Question about GPS
Problem download music to sd memory card for my GPS.
No problem with GPS.but having problem downloading music from computer to SDHC card.
  • Lost larry May 31, 2008
    I have the same problem I have sat here cursing for hours trying to get music on my Uniden GNS 8430. If you could help that would be great?
  • heididuncomb Jun 28, 2008
    i dont know how to get music on my SD card from my iTunes...?
I dont know how to down load music to my gps
Posted on Jul 30, 2009
What card goes in this camera
Your camera can accept SD memory cards. Don't try to use SDHC cards. Before SDHC, they produced 4 GByte SD cards, now almost all 2 GByte and up are SDHC. Because your camera is not compatible with the newer versions of SD(HC and XD) you can't use them.
The manual says SD cards up to 2 GB.
Jun 26, 2014 | WildView Infrared Xtreme 5 Ir Game Trail...
How to unlock the micro sd memory card's password
Sorry. You can't. But you can usually recover use of the card by inserting it into an external SDHC card reader (using a suitable micro SDHC to SDHC adapter) and then refomatting the card. You may need to use the host computer to go into the cards properties first to uncheck the "read only" status.
This makes all data stored on the card overwriteable as if it's no longer there, but there is plenty of free/cheap data recovery software which can recover data from reformatted memory cards as long as the card has not been used after formatting.
Jul 17, 2011 | Skque 16GB MicroSDHC / MicroSD / Micro SD...
I am trying to download the Mexico 2011 map and the download stops because it states I do not have enough space. They advised a 4 GB SD chip which I purchased and installed. The download still stops and it...
When you go to download the map by default it tries to download it to the satnav i.e. not the SD card. When the website recognises the satnav it shows it in a drop box with a drop-down arrow. Click the drop-down arrow and it should give you the option to download the map to your computer. Download it to the hard drive.
After it's downloaded it may begin the install automatically. If not click the START button on your computer and go to GARMIN. In the garmin menu click MAPINSTALL to begin the installation.
When the install program finds your satnav and you get the option to install the map there again click on the drop-down arrow and select the drive letter of the SD card. This will be different to the drive letter for your satnav. The map will then be installed to your SD card.
Before you begin to install to the SD card you should know that it can be very hard to get get the 200W, and other satnavs of the same age, to run the map from SD cards. It will install to it without problem but when you try to operate the satnav then it cannot load the map and will close down again unless you remove the SD card. I recently had this problem with a garmin nuvi 760 and contacted garmin about it. They told me the problem is that 4 Gb SD cards are SDHC which operate differently from SD. They said to get a class 2 SDHC card. (You can identify the class by the small figure on the card. It will be either 2, 4, 6, 8, or 10). Before you install the map format the card. Also use webinstaller to check that you have the latest version of operating software on your satnav.
Format the SD card with "Panasonic SD Formatter" available from http://panasonic.jp/support/global/cs/sd/download/sd_formatter20.html
rather than the standard windows format function. Select the fast format option and be sure you have selected the drive letter of your SDHC card as it will format your hard drive just as easily if you select it by accident or your satnav.
To update your software you can download webupdater from http://www8.garmin.com/support/collection.jsp?product=999-99999-27
Connect your satnav to the computer and run the program. It will search for any updates to your software.
Class 2 SDHC cards are available on ebay if you can't find one in the shops.
After failing to get mine to work on a class 4 SDHC 4Gb card I followed their instructions and it worked for me. Hope it works for you too.
Oct 27, 2010 | Garmin nuvi 200W GPS Receiver
How do you download music to your gps
You do not download music to the GPS, put music files onto a SD card and then put that card into the GPS. You have to remove the Map SD card to do this so you cannot play music and use the GPS at the same time.
Jun 23, 2009 | Nextar X3B GPS Navigation System
How to add music and video files to the sanyo nvm-4370 gps system
Option 1 (Internal Memory):
  • Connect the GPS to your computer with a supplied USB cable
  • For Windows, go to My Computer and find the connected drive (Removable Disk), when you open this disk you should see MobileNavigator folder
  • From the root of this drive, you can create 3 folders: Photos, Music, Videos and copy your media files respectively
  • Safely Remove Hardware the connected unit and unplug
  • Select your player/viewer (Photos, Music, Videos)
  • By default the internal memory (a can shape icon) is selected
  • Now enjoy your media
Option 2 (SD Card):
  • Assume your computer has a SD card reader
  • Insert the SD card to your computer
  • Insert the card to the Sanyo GPS
  • Tab the internal memory option (a can shape) to change to SD card option (sd card shape) to access files on SD card
Feb 26, 2009 | Sanyo EasyStreet NVM-4370 Car GPS Receiver
Garmin nuvi 610
VERY SIMPLE-to SD card to 4GB (not SDHC)
Dec 27, 2008 | Garmin Nuvi 610 GPS Receiver
Reformating card
I deleted TomTom Home from my computer. I downloaded a version of Home just for Mac OS 10.4 users and rebooted. Then I followed the directions and it downloaded all of my maps, etc to the original TT SD card. I also set up my cell phone with a bluetooth connection.
Didn't need to reformat the new SD card I had bought because the original card had enough room for everything.
Thank you for asking.
Jul 12, 2008 | Tomtom GO 510 GPS Receiver
Memory expantion
If TT Go720:
- Buy a SD card, the faster the better..
- Choose between a SD or SDHC card.
- Mount in card slot, and your done...
The unit will read from both internal and SD card at the same time.
Example:
- Make a folder on sd card named "mp3"
- Put some mp3 somgs in there, and they will appear in the Music and Media option on the unit...
Any more questions, please don't hesitate.. ;-)
(Please remeber to vote. Thanks.)
Jun 21, 2008 | Tomtom GO 720 GPS Receiver
To download
The manual is helpful isn't it?
Your music and pictures need to be installed onto a SD memory card. Take an empty card and copy the MP3 or pictures onto the card. Install the card into the GPS. Use the correct player (for pics or MP3) and see if it detects the music on the memory card.
It seems like it works the same way if you were to put music or photos onto a Palm. It may need a special folder on the card to read the photos or MP3s. I would put it into the GPS first, let the GPS format it, and see if it creates folders for them.
Jun 17, 2008 | Fine Digital FineDrive 350 GPS Receiver
How do you get SD cards to play ???
Are the songs in MP3 format? Typically you connect the GPS to the PC using the USB interface and using Windows Explorer, drag & drop the MP3 files into the GPS's MP3 subdirectory.
Then on the main screen, select travel tools and then the MP3 player. Select browse and choose a song.
Please let me know if I can be of further assistance to you.
- Jim
Feb 22, 2008 | Garmin Nuvi 660 GPS Receiver
GPS Logo
428 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
