Question about Honeywell Programmable Thermostat Heater
I have a honeywell TH8000 series and the batteries died. It took some time before replacing them since it was summer. I cant get the screen to do anything now. The time and date are switching but cant do anything else. HELP!
4 Suggested Answers
  • 252 Answers
SOURCE: Permanent Hold - How do I UNHOLD the thermostat?
Press "CANCEL". Go here: http://yourhome.honeywell.com/yourhome/Applications/Wizard/Wizard.aspx
Posted on Apr 10, 2009
  • 59 Answers
SOURCE: Have moved into a house which has a honeywell
dont know the square footage of your home or how many units you have. unless you are in and out of your home for long periods of time and need a digital thermostate. get rid of it. install a 30 dollar honeywell or call a prof. to f@##$%^you.
Posted on Apr 26, 2009
  • 48 Answers
SOURCE: I want to turn off
You only need to turn it off if you are using program mode. Very nice stat btw. Heres a link to the pdf and I will also explain. http://customer.honeywell.com/techlit/pdf/PackedLit/69-1896EF.pdf Use the system select button so that the heat option is flashing. Look at the bottom of the screen and you will see 7 boxes. First one done and seventh one cancel with all boxes in between blank. Now at the same time hold the 3rd and 5th box (buttons) for approx 5 sec. A new screen will appear with a number sytem staring at 0120 with up or down arrows and 20 with up or down arrows. Push the left up arrow till the left number reads 0530. The right number will read 1 if its on. To turn it off select the down arrow so it reads 0. Then select done and your all set.
Posted on Feb 26, 2011
What is the other slider button used for? How do I set the differential +/-
Setting thermostat differential to 3 degrees? - HVAC-Talk
hvac-talk.com/vbb/showthread.php?...Setting-thermostat-differential-to...
Dec 27, 2006 - 12 posts - ‎5 authors We set both the differentials on the thermostat to 3 degrees. ... very low, but I doadmit to changing the differentials to 1 degree on the thermostat ... How does an adjustable temperature differential work?
Apr 5, 2011
Honeywell Thermostat TH8000 Series
Jun 27, 2009
Honeywell Thermostat Cycle Time
Feb 3, 2005
More results from hvac-talk.com
Oct 16, 2015 | Heating & Cooling
Honeywell thermostat is locked in the off position
sounds like keypad is programmed in lock position read manual for set up to activate keypad again.
Nov 25, 2012 | Honeywell Programmable Thermostat Heater
I have the VisionPro TH8000 home touchscreen programmable thermost, which is 3 years old, and was installed with a new heating and air system. It has worked flawlessly up until this week. All of the...
http://www.completeheating.ca/manuals/VisionPro%208000.pdf
Try the screen button and clean your screen in the given time.
also try honeywell.com/yourhome and use the contact us. They will try to walk you through and fix the problem as an ac company will usually just try to sell you another. These are not cheap stats I use one myself, I've have mine for years. I know it isn't much but hope this puts you in the right direction.
May 15, 2011 | Honeywell Electronic Programmable...
I want to turn off the adaptive intelligent recovery feature on my TH8000 Series programmable Honeywell thermostat. How do I do that?
Feb 26, 2011 | Honeywell Programmable Thermostat Heater
Non-deletable schedule in VisionPRO TH8000
The thermostat has a function called "Adaptive Intelligent Recovery".
This feature allows the thermostat to learn how long the furnace and air conditioner take to reach programmed temperature settings, so the temperature is reached at the time you set. For example: Set the Wake time to 6 am, and the temperature to 70°. The heat will come on before 6 am, so the temperature is 70° by the time you wake at 6.
You can turn off this function. Download the installation guide at the next link:
http://customer.honeywell.com/honeywell/ProductInfo.aspx/TH8321U1006
and look for funcion number 0530 Adaptive Intelligent Recovery. In this manual you also find the way to do a reset with the function number 0710.
I hope this solves your problem.
Nov 19, 2008 | Honeywell Programmable Thermostat Heater
Honeywell VisionPro TH8000 touch screen will not allow changes to the schedule. Screen is unlocked and not in cleaning mode
In the set up mode are you sure the lock was not turned on. The set up mode has a different book for the installer. Do you have the book if not check with Honeywell or let me know.
Sep 27, 2008 | Heating & Cooling
Our TH8000 Series Programmable Thermostat keeps flashing "change filter" even after we changed it. The guide book does not show how to re-set so the flashing stops.
try holding the filter button in for three seconds, if that doesn't reset the timer try the filter button and the temp. up button at the same time for three seconds.
Mar 30, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
46 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
paulcarew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
