Question about Samsung Cameras
Stripped gear HI THERE BOGDAN,I NEED A GEAR ON THE S500 DIGIMAX ,ITS THE 3RD GEAR FROM THE MOTOR WORM GEAR.PLEASE SEND ME ONE.
Take a broomstraw and stick up your ***** Cindy. Next, crack the case open with a nutcracker. You should then be able to see the gears. At this point, spray in WD40 until everything is coated. Re-assemble the case, and then use the broomstraw to poke out your eye.
Posted on Mar 22, 2009
  • smokinjo Mar 22, 2009
    cam it up your pu$$y, Cindy. You thief.
Camera will not come on but green light flashes and camera makes three beeping sounds. Already changed batteries and still same thing when powered on. What could be causing this problem?
The reason why your Samsung Digimax S500 camera beeps 3 times and shuts down is because the internal workings of the telescoping / retracting lens barrels may be damaged beyond reasonable repair, of the casual user, and the internal circuitry senses the malfunction.
And to open up and attempt to service any digital camera, with an electronic flash, is a dangerous proposition. The Samsung Digimax S500, for example, has an internal 320 Volt, 110 microfarad photo-flash capacitor that, if accidentally touched, would hit you like a stun gun. In fact, I had to discharge the capacitor by bridging two soldered contacts (just to the upper-left and upper-right of the "53", of the "STS2-53-SR" printed on the internal circuit board). And, even though I was careful to use an old, worn out flat-head screwdriver, electrically grounded (MUST have an insulated wooden or plastic handle), the discharge arc was so violent that it destroyed the tip of the screwdriver.
And don't think that the telescoping / retracting lens barrel can be "gently forced" open or closed, as the tiny DC motor has a plastic worm-gear on its shaft, initiating torque to a miniature train of 7 plastic spur gears, before reaching the final plastic spur gear track, 120 degrees part-way around the large outside lens barrel. So, to make a long story short, any attempt to manually move the lens barrel out, or in, will most certainly damage the spur gears, as absolutely no manual movement is possible at the worm gear on the motor shaft. And, anyway, the geared motor drive provides more than enough torque, by itself, to extend / retract the lens barrel, unless there is grit and debris interfering with the smooth motion of the gears and angled slots.
Sand, grit, and other debris can sometimes find its way between both lens barrels, and into the curved, 120 degree spur gear track. And since the 120 degree spur gear track is not lubricated, it can possibly be cleaned by very lightly tapping the camera on a table top, with the lens down (this is assuming that both lens barrels are fully retracted) , to loosen any debris, and then using a vacuum cleaner: Taking care to apply the open nozzle of the vacuum cleaner, tilted (to reduce its intensity), but directly on the perimeter of both lens barrels, so as not to **** the lens barrels out, yet apply a strong vacuum into the narrow grooves.
This may damage your camera -but do you really have a choice?
Also, a piece of paper can easily inserted between the lens barrels and run along the circumference to help clean out some of the grit. And repeat the process above, until the lens works.
But that's assuming that the problem is caused by dirt and grit in the inner workings of the lens.
The other cause for the telescoping / retracting lens barrel to malfunction is either the camera was dropped (while the lens barrels were extended), or the camera "POWER" button was somehow depressed while the camera was stowed away, and the lens barrel was prevented from extending. Either situations will break off 2 teeth of the final circular plastic spur gear, that powers the 120 degree spur gear track on the outer lens barrel. If you know either of these to be the case, then your camera cannot be fixed, and a repair would probably cost more than the camera.
Dec 04, 2011 | Samsung Digimax S500 Digital Camera
Hello, our samsung digimax S500 gives problems.
HI! ITs inevitable. Even mine does it when theres light. You will just need to find a perfect spot that has lesser light.
Sep 26, 2010 | Samsung Digimax S500 Digital Camera
I need the software for digimax s500 camerafor the
check the link below you should find the driver that will help windows recognise your cam
good luck!
http://www.nodevice.com/driver/DIGIMAX_S500/get38498.html
Jul 28, 2010 | Samsung Digimax S500 Digital Camera
Just replaced the worm gear and cleaned out old grease adding clean new grease. Plugged the machine in and it will not run at all. The machine had been working but not well since I had stripped the worm...
Hi PEGNGEORGE. I can understand your frustration after getting all that work done for the gear and grease replacement just to find that it won’t run. Makes you want to scream. But before screaming, let's see what might be causing problems.
If your machine is not getting power to the motor, and you’re confident that the motor was not damaged by the stripped worm gear, which necessitated the replacement in the first place, then there are a few things that we can look at.
The easiest to check are the motor’s brushes. During your disassembly, did you remove either or both of the motor’s brushes (from the side of the mixer’s head)? If yes, then you need to check their alignment on the armatures’ commutator. The concave contact face should be resting completely on the comutator. If you've turned it 90 degrees too much, it wont' seat properly and you'll get no 'juice' to the electric motor so it won't start.
If the answer is no, and you said the mixer worked, but not well after the worm gear stripped, that would lead me to suspect the problem most likely will be with your speed control assembly.
Since you’ve already replaced the stripped worm gear, I imagine you have your mixer’s Parts List manual on hand, but if you don’t, you can download a PDF version from the KA website: http://www.kitchenaid.com/flash.cmd?/#/page/home.
Click on Customer Care>Locate Manuals & Guides> Enter the 6 character model number, in your case use K45SSW, and select the file listed under Parts List (1), K45SSWH0.pdf (341.41 KB). Check to ensure it matches your mixer model.
Turn to pages 6 & 7, titled: Motor And Control Parts, which provides an exploded view for the disassembly and reassembly of your mixer’s electrical components, along with all the parts. You’ll want to focus on Illus. No. 25, Control Plate Assembly.
First inspect around the control plate assembly to ensure all the wire connections are OK. It's possible a connection has come loose. Unfortunately the whole controller assembly is fabricated on a little PC board which was not meant to be 'home fixed', and my 'expertise' ends there. A local small appliance repair shop should be able to determine if the controller assembly is functioning properly or not, or you can just order replacement parts without the testing.
As far as parts go, here are four potential vendors in no particular order: RepairClinic.com; mendingshed.com; searspartsdirect.com; partstore.com. Prices for the same part can vary widely between vendors, so do your comparison shopping.
You may already know about the website links below when you replaced your worm gear, but it’s always good to keep these sites in your ‘toolbox’. Here are some links to several excellent websites that detail the disassembling/reassembly of a KA Mixer.
Between these three websites and their excellent pictures and descriptions and your Parts List manual, you should now be able to completely disassemble and reassemble your mixer.
Good luck and have fun. I hope this helps. Howard, Burke, VA
If this solution has helped you, please rate it, thanks! - hslincoln
Dec 14, 2009 | KitchenAid K45SS Classic Stand Mixer
Samsung digimax s500 camera
You can download what you need, here from Samsung.
Dec 30, 2007 | Samsung Digimax S500 Digital Camera
Digimax 500
my camera has been doing the same thing. and i was wondering the same thing.
Dec 23, 2007 | Samsung Digimax S500 Digital Camera
It is very hard to do. It takes a "jewler's touch." I posted how do this for some one else. I'll find it and repost for you. My advice send it in for repair.
Sep 13, 2007 | Samsung Digimax S500 Digital Camera
Cameras Logo
26 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
