Wont switch to heat from ac is a ruud heatpump
  • 24 Answers
Is the thermostat showing that it is switched?
Posted on Oct 06, 2010
  • Jeremy Long
    Jeremy Long Oct 06, 2010
    yes is indicating and calling for heat
  • imagolfer15 Oct 06, 2010
    Is the outdoor unit running?
I have a RUUD UPKA-036jaz heatpump. Anytime the thermostat is set to heat, the reversing valve coil is energized. Even if the unit isn't running. Is that normal?
Most heat pump reversing valves energize in cooling. Does it ever "deenergize". If not its stuck, if it does check programming, may be setup to operate that way. Or possibly wired wrong or wired as straight cool. To answer your question, i dont think that is normal.
Nov 08, 2016 | Ruud Heating & Cooling
Unit set to heat but outside unit fan won't turn on. Outside temp is below freezing. The weird thing is that you unit is putting out heat and not set to emergency heat
If it is a heatpump, the outside unit should not turn on below 35degrees or so. Below that temperature, the unit cannot effeciently exchange heat. When the outside temperature is low, the system automatically switches over to auxillary heat which uses the same heating elements as emergency heat.
Jan 11, 2011 | Ruud Heating & Cooling
2005 s type jag a/c quit blowing cold air suddenly .just blows hot at any setting or on auto
hi,is this a heatpump or a ac unit only...if a heatpump ,there is a valve that switchs from heat tocool mode...go outside with unit running..put hand on big copper line,if it is hot your in heat mode..if cold your in cool mode....possible stuck change over valve if a heatpump...hope this helps...good luck...michael doctor airr appl.repair..843-384-8474...if need more assitance..call..its free...good luck
Mar 26, 2010 | Heating & Cooling
Ruud UBHC AC System - Provides no Aux Heat
Tried this on my unit today, and observed the same results, but got Aux Heat (with A setting), if the H (blue wire) connected to B terminal, as per instructions for my 6036 Ritetemp. However, in this case, when the set temp is reached, I hear the click, but HVAC still blows aux heat indefinitely.
I also have RUUD UBEA 17J10..., and replaced my old honeywell with 6036, and can't get heat pump working. Both of my units are 14 years old, so I'm thinking to replace them soon.
Jan 06, 2010 | Ruud UBHC Air Conditioner
Tempstar phad42n1k1 heaters come on in ac mode and compresor or fan wont run in heat mode. was able to make heatpump go in defrost mode and compressor runs.
sounds like u have the thermostat wired wrong or bad wires i would check that first make sure you have the wright thermostat
Jan 05, 2010 | Ruud Central System Air Conditioner
Hello, I have a 1.5 ton rudd ac/heat pump
Your outside unit is not defrosting. You need to call a service tech to check it out. Defrost board sensor or low on gas. Also you amy have an outside tstat that is not working correctly. Rus
Dec 06, 2009 | Ruud UAMB042 Air Conditioner
Ruud ac wont come on. mfg 03/99. thermostat
Have an electrician check the connections in your panel, this sounds like a loose/bad nuetral connection
Jul 26, 2009 | Ruud Heating & Cooling
Smell when unit comes on with heat
Hi!!!remember everytime you turn on yout furnace you will have a strange odor thats all the dirt that is burning from the heating element if your using the emergency heta if not the what you are smelling is your fan motor replace it and you should be fine..Good luck..
Jan 19, 2009 | Ruud Matching Split Air Conditioner
Heating & Cooling Logo
14 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
