Question about Minolta Di3010f Printer
Minolta EP1080 Error Code C004C - Fan Motor Problem.
  • Minolta Master
  • 6,161 Answers
Look for the ozone filter the fan next to it is bad replace it.
Posted on Mar 01, 2015
2 Suggested Answers
Cogz
  • 1326 Answers
SOURCE: Have a MINOLTA CSPRO 4000, erro code C0040----"FAN
The fan is not easy to replace...... The fan is located under the black transport belts. The fan is part
of the unit that brings the paper from the transfer & drum to the fuser unit. The unit is black and it looks like tank tracks. From what I remember the fan is acturely in the transport unit ... Good Luck
Posted on Apr 28, 2011
I have a minolta Photocopier CSPro EP1080 that keeps displaying an error message; C04 with a Spanner sign as well, what will I do?
Exposure lamp is burned out or the board the operates it is or both. The exposure lamp is the very bright light hat comes on when you make a copy under the the big sheet of glass. Raise the document feeder up and press start button does the bright lite come on and scanner move?
Try to reset. power off the machine, remove the top rear cover. Find the main circuit board now turn on the machine wait for code to show up and press the small black button on board lower right. if the code comes back try below parts.
Try this site for the lamp as a start
Precision Roller Printer Toner Cartridges Parts and Supplies Office...
Dec 10, 2015 | Minolta Office Equipment & Supplies
HOW DO I CLEAR ERROR CODE C004C FROM MINOLTA DIALTA Di 250?Thanks.
Ozone Fan is causing this code it is located under the paper registration assy. which is the large assy. attached to the door on the side of the machine where you open it up. It has a large clutch to the rear, sponge looking roller, and a shiny roller two tabs hold it in place two springs underneath. The fan might need to be cleaned or replaced.
Aug 14, 2015 | Minolta Office Equipment & Supplies
What is the solution to error code c004c
0040 - suction fun motor malfunction problem.Use the vacuum cleaner and clean the ventilators.
OR
Replace the fan at the top of the machine. the one that is at the top, near the optical section.
Apr 24, 2014 | Konica Minolta DiALTA Di200 Copier
C004c
It is a fan error.The fan is not easyicon1.png to replace...... The fan is located under the black transport belts. The fan is part
of the unit that brings the papericon1.png from the transfer & drum to the fuser unit. The unit is black and it looks like tank tracks. From what I remember the fan is acturely in the transport unit ... Good Luck.
I am getting error code C0045 on the Minolta Di2510f
Error C0045 indicates a cooling fan motor malfunction. Either the cooling fan motor or the master board needs replaced. I have a copy of the service manual on PDF if you would like to attempt the repair yourself.
Mar 31, 2010 | Minolta Di251 All-In-One Printer
Hi sir......i have minolta machine 1080......i want to cancel the mark of toner....how?...plz..
Minolta 1080
C000 Main drive problem C001 Main drive speed. Too fast or too slow C004C Fan motor problem C004E Power supply fan problem C0070 Toner motor drive problem C0071 Toner motor speed. Too fast or too slow C010 Drum motor drive problem C011 Drum motor speed. Too fast or too slow C0400 Exposure lamp does not turn on or AE sensor problem C0500 Low fuser temperature during warm-up C0510 Low fuser temperature after warm-up C0520 High fuser temperature C0600 Scan motor drive problem C0610 Lens motor drive problem C0620 Mirror motor drive problem C0990, C0991 Main tray up problem C0992, C0993 Main tray down problem C0994 Elevator motor problem C0996 Main tray shift problem C0998 Tray shift problem C0999 Tray shift return problem C099A, C099b Shift home problem C099c Shift drive motor C0b10 Auto exposure sensor problem C0b11 Paper clamp motor C0b30 Paper aligning motor C0b31 Paper aligning motor C0b50 Stapler motor C0b51 Stapler problem C0b52 Stapler sensor C0b60 Sorter bin motor C0b61-C0b64 Sorter bin movement C0d00 Duplex rail sensor sensor problems C0d20 Duplex home sensor C0d50 Duplex drive motor problem C0d51 Duplex drive motor speed C0F10 Auto exposure sensor problem C0F30 Paper aligning motor C4100 Exposure lamp stays on C0F79 Paper empty sensor problem
Sep 13, 2009 | Office Equipment & Supplies
DIALTA 351
The C004C is ozone fan motor M8 malfunction.Check various parts for possible overload or change PWB-A if the code persist after reset.From reset open and close the right door,or turn OFF/ON the power switch.
Aug 19, 2009 | Konica Minolta DiALTA Di200 Copier
C04 in Ep1080
The exposure lamp is it coming on? Thats the real bright lamp under the glass where you put the orginal documents, To reset open close the front door., Code C-0410 is the lamp is on to long. Check the scanner itself that it moves any loose connections or binding?, Mite have a problem with the scanner circuit board? Second reset is behind machine, remove back cover, looking at the circuit board from the rear your left side see a small black button on the board press it. copier must be on
Aug 08, 2009 | Minolta Office Equipment & Supplies
Error Code C04
Let the copier on then press S1 (reset switch ) on Board-A.
Apr 04, 2009 | Office Equipment & Supplies
Minolta Di3010f Printer Logo
407 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
CheckitRight
CheckitRight
David Burkhart
David Burkhart
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
