Question about D-Link DI-704P Router
Mac Support for DLink 704P Router
Is there a Mac version fo the Dlink Print Server software that came with the D704P? Thanks in advance.
  • Elvie88 May 28, 2008
    Very helpful. Wonderful.
  • Elvie88 May 29, 2008
    Thanks alot for this useful information. When you say still "couple the server to mac" - will this work also on 704P (revision A)?
  • D-Link Master
  • 19,396 Answers
The DI 704 P software is not distributed anymore , as D-Link discontinued the product.
Among 704 P only last version (revision D) supported mac, check here to find out your version.
You can still couple the server to mac using this procedure, give it a try.
If it does not work contact D-Link and ask if you can have copy of control software.
Posted on May 28, 2008
Printing on HP Laserjet 1020 connected to the network through DLink DPR-1020 print server
did you resolve this issue , beacause have the same problem with a Toshiba e studio e223 ?
Jan 31, 2013 | D-Link Dpr-1020
Hi sir how can i change ip address for Dlink printer server DP-301P+
Logon to the Print Server web configuration and begin managing the DP-301P+, simply launch the browser (e.g. Internet Explorer) and type dlink-xxxxxx, where xxxxxx are the last six digits of DP-301P+'s MAC address. The MAC address can be found on the bottom side of
the DP-301P+ device.
Default IP Address of DP-301P+ is set as automatically getting from DHCP server or Router with build-in DHCP server. Please note that the PC's IP Address must be in the same subnet as the print server's IP Address for the two devices to communicate. (For example, if print server's IP
Address is 192.168.0.10, with a subnet mask of 255.255.255.0, then your computer's IP Address should be 192.168.0.x, where x is a value between 1-254, excluding 10.)
For additional information, please refer to Dlink printer server DP-301P+ Product Manual
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Jan 11, 2011 | D-Link DP 301P (DP-301P) Print Server
Have a linksys router tring to get adlink print
Did the dlink print server come with an installation disk? If so, you probably need to run that. It will help you set up a virtual printer port that you can then choose when adding a printer. For seting up two printers, you'll have 2 different virtual printer ports. For example SCB77031_P1 and SCB77031_P2.
If you need more help, please let me know what model linksys router and dlink print server
Aug 23, 2009 | Linksys Computers & Internet
Print server for vista, D-link DI-704p
I can recomend to your network setup is WPS54GU2
Wireless-G PrintServer for USB 2.0
******************************** Before configuring the wireless settings of the printserver, make sure to know the following settings on your D-link router: SSID, and wireless security.
Configuring the Wireless Settings on the Printserver
The wireless settings of the printserver can be configured using its web-based utility. Make sure the printserver is set to a static IP on the network.
NOTE: Make sure the printserver is already working when hardwired to the Dlink router before attempting to use it wirelessly on your network.
Step 1:
Access the printserver’s web-based setup page. Open a web-browser such as Internet Explorer.
NOTE: If you're using Mac, use Safari to access the printserver's web-based setup page.
Step 2:
Go to the address bar and enter the IP address you've assigned to the PrintServer.
NOTE: To assign the PrintServer a static IP address, click here.
Step 3:
When the printserver setup page appears, click Wireless.
Aug 01, 2009 | D-Link DI-704P Router
I want to put password on my router
just open your dlink ip page and type the username as admin and leave the part of password.
it will open a page where there is a palce to add a wifi password
sagar
May 15, 2009 | Directed Electronics Dlink DP-301U PRINT...
D-link DI-704P lost CD
http://support.dlink.com/products/revision.asp
go here select your version and download everything you need
May 02, 2009 | D-Link DI-704P Router
Can't connect a Dlink 1260 Print server through my Linksys wireless G router
A couple of things to check for:
  • If the wireless network is encrypted on your router verify that you have the right encryption key programmed on the print server
  • You are connecting to the corret router (Verify the SSID of the network - SSID being the networks name)
  • Make sure you are in an acceptable range , not 500 feet away from the router
  • Verify that the print server has a connection to the printers connected to it
  • Try rebooting all of the equipment (router , server, printers)
Oct 02, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Router and New Print Server Not Talking?
what hardware version and firmware is on router.you might need to update firmware depending on what firmware is on now.
Aug 15, 2008 | D-Link RangeBooster G DPR-1260 (DPR1260)...
Vista Compatibility with DI-704P
The print server software does not need to be installed in order to print to the printer attached to the 704P from Vista. I went out to D-LINK's website and there are step-by-step instructions for configuring port 192.168.0.1 and associating a printer with that port.
See the following link:
http://support.dlink.com/faq/print.asp?productid=794
These instructions are for 2000/XP but they are very similiar to what you need to do for Windows Vista. I tried it and it worked fine. It did take me several tries however, as I should have read through the steps completely first.
May 29, 2008 | D-Link DI-704P Router
D-Link DI-704P Router Logo
179 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
