Question about Casio Privia Keyboard Case
I have a Casio Privia & I believe liquid fell unto the keyboard & as a result 8 notes do not have any sound. How can I get this repaired? I bought this 3 years ago.
You can try to dry the inside of the keyboard by taking the end of the key board off.
Take a hair dryer and place it at the end of the keyboard and let the air dry out the fluid this may take some time depends on how much fluid you have inside.
Do not use the dryer on high because the heat will warp the bed the keys fit into, this will damage the board which cost about $ 400.00 to repair. Do not turn on the key board while the fluid is still inside this can also damage the keyboard. I belive you have already turn it on because you said eight keys do not work.Do not open the keyboard because the keys will be hard to put back in the grooves the way they were.
You can try and have it repaired at American Perfect Crystal Corporation
Casio Parts Distributor 520 Eight Ave. 2nd Floor
New York, New York 10018
212-246-8292
800-345-0537
sales@americanperfit.com
www.americanperfit.com
They will charge about 50-89 dollars to check it for you and if its reparable the checking fee will go toward the repair.
I wasted kool-aid in my casio privia while the keyboard was off, but made a grave mistake because I tried to repair it my self with the hair dryer at a high level. I was told that the major board was warp, that being said try not to do self repair.
Posted on Dec 22, 2010
I just got a 18 month old privia px130 and when I play the G keys (middle and -1) and the -1C there is a hissing sound. If it only happens in the electric piano setting. If I set it on duet, it happens...
First thing is to verify if the sound is there using headphones. This is important test as it isolates problems in power amps and other connected equipment that may be sensitive to the particular pitch of those keys. If it is in the headphones, then likely you will have to take it to a repair shop as the problem would be very deep in the unit's sound generator hardware.
Jul 25, 2011 | Casio Privia Px-130 Px130 88 Key Digital...
Can i tune the privia 130
Refer to page E22 in your user manual. Please note that the default pitch is crystal controlled and quite accurate, but if you need to detune it you can do so as well as changing the temperment.
Jul 03, 2011 | Casio PX 130 Privia 88 Key Digital...
I've recently purchased a Roland foot pedal for my casio privia px-300 keyboard. When playing a note, even though the pedal is not pressed, the note sustains. When I press the foot pedal down, it cuts...
Sorry, but Roland uses the opposite sense switch. They use normally closed where Casio requires normally open contacts. SOMETIMES one can rewire the pedal internally, but you have to be mechanically and electrically inclined to do that.
Jun 04, 2011 | Casio Privia Keyboard Case
Is there a "Factory Reset" procedure for a Casio Privia PX-575R
Here is a link to the manual:http://ftp.casio.co.jp/pub/world_manual/emi/en/PX410R_e.pdf Page E-79 describes the procedure. Here is a link to their support page in case you don't have the CD that was bundeled with the keyboard:http://www.casio.com/support/
Oct 17, 2010 | Casio Privia Keyboard Case
Casio Privia PX-130, 8 months old: fluttering sound
If I were to venture an educated guess I would vote for failing filter caps in the power supply.
The power is likely collapsing under load of the speakers but headphones take much less drive.
If this has an external wall-wart power supply, you might try a new one IF the output is found to be under the rated voltage.
Internal power supply components are beyond those individuals that are not adept at electronics.
Jul 13, 2010 | Casio Music
How to adjust the metronome on casio privia
You hold down the function key/button and then use the PIANO keys with the "tempo" shown above them.
In that section of the keyboard, the C# key raises the tempo and the C key lowers it. You can also use the numbered keys in that section to dial up a particular value. Hold function down and strike the numbers you want then release the function key/button
I don't believe there is an adjustment for loudness of the metronome other than the overall loudness of the piano..
Mar 26, 2010 | Casio Privia Keyboard Case
Casio Privia PX-800: When using the sustain
Check if the cble frm the pedal MIGHT be flexing or pulling on the keyboard case when you use it. Such movement COULD vibrate the power connector causing your problem.
Make sure you have the right power supply for the unit as one with too large a hole for the power pin would be intermittent like this.
Jan 26, 2010 | Casio Privia Keyboard Case
Casio Privia PX-120 cannot be connected to Reason or FL
When you are using midi the sounds from your keyboard aren't sent anywhere. What happens is control messages are sent over the midi cable from midi out to midi in on the other device which must have midi sounds on it (in your case the sound card) to make any sounds. The messages can be things like note on/of or pitch bend etc. If you want to send messages to produce a result on your laptop and still here something you can loop the messages by running from midi out on the device end ( your laptop) back to midi in on your keyboard. A much better explanation is available here:http://www.indiana.edu/~emusic/etext/MIDI/chapter3_MIDI.shtml I also signed up to this site (its free) that has great people and lots of info:http://www.recordingreview.com/ I recommend downloading Killer Home Recording setting up which at this time is also free and has the best advice you could want in it. I'd also recommend checking out Reaper which is comparable to Reason, Cubase or Protools. If this helps please let me know.
Jan 21, 2010 | Casio Privia Keyboard Case
Casio Privia Keyboard Case Logo
342 people viewed this question
Top Casio Music Experts
Michial Gueffroy
Ben Armstrong
Are you a Casio Music Expert? Answer questions, earn points and help others
