off the water before this valve it is probably best to replace the hole valve .
Jun 24, 2009 | Plumbing
Water in tub
I don't know if the outside temperature has anything to do with your problem. I think it may just be coincidental. Water accumulating in the tub is usually caused by two things:
Leak by - which is caused by a water inlet valve malfunction. The valve has an electronically controlled diaphragm that closes to shut the water off when not in use. Over time the valve can accumulate sediment and debris causing the valve not to seat all the way. This is especially true if you live in an area that has hard water, or if you use well water. This will cause water to leak by when the valve is not in use and accumulate over time in the wash tub. You can attempt to clean the valve with distilled vinegar to remove any sediments and flush it with clean water. You will need to remove the valve in order to do this. Sometimes a good cleaning is all it takes to correct the problem. If not, I would recommend replacing it.
Siphoning - siphoning occurs when the drain line is installed incorrectly. The following link explains:
http://www.fixya.com/support/r587481-prevent_washer_siphoning
Although the problem usually describes a condition where a washer constantly fills and drains, or cannot maintain the proper water level, it can also cause back flow from the drain. Double check your drain line installation to ensure there is a proper air gap to allow for proper draining. If not, a vacuum is created and drain water can back flow into the washer.
A simple test would be to shut the water supply off when not in use. If the washer STILL accumulates water, you know you have a drain problem. If it does NOT, then you know you have an inlet valve issue.
I hope you find this information helpful. Let me know if you still require assistance.
Nov 18, 2008 | Bosch 3.81 cu ft WFMC530 1UC Nexxt 500...
GE WSXH208A Front Load Washer Logo
21 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
