Question about Linksys Wireless-G WRT54G Router
Public ip address
Hey wiz do you know the public ip address of linksys
    Sergeant:
    Champion:
  • 427 Answers
Im not sure if there is such a thing as a public ip adress. The ip address is automatically given out by your router. (192.168.1.100, 192.168.1.101 ect.)
Posted on May 29, 2008
How to find a IP address for my emachines laptop
go to start -- run and type in CMD
hit enter to open a black command prompt window
type in "ipconfig" without the quotes and hit enter. This will give you your IP address.
If you need the IP address from your provider that you are using out on the public internet, just go to http://whatismyipaddress.com/ and it will tell you what your external public IP address is.
Mar 06, 2013 | E-Machines eMachines Desktop PC
Whte is my ip addres
Open a command line (e.g. run CMD to get a 'dos' prompt) and execute:
IPCONFIG
The line with IPv4 will have your IP address
Sep 20, 2011 | Linksys Wireless-G Broadband Router
I need to assign public ip to my pc onlyhow to set up this on the router
Connect your router to computer with ethernet cable then you can access it with following default link. http://192.168.1.1 or http://192.168.0.1 or http://192.168.15.1 or http://192.168.2.1 If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it. Then it ask for user name and password. Type user as "admin" and password as "admin" or "password" or blank. Then you can see configuration page of router. Then click on WAN settings and configure your router as static ip then enter ip address and dns server of internet service provider. then apply if you want ip from router enable DHCP Then click on wireless settings then turn on wifi set SSID . If you want secure wifi then in wireless security enable WEP enter WEP code it is your password for connect wi fi. Then save settings and restart router. Let me know if you need further assistance. Thanks for using FixYa.
Jul 06, 2010 | Linksys WAG200G Router
Wireless webcam behind dsl modem/router and a wireless router
What you have to do is ,first covert the modem into bridge mode, then configure the router in pppoe modem by having internet username and password from ISP .. that will resolve your problem
Mar 22, 2009 | Linksys WVC54GCA Network Camera
How to contact sys-admin(wiz)
Plug the print server in the back of your computer using the ethernet port. Insert the setup cd into the same computer. Assign an IP address for you print server using 10.10.10.xxx. xxx=available address number on your network. If it requires the gateway address use 10.10.10.1 if that is the correct address of your Linksys router.
You can verify the correct router address from your computer. Make sure your computer is connected to the network (not the print server) and go into the control panel. Select Network Connections. Move the mouse to you network card. Press the right mouse button and select status. The gateway address is your router address.
Jan 06, 2009 | Zonet (ZPS1000) Print Server
Xbox 360 to Linksys wireless modem...
OK I think the easiest way to connect the xbox to the linksys, is if you configure your XBOX to have a static IP address, because the xbox will not have to pick an IP address every time you connect to the internet using the Linksys router and will not have conflicts with other PCs on your house, if you have any. What the linksys does is to convert your Public IP addres into a Private IP address, so example if your ISP gave you an IP address of: 209.235.205.30 that is your IP address for you, then the Linksys converts that number (NAT) into a private IP address so it can be share with many computer inside your house using a single Public IP address. The Linksys always transform it into 192.168.1.?=any number between 1-256 thats the defaults IP address from the manufacturer but you can change it if you want. Ok enough info about NAT or IP jeje.
Where going to use the default IP addres for an easier setup.
First: On your XBOX 360 dashboard go to SYSTEM, then Network Settings, then Edit Settings, then choose the option manual, here put the IP address= 192.168.1.33 (if 33 doesn't work use another numer like 20 or 45 just pick a number between 2 and 250) ; Subnet Mask = 255.255.255.0 ; Gateway = 192.168.1.1; DNS options put Automatic. And see if it connects. If it doesn't work just post it here, any problem that you have.
Aug 22, 2008 | Microsoft Xbox 360 Console
WRT54G Can Not Connect Wireless
hey to know your ip in windows just go start, then run, then in the blank space type cmd and in the console write ipconfig and thats all, you will have all adapters with their name and ip address under the identification ip address...
but is that whay you needed to know? or you mean something else?
Mar 17, 2008 | Linksys Wireless-G WRT54G Router
LINKSYS ROUTER
You need to know the ip address of your dvr. It might have a factory set ip address or a dynamic ip address from the router. You can then use this ip address to access your dvr.
If your dvr has a static ip, that static ip should be in the same range as the router's ip address so that the router can communicate with the dvr.
Mar 12, 2008 | Linksys Wireless-G WRT54G Router
RCA Modem DCM315R
Just a bit of explanation. E0 interface is for inside network (LAN interface). E1 is for outside (ISP or WAN physical interface). Dialer1 is for PPPoE (the "actual"/logical WAN interface). The 1.0.0.13 is ISP provided static IP address for the use of the server. This configuration example is for running FTP server, which uses the standard TCP port 20 and 21.
The LAN uses 10.10.10.0 network with 255.255.255.0 subnet for both servers and workstations. All servers within the LAN use static IP address. The router is configured as DHCP server to give out IP info (IP addresses, subnet mask, DNS) to workstations that are configured as DHCP client.
Basically I suggest that you deploy NAT (Network Address Translation) and PAT (Port Address Translation) to setup your own servers behind Cisco router. The NAT is used to translate the ISP's given static IP address to your local IP address. The PAT is used to translate TCP ports (the port 20 and 21) between the two IP addresses.
When using NAT/PAT, keep in mind that the Internet-accessible servers are seen from the Internet as their NAT/PAT-ed IP address (the Public IP address) and not the local IP address (not the Private IP address). This understanding is very important when you or someone need to test connectivity to the server and/or when you need to create filter (access list or ACL for short) to allow only certain incoming traffic from the Internet and block others.
Side Note:
For more info on NAT/PAT concept, check out the following FAQ
»Cisco Forum FAQ »NAT and PAT; Introduction and Implementations
Instruments used in this illustration are pretty much standard for running your own servers. Please note that IP addresses, username, and password are changed. However, you could always modify the configuration to suit your situation.
This sample configuration assumes that you have a block of IP from ISP. There is a dedicated Public IP address for the router WAN interface (the Dialer1 interface) and another dedicated Public IP address for the server PAT IP address. If you only have a single Public IP address for both router WAN interface and server PAT IP address, there are several ways to configure the router.
One way is to use the same command as shown in sample configuration.
view plaincopy to clipboardprint?
  1. ip nat source static tcp 10.10.10.2 21 1.1.1.14 21 extendable
This one configuration way is suitable when you have static IP address from your ISP and you know exactly what the IP address is. In this case you have the 1.1.1.14 single static IP address for both the WAN interface and Public server IP address.
When you are unsure which IP address you receive from the ISP, or when your Public IP address keep changing; then another way to configure the static PAT is following
  1. ip nat source static tcp 10.10.10.2 21 interface Dialer1 21 extendable
With situation of dynamic IP address, at some point you still need to know the exact Public IP address you receive from your ISP for server connection testing and production time. To find out, you can issue show ip interface brief command on the router. You will then see the associated WAN interface Public IP address.
Feb 25, 2008 | RCA Cable Modem DCM315R (11603540)
Multiple WAN IP Addresses with a Linksys Router
Yes, however we recommend using the following procedure is the only way you can do so without a block of IP addresses. The example below is for instances where you have multiple public IP addresses that are not in block form. For our example the ISP has given us 3 Public IP addresses. One goes to the FTP server, Web Server, and the Router. You can setup the router for whomever your ISP is. If you have a dynamic IP address and you're unsure on the setup, please see the article on setting up the router with a static IP address. If you have a static IP address please our article on setting up static IP addresses with the router, and it will describe how to setup the router with a static IP address. Once the router is setup, it will provide the 3 PC's (In our example) with internet access. The remaining two public IP addresses should be assigned to the WEB Server and the FTP server. Note - The Web and FTP servers will not be on the Local Area Network of PC-1, PC-2, and PC.
Feb 16, 2006 | Linksys EtherFast Cable/DSL Router
Linksys Wireless-G WRT54G Router Logo
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
mark
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
