Question about Numark CD Mix2
Im trying to hook up two sets of passive speaker, one pair is connected to a QSC amp and the other pair is connected to a Kenwood amp. Is this possible without using another mixer like a mackie 1402.
    Genius:
  • 1,066 Answers
You should be fine, you can get splitters, little adapters to split the input cables into 2, so that you can use one ouytput to run 2 channels. just hook up the output cables to the output on the numark, and use the splitter adapter to split the sound between the 2 amps.
Posted on Nov 27, 2010
Qsc hpr153i rattle
Please specify a bit more, does the rattle is physical(Enclosure structure) or electronically hear thru speaker(Power Amp Common Issue)? I have the solution for the amp issue, let me know.
Mar 20, 2013 | QSC Audio Products QSC HPR153I 12 SPEAKER
Hi, How do I connect a powered subwoover to my PMP 6000 when i have connected 1 pairs of passive speakers to Output B and 1 pair of passive monitors to Output A . Ampmode switch set to Monq1 and Mono...
hi,
this mixer has output's from cd/tape(rca plug) that can be used to connect an additional amp for output to a sub. It is designed to use for recording but may also server as a pre-amp output to an external amp of choice.
GL
hope this helps
Don't forget to rate my answers
Thank You
Jammer
Sep 26, 2011 | Behringer PMP6000 / B215XL Powered Mixer...
Connect Qsc pair kw122 powered speakers and kw 181 powered sub to peavy pv14 mixer?
Two things... Use BALANCED LINES, either XLR or TRS... AND power the mixer from the same receptacle or power conditioner as the speakers and the sub.
Apr 30, 2011 | Peavey Electronics Peavey 00512140 PV 14...
Hey, i bought a new pair of samson auro D415 speakers and i connect them in parallel because one of my main mixer outputs ain't working.but even if al my signal gains and fader levels are low,the peak...
Check only one active speaker at the mixer output and report the results.
Connect only one of the audio inputs from the power amp at the mixer output (and the passive speakers at the output) and report the results.
Sometimes (in parallel connections) there are interferences from the volume controls.
In case of a problem or clarification or further details needed, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Mar 30, 2011 | Samson Auro D415 - 2-Way Active Speaker...
I use a Mackie 1604vlz board. I have Passive EV Speakers that I use a QSC power amp for. I want to add one Powered Subwoofer to this. How can I hook up without buying a crossover? Can I run out frome the...
You can, but I would not suggest it. Depending upon the input design of the powered sub, the highs might not get filtered out. Many subs assume that they are only receiving the lows. You are better off using a crossover between the mixer and the amp for highs and the powered sub for the lows. Please note that the crossover will give you much more control over the sound quality.
Dan
Mar 29, 2011 | Mackie 1604 Vlz3 16 Channel Mixer
I have four active and two passive speakers how do i hook up to amp
Assuming they are ALL mains and not for monitors connect this way:
Connect the passive to the A and B powered outputs. Please read my tip on Fixya regarding hazard of grounding speaker leads on channel A of PMP mixers.
Connect each pair of active speakers to the Main L and R 1/4 inch jacks using TRS balanced cables. Power these speakers from the SAME receptacle or source, even if it means running an extension cord to your mixer from where the actives are plugged in. FAILURE to do this creates a hazard of ground loops and ground bounce that can damage equipment. The Main L and R 1/4 inch jackls can drive more than one active speaker... these are line level signals. Make sure to use TRS balanced cables for this.
Nov 10, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Peavey XR800F 8 channel - I can't get but very little sound to my big speakers. Help
Troubleshooting is always a "process of elimination." Have you tried hooking up your Peavey powered mixer to another set of speakers? How about connecting the speakers to another audio system? Your term "very little sound" could mean audio input problems, mixer/amp settings or failure and possibly speaker damage (internal passive crossovers). Please be more specific.
Jun 12, 2010 | Peavey Pv 2600 Power Amplifier
How do i hook up my new behringer pmp 5000 mixer to my fast track pro audio interface for home recording? I also want to be able to use 2 passive loud speakers. Any help most appreciated. Yep, im a newbie.
Passive loudspeakers are connected to the two "Speakon" connectors on the back of the unit. BUY GOOD cables for your speakers!!!! Whatever you do don't have a speaker line come loose while driving audio out !!! You will arc- out the rear-most power amp... I know, I repaired two of these now with the problem.
Connect the recording device to either the "tape OUT" RCA jacks or either of the pairs of MAIN out TRS jacks.
Set the slide switch for the MAIN L/MAIN R (upper position) leave this in this position unless you understand what the other positions are for to avoid damage. You will NOT need the other positions.
Further: Power ALL interconnect devices from the SAME receptacle source to avoid ground loops and possible damage.
YOUR passive speakers should be rated at least 300 Watts RMS continuos power handling or 600 Watts peaks.
Drive consumer stereo speakers with this and you will smoke the speakers and MAYBE blow the amp. This is a powerful amplifier and if you don't have at least 15 inch speakers you MUST really hold down the volume lest you blow the speakers.
Above all read the manual... yes, it is a bit hard to understand...
If you have a problem you can contact me by email for a bit of help. I have wo of these I have been using at venues now.
Apr 24, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
Numark CD Mix2 Logo
107 people viewed this question
Top Numark Music Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
rhodesworks
Seanzilla
Are you a Numark Music Expert? Answer questions, earn points and help others
