Question about Canon BubbleJet i560 InkJet Printer
Canon i560 printer
Printer won't print. Green light blinks once, then turns amber & blinks 5 to 6 times, then turns green once again. I have replaced all new ink cartridges.
  • 9 more comments
  • Anonymous May 28, 2008
    same problem.. tried re installing restarting computer, changed usb port
    no help
  • JackJay Jun 09, 2008
    Same problem...just quit printing. Goes thru all the motions...page is blank.
  • Anonymous Jun 10, 2008
    blinks yellow 5 times then green. Won't print anything at all. I've removed the printer head and cleaned it, but no change.
  • Anonymous Jun 14, 2008
    light on j560 printer keeps flashing. Will not print. Could it be fried from a power failure?? Have unpluged, repluged into power. Changed ink cartridges.
    Do I need a new pinter?
  • glassmith Jun 19, 2008
    crud!, me too. 1 green, 5 amber, 1 green, 5 amber, 1 green, 5 amber......
  • scottpezza Jun 25, 2008
    I have the same problem. Orange light flashes 6 times then green once. Warning tab says "Operator error"
  • swede111 Aug 11, 2008
    canoni560 flashes 5 times??
  • Anonymous Apr 30, 2009
    For 59.99 I can spend another $50 and get a new printer.
  • ying55 May 20, 2009
  • Anonymous Mar 16, 2014
    when I got a refilled cartridge and installed it my printer will not recognize it the yellow light flashes 4 times and then the green light flashes once
  • Anonymous Mar 20, 2014
    The alarm light blinks after installing new ink
I have similar problem. I found this solution that may help you. My problem insists tho.
>>> 5 flashes indicates a faulty printhead or possibly a problem with the p/head contacts. Try removing the head which is easier if you take the cartridges out first(no tools required) and re-seat it having checked the contacts for dirt.
If that doesn't work it may be that the waste ink tank is full. Try this ...
Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000 above,
1. Turn off printer
2. Hold down Resume button and press Power button.
3. Keep holding down Power button and let Resume button go.
4. Press Resume button 2 times then let BOTH buttons go.
5. Green lights will flash and then stop blinking.
6. When green lights are solid, press the Resume button 4 times.
7. Press the Power button and the printer should turn off, if not, press the Power button once more.
8. Your printer should respond as normal.
Posted on Aug 12, 2008
  • Dan Legate Nov 21, 2011
    This worked awsome. Thanks so much you saved me about 200 dollars.
  • stiffun Jul 03, 2013
    Sorry, didn't work for me but thanks for the effort; may work for others
Orange light flashes 5 times then green flashes once then repeat Can't get printer to do anything else. Have unpluged it for ten minutes no luck Have removed print head and replaced it, no luck....
1. Turn off printer
8. Your printer should respond as normal.For printer
Mar 22, 2011 | Canon BubbleJet i560 InkJet Printer
Canon i9950, Operator error,5 amber blinks
  1. Turn off Canon i550, i560, i850, i860, i865, i9100, i9950 Printers
  8. Your Canon i550, i560, i850, i860, i865, i9100, i9950 Printers should respond as normal.
Please all I ask is call back and just gave a vote, it will gave me some satisfaction to know am helping some one, so I will keep on helping.
All The Best: Pineworks
Jan 02, 2010 | Canon i9950 InkJet Printer
5 times says the printhead is bad and needs to be replaced.The part number is stamped on the side so you can get the right one.
Oct 30, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560. It stopped printing when i changed black ink cartridge. None of the maintenance functions work. They all show the same message: Press resume, then turn printer off & back on. 1st green...
Blinking 5 times in orange means print head not detected by the printer. You may try following procedure: remove and reinstall the print head. If the problem not solve find good print head to compare. More information please check below link
Blinking in orange 5 times
Oct 18, 2009 | Canon BubbleJet i560 InkJet Printer
Do I need a new print head?
1. Turn off printer
Sep 13, 2009 | Canon BubbleJet i560 InkJet Printer
The printer flashes orange light five times, and green once
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
This also applies to the i550, i560, i950, i960
Sep 07, 2009 | Canon BubbleJet i560 InkJet Printer
Canon i560 not printing, status light flashes 4 amber 1 green
4 blinks of the amber light says that the ink is empty, at least 1 cartridge is empty.
Jun 21, 2009 | Canon BubbleJet i560 InkJet Printer
Blinking orange 5 times and 1 green
Try this:
Most of the time when a printer used for a certain period the ink would dry out and caused an error message. What you do is to replace with a new inks pad inside the printer and reset that error message. Once it is done, your printer will work again!
For Printer Model: Canon S9000, S300, S400, i550, i560, i850, i860, i865, i9100, i9950, PIXMA iP3000:
1. Turn off printer
Please remember to rate all Techs who assist you for free :)
Oct 04, 2008 | Canon BubbleJet i560 InkJet Printer
Canon i560 won't print
The green light snable, no flashes.But test-print page is empty. All cartridges are full. Print head was reinstalled.
Sep 14, 2008 | Canon BubbleJet i560 InkJet Printer
Canon BubbleJet i560 InkJet Printer Logo
1,874 people viewed this question
old marine
old marine
