Question about Honda Garden
I purchased a Honda Power Washer Model PWH2600 two weeks ago. I cleaned half my deck when the motor shut off unexpectantly, and now the cord will not pull to restart the engine. Any ideas what I can do for the cord to pull normally?
  • kmattisonn Oct 05, 2010
    Agree. Thanks, Clay
  • 2,841 Answers
You just bought it so it is under warranty. I would take it back to the place you bought it for service. If the starter rope will not pull then the engine may be locked up. Check the oil level and make sure it is full before returning it for service. Most Honda engines have a low oil pressure shut off to prevent damage to the engine if it may be low of oil. But you are saying the rope will not even pull which indicates the engine is locked up or something is broken in the starter assembly. You can remove the screws holding the starter rope assembly on the engine and then see if something is broken inside. But considering it is under warranty I advise against doing anything or you may void the warranty. Take it back to the dealer and let them solve this problem. You paid for the warranty when you bought it, so avail yourself of this warranty.
Posted on Oct 05, 2010
Samsung Laptop Shuts Down Unexpectedly
CHECK THE FANS! The biggest enemy to your laptop is HEAT! You just replaced the display it's very possible you inadvertently disconnected the cooling fan. Clean it while you have it apart dirt and dust prevent proper cooling
Jun 28, 2017 | Samsung Computers & Internet
My washer is alarming "suds or blocked pump"? What can I do?
Plug off the power cord from the wall mains. I give you several alternatives, sort out thru the easiest: Note your brand and model. Check on YouTube for change of motor brushes. Then disconnect your motor and check your brushes; follow noting how you dis-assemble so you can re-assemble easier. If your brushes are less than half an inch long get new brushes (thru this very site Fixya) and refit; actually this is quite easy. The spin has a lot to do with worn motor brushes. Manufactures want you to dump machines and buy; it helps them all. Not you - you shell out bucks.
If you have already cleaned out your filter, which is usually just under the tub (be prepared for a lot of water; and disconnect from the wall power socket), your washer still may not spin. So look into next para below. The tech sheet is usually taped to the body of the washer inside somewhere.
Note your brand and model. Check on YouTube for change of motor brushes. Then disconnect your motor and check your brushes; follow noting how you dis-assemble so you can re-assemble easier. If your brushes are less than half an inch long get new brushes (thru this very site Fixya) and refit; actually this is quite easy. Thespin has a lot to do with worn motor brushes.
Check the motor housing for an overload button, usually on the back and coloured black or red. Give it a push and if it clicks then the motor might have just been overloaded and shut itself off.
There is a big connector located at the motor - giving power to the motor (located under the tub) to the right side, could be loose. Disconnect the connector and refit to make sure it is tight. Before refitting the back, etc, try the spin alone; if it works you are done.
Click if helped pl, at my solution. I am doing this for the enviro. (& you)
Apr 01, 2013 | Bosch Nexxt Premium WFMC6400UC Front Load...
Broken plastic water inlet connection.
I have the same problem. The design is bad with the weight of the hose and the lelength of the plastic inlet tube from the body creates a sheer force that causes it to break. I cannot find anything but a plastic inlet part. If someone would create a metal inlet connector they could make a lot of money. You need a lot of hose slack when moving your power washer or it will break off the inlet and the parts are abotu $20. Very poor design!!
May 08, 2012 | Honda Black Max 2600 PSI Pressure Washer
Where can I get a manual for a Honda pressure washer PWH2600
There is no manual available for this machine, I do have a manual on a simular machine that would give you a good idea on the basic operations of the the machine. See attached link, click on the G 2500 VH manual.
http://www.wmpcs.com/index.php?main_page=page&id=6
Oct 09, 2010 | Honda Black Max 2600 PSI Pressure Washer
Treadmill shuts off in middle of workout
A treadmill will shut down from to much friction which is due to high motor current because the walkbelt and deck are not properly lubricated. I would recommend replacing the motor controller,walkbelt,deck and applying .5 oz of lubricant on the deck every 3-6 months or 100 hours of use. This will extend your treadmill's life many years.
Aug 09, 2010 | Precor 9.31 Treadmill
Will a honda vertial shaft motor from a power washer fix on a lawn mower
u can make any vertical shaft motor basically fit any deck two things that cause problems are blade hook up and to high/fast rpms check the rpms the power washer might be to fast for it to be used on a small mower deck
Apr 15, 2010 | Troy Bilt 5.5hp Self Propelled Mower
Mower deck will not engage.
you have sheared off the keyway either on the mandrel or pully on the engine
Jun 30, 2009 | Garden
My hp desktop computer will not turn on
Most likely the power supply has failed. This is the device that the cord plugs into in the back of the computer. They can be purchased for around $20 - $50 depending on where you go. Then you just remove the four screws holding it in, remove all the internal plugins and reconnect the new power supply. Oh and please take a moment to rate this solution as fixya. Thanks! :c)
Dec 29, 2008 | HP Pavilion a1410n (ER890AA) PC Desktop
Garden Logo
1,189 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
