Question about Microsoft Windows Live Messanger
Msn wont allow me to log on , multiple error codes,
    President:
  • 2,291 Answers
You have registry key problems run reginout cleaner Reregister SSL security libraries. To do this, click "Start," click "Run," and type in each command below and hit ENTER.
Note: After each command is executed successfully, you will receive a "DllRegisterServer succeeded" message. Wait until you receive this message before you continue to the next command.
a. REGSVR32 softpub.dll
b. REGSVR32 wintrust.dll
c. REGSVR32 initpki.dll
d. REGSVR32 Rsaenh.dll
Posted on Oct 06, 2010
Check my email
MSN Hotmail is a popular Web-based email service.
It allows you to read, send and manage your email with just an Internet connection and a browser.
This is convenient when you are on the road a lot or when you use multiple computers at home, work and school. It takes a few moments to log in to your MSN Hotmail account.
Launch a browser.
Go to the Hotmail log-in page (see Below).
http://login.live.com/login.srf?wa=wsignin1.0&rpsnv=11&ct=1253879194&rver=6.0.5285.0&wp=MBI&wreply=http:%2F%2Fmail.live.com%2Fdefault.aspx&lc=1033&id=64855&mkt=en-us
Type your username and password in the appropriate fields on the page.
Hit the "Sign In" button.
Hit the small "Hotmail" link in the upper-left corner of the MSN page that may appear.
If your Hotmail page appears automatically, click the "Inbox" link on the left side of the page.
Click the message that you want to read in the main window.
Nov 17, 2013 | hotmail.com
GE error E61
E61 means you have the neutral and the L2 wire either reversed or in the wrong position. ENTER TEST MODE SEQUENCE by doing the following . 1.Disconnect thepower for 30 seconds.2.Reconnect the power and within 30 seconds press the sequence of buttons listed below.3.Press the "SIGNAL"button.4.Press the "DELAY START"button.5.Press the "SIGNAL"button.6.Press the "DELAY START"button. Now after you have fixed the reveresed wiring problem you will need to remove the fault code fromt he memory otherwise the machine will not work. To remove the fault code do the following ENTER TEST MODE
SEQUENCE (cont.)
You will notice "t01". To choose the test mode that you want toverify, turn the knob to the desired test mode setting.
Push the start/pause button.To cancel the test mode, press on "power".
You will be able to choose another test mode and again press on "start/pause".
The display error codes test allows the service technician to examine and clear the fault log.
DISPLAY ERROR CODES TEST
(t02)
The control shall display the most recent error in the fault logupon entry into the display error codes test. If there are no errors in the fault log, the no error code "E00"shall be displayed on the 7-segment display.
The control shall clear the displayed error from the fault log if the start key is pressed during the display error codes test. After clearing thedisplayed error from the fault log, the appliance shall display the next most recent error from the fault log.
After clearing all errors from the fault log, the control shall display the no error "E00"code on the 7-segment display.
The control shall log the last 8 error codes in the non-volatile memory stored in a circular list.
The control shall avoid logging multiple instances of the same error code. now unplug the appliance for about 30 seconds and replug and everything should be fine
credit to the original author of this solution rcadieux4444
Jun 30, 2012 | Computers & Internet
How can l log in 2 or 3 msn ID at the same time?
You mean multiple msn logons on a computer right?.. you can find the tips here..(click here to read the trick) but you'll need to access the registry.. This works perfectly.
good luck.
Thanks for using FixYa.
Jun 16, 2010 | Microsoft Windows Live Messanger
Error code 1 comes up when i access my mailbox
Error Code 1
Most likely this is temporary issue that will soon resolve itself. "Error Code 1" is generally caused from having multiple browser windows open or multiple tabs within the same browser open to your Yahoo! Mail service.
If you are still receiving the error code, please try the following:
  1. Log out of Yahoo! Mail.
  2. Close all web browsers.
  3. Restart a web browser and log into Yahoo! Mail.
Dec 19, 2009 | Yahoo Mail
Anybody can help me with this? When i try
Solutions to MSN Error Code 81000306 1) Wait for MSN to repair their Server! Meanwhile check the status of the Messenger service, at: http://messenger.msn.com/Status.aspx
2) Delete ListCache.dat
Launch CMD and navigate to %appdata%\microsoft.
CD %appdata%\microsoft
Dir /s ListCache.dat
Decide if you want to delete the cache.
Del /s ListCache.dat
Restart your MSN Messenger.
3) Register softpub.dll.
Click Start (Button), and then click Run, type regsvr32 softpub.dll. Restart MSN Messenger.
It would do no harm to also use regsvr32 to re-register: wintrust.dll, initpki.dll, Rsaenh.dll Mssip32.dll and Cryptdlg.dll. Here is the command string to register these dlls. Launch the 'Run' command and paste:
regsvr32 softpub.dll Wintrust.dll Initpki.dll Rsaenh.dll Mssip32.dll Cryptdlg.dll
4) Another problem could be firewall related, thus try temporarily disabling the firewall. If this cures the problem, make sure that MSN Messenger is allowed full access through the firewall.
Your problem could also be related to Error Code 80048820
5) If other people can access the MSN Messenger service, and you are the only one getting Error Code 81000306, then you could look at your anti-virus software. Has anything changed recently?
6) One more thought, could your account be locked out? Try another account if have one, or can create a new account.
Dec 08, 2009 | Computers & Internet
I can't log into msn..says errore porta..net messenger service non attiva..dice che sono connessa a una rete cablata,please help me
It sounds as tho your firewall is blocking the service. Go into your firewall, you will find a list of allowed programs, and simply click on allow, for MSN. BTW, MSN uses port 1863
Nov 16, 2009 | Microsoft Windows Xp Home Edition Sp2...
Msn wont let me sign in (error 800401f3)
When this happens I sometimes use the web version
webmessenger.msn.com/
MSN can be frustrating sometimes and one way I fixed logging in was to 1st log in as showing being offline mode 1st then changing my status.
Also try opening Task Manager and select msnmsgr.com from the process tab and select end process then try reopening the msn messenger and log back on.
Jul 22, 2009 | Microsoft Windows Live Messanger
Error code 8e5e0408 for msn messenger 9.0
Check your event logs running C:\Windows\System32\eventvwr.exe
If you see lots of wlcomm errors under Windows Logs/Application, that means wlcomm has no access to your user directory.
To solve the problem:
1. Back up your user directory under c:\Users\%username% just in case
2. right-click on x:\users\%username% and go to properties
3. go to security tab and click advanced
4. Change the permission set to the following:
Type Name Permission Inhefited from Apply To
Allow %username% Full Control <not inherited> This folder, subfolders and files
Allow SYSTEM Full Control <not inherited> This folder, subfolders and files
Allow Administrators Full Control <not inherited> This folder, subfolders and files
Make sure you uncheck the "include the inheritable..." and "replace.." checkboxes.
Click OK and let it run.
Now you should be able to log on to Messenger.
if that doesnt help
  1. Go to http://help.live.com/help.aspx?project=a&querytype=topic&query=Default_Help_PROC_MessengerVersion.htm&market=en-us
  2. Choose the Messenger version that you're using. (A new window will open).
  3. On the new window, click any topic at the left side of the page
  4. Click "Get more help" located at the bottom right part of the page
  5. Click "Get support."
thank you good luck
May 30, 2009 | Microsoft Windows Live Messanger
When i try to log into windows live msn it keeps coming up with error: 80048820 and says its my key ports?... I only recently downloaded this new msn and I don't know why it wont work all my other versions...
Unfortunately, there are many possible causes of error 80048820. This is somewhat of a generic error,
Lets try some easy trys first Check your System Date and Time.
sometimes Invalid proxy settings can sometimes cause the 80048820 error
sometimes your anti virus software can cause this error.
I would try and download the windows live one more time
Jan 27, 2009 | Computers & Internet
Microsoft Windows Live Messanger Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
