Question about Kenmore 95822 / 95824 / 95829 Electric Kitchen Range
Display reads EO F2 Can't find what it means>
  • 15,935 Answers
F2-E0 - Shorted Touch Pad (Keypad) - Check the connection between the touch pad (keypad) and control board (clock) to make sure it is secure.
Select the 'cancel' function and wait 60 seconds.
If error code reappears then replace the touch pad, or touch pad and control board (clock) if all one assembly.
Thanks for using FixYa - a 4 THUMBS rating and POSITIVE TESTIMONIAL is appreciated for answering your FREE question
Posted on Oct 05, 2010
Testimonial: "Thank you for your help. It was very helpful."
My ranger digital pannel have a message EO F2, what ir means..?? the brand is Kitchenaid
Is it E0 F2 or F2-E0? If it is a 4 digit panel and it shows F2-E0, then it is a shorted keypad and you have to replace it. Sorry.
Sep 06, 2011 | Microwave Ovens
My whirlpool gold accubake system display has eo f 2 ,my book is packed away for remodeling, so what do I do? Thanks
Hello & Welcome to FixYa
F2-E0 error means open/shorted oven temperature sensor and to solve this problem the sensor needs replacement. If you want to do it yourself and wan to be sure before replacing the sensor then you can test it with a voltmeter between 1080-1120ohms....if it reads more then or less then this then it needs replacement however, if the reading is around between 1080-1120ohms then it is the control board that needs replacement. Please get back to me if you have any other questions.
Kevin
Feb 15, 2011 | Whirlpool Ovens
I have a new Whirlpool Built-in electric wall oven. I just installed it. The read out says EO F2. What does that mean?
EO-F2 means shorted touchpad.
Try pressing the CANCEL button to see if this clears it otherwise you will need a replacement touchpad.
Dec 13, 2010 | Ovens
Display reads EO -F2- stove top works, oven will not
F2 - E0 Shorted keypad (also called touch pad) 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Sep 14, 2010 | KitchenAid KERA205P Electric Kitchen Range
Diplay Panel shows: F2 EO
hello there:
the dreaded F2-EO code appears when the keypad has shorted out and needs to be replaced this is also known as the electronic range controle tis costs about 180 dollars and if the controle board need to be replaced this is about 250 dollars so if you can i would have both of them tested out before you spend your money on somethng you really dont need if you have the warranty you can use it to have it tested ok
Best regards Michael
Jul 25, 2010 | KitchenAid Architect Series KEBC278KSS...
Error EO F2
EO-F2
Is a poorly connected keypad ribbon.
Remove the front panel and unplu, then re-insert the keypad ribbon in the control.
Mar 26, 2009 | KitchenAid KEBC107 Electric Single Oven
EO F2 code
hi, this appears to be a fault caused by a short in your keypad - electronic range control (ERC)
this needs to be replaced unfortunatly.
To assist you finding the proper part your model numbel means that the oven is manufactured by Whirlpool for Sears/kenmore.
Oct 24, 2008 | Kitchen Ranges
Kenmoore Electric Range - Error Code EO F2
That code means your oven is a piece of ****. Put out in front lawn on big garbage day. Get inside the oven and wait until the garbage men get there. Jump out and yell, "Surprise!". After you've had your fun go back inside, get your keys, and drive to the closest appliance store to get a new one.
Oct 05, 2008 | Kitchen Ranges
Control Panel Display Reading
mommaT, the code has to do with the keypad, key held down too long or stuck or shorted keypad. Have someone remove the key pad ribbon cable from the control board and clean the ends with an eraser. If that doesn't do it, you may need a new keypad. Catriver..post back
May 13, 2007 | Kenmore 75844 / 75849 Gas Kitchen Range
Kenmore 95822 / 95824 / 95829 Electric Kitchen Range Logo
203 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Mike Carew
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
