Hi i have a Heat line Capriz 28, which has been working fine upto now ,its just over two years old , now has stopped working and flashing up LED showing flame or gas failure , tried resetting as user instructions but keeps doing the same , fan starts boiler lights up then few seconds later LED up again . any help please.
SOURCE: indesit w123 washing machine
hi had a similiar problem on a year old washing machine after 3 engineers later who 1..put in a new circuit board...did not work 2...put in a heating element ...did not work 3...techican engineer..put in a new motor and repalced air pressure switch...bingo did work if your drum is turning slowly and does not wash how very well you may find ur motor is getting worn out..a problem..?? b careful they r £90 so make sure its that b 4 u change it my machine started to fill then almost immedately emptied out..then tured off then i had the flashing lights hope this is some help to u
Posted on May 29, 2007
emissionwiz
  • 76861 Answers
SOURCE: flashig oil light
You either have a loose/worn engine bearing or a worn out oil pump, do not drive the car this way, you will cause serious damage to the whole engine. A oil switch is for a light, it turns on the light when oil pressure falls below about 10 PSI, a sending unit is for a guage that shows oil pressure with a scale, it may have numbers on the guage or just green and red, or high and low.
Posted on Oct 10, 2008
  • 96 Answers
SOURCE: My GOODMAN furnace GMH80703ANAA Starts but quits 5 seconds later
You have a flame sensor that may just need cleaning take out and take fine sand paper or emery cloth and clean
Posted on Nov 30, 2008
SOURCE: Heater not staying lit
my furnace pilot light is on but the burners will go off when we put the thermostat on auto. if we keep the fan on the burners will light but turn off the fan and and the burners go off
Posted on Jan 18, 2009
mrhotandcold
  • 248 Answers
SOURCE: VOKERA UNICA HE BOILER -
Vokera will send in post if requested
Posted on Oct 12, 2009
Mhu75ng stopped lighting after about a year. Fan starts, but burner doesn't light. Fan stops after about a minute. LED code is 3 flashes. Gas supply should be good, heater in another room ups
3 flashes could be the pressure switch ,jump it out see if it lights or clean the flame sensor or check the snap dice's 1 for high temp and 1 for low temp ..
Apr 12, 2013 | Mr. Heater MHU75NG
Oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where...
oven will not heat up. microwave works fine. all oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. oven will not heat up. microwave works fine. all the led light up fine. was working fine for the last 4 years. checked the circuit breaker and it is fine. is there a thermal fuse i can check. where is it located
Jul 19, 2010 | GE JKP86 Electric Double Oven
My Bose Lifestyle 28 III system is about 2 1/2 years old. The remote has just stopped working---nothing at all. I have tried 4 sets of new batteries and still no luck. Any suggestions besides purchasing a...
A new remote is the simplest and best bet. I know of no way to repair a remote without making it irreparable. Though you might check the infrared LED i the front. Does the light on the remote illuminate when you press a button?(assuming it has that.)
Jun 22, 2010 | Bose Lifestyle 28 System
SDW60 - AL08 Error - No Hot Water
Hi fridge-1,
I had the same problem and fixed it by fitting a new control board .
Best of luck.
michael-howe
May 03, 2009 | Hotpoint 24 in. FDW60 Free-standing...
Screen (f-28) and keep flashing
call for service this is a covered repair. you have something wrong with your motor or a loose connection somewhere. You say this is brand new if it is less than one year it should be 100 percent covered
Apr 23, 2009 | Kenmore Washing Machines
Slightly high pressure in C24 Heatline Boiler
my heat line capriz 25 boiler is flashing that i have flam or gas falure and has stoped workin? what do i do?
Oct 05, 2008 | Heating & Cooling
Heating & Cooling Logo
366 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
