Question about Sony FD Trinitron WEGA KV-32FS120 32" TV
No picture-- Diagnostics Light blinks twice. Set is about 6 years old. Set and picture look(ed) brand new. This occurred suddenly and for no apparent reason. Please give me some GOOD news! RTNTX
  • 4,234 Answers
The 2 blinks indicate an over-current condition. Basically that means that there is a shorted component inside the set. My first inclination is to check the horizontal output transistor as that is the most common failure part. Figure on the part costing between $10-$20. Add in the local labor rate for the total repair cost. If you can solder and are confortable workin g with eleectronics, you can repair this yourself. The Horizontal Output Transistor (HOT) is located close to the flyback transformer (part with large red wire coming out the top) and is attached to a heat sink. It has 3 legs. It may be marked C5638 or something similar. Post hte marking here and I'll give you the part number.
Dan
Posted on May 28, 2008
Tv not coming on has a blinking power button
Toshiba CX36F85 36" TV Blink - Questions - Fixya
www.fixya.com > ... > Toshiba > Toshiba CX36F85 36" TV
Toshiba CX36F85 36" TV, blink related issues. ... Every brand TV will have its ownblinking ... stand by light blinks 6 times, wont power on tv is only 4 years old. ...From the number of blinks occur at one time switch ON, you can get an idea ...
Toshiba CX36F85 36" TV Blinks - Questions - Fixya
Toshiba CX36F85 36" TV, blinks related issues. Get free help ... Every brand TV willhave its own blinking codes. From the ... Push power button and it ... and then ... stand by light blinks 6 times, wont power on tv is only 4 years old. Junk! it wont ...
Toshiba power light blinking not turn Standard (CRT ... - Fixya
www.fixya.com > ... > Standard (CRT) Televisions
Jan 10, 2016 | Toshiba CX36F85 36" TV
The tv is at least 17 years old.The blinking red light blinks 5 times ,then the tv picture goes off . The voice is still on
Five blinks is the error code for an AKB (auto kine bias) error. What this means is that the set isn't able to balance the three color guns (red, green and blue) of the picture tube properly, and it's blanking out the screen.
To get the proper colors, the signals for the three colors need to be balanced, and Sony sets have circuitry to do this automatically. Other brands don't, and when they go out of balance you see a picture that starts to show tinting or colors that are off. As the picture tube ages, it gets harder to adjust the balance until finally the AKB circuit can't anymore, and poof, the picture goes away. With a 17-year-old tube, it's not surprising.
There isn't anything that can be done to fix the picture tube, it would need to be replaced. But the cost of the tube and the work required to get it set up after installation makes it completely uneconomical to repair this TV. A new picture tube is nearly $200. Then special tools are required to set the tube up (a process called convergence), so you'd need to find someone to put it in, and possibly pay to have the old one disposed of. A new 32-inch LCD set is around $350 now. Treat yourself to a new one.
Jan 01, 2011 | Sony FD Trinitron WEGA KV-27FS120 27" TV
Hi i have lost instruction manual for my total remote urc 11-4110 b02 Universal Remote could you tell me how to code it to tv manually please
@font-face { font-family: "Cambria"; }p.MsoNormal, li.MsoNormal, div.MsoNormal { margin: 0cm 0cm 10pt; font-size: 12pt; font-family: "Times New Roman"; }div.Section1 { page: Section1; } SET UP
TV
The Search Method
If your device does not respond to the TOTAL CONTROL after you have tried all the codes listed for your brand, try searching for your code. The Search Method allows you to find the code for your device by scanning through all the codes contained in the memory of the TOTAL CONTROL.
To search for your TV code:
1 Switch your television on (not on standby) and aim your TOTAL CONTROL at your TV.
2 Press the TV key on your TOTAL CONTROL.
3 Press and hold down SET UP until the red light blinks twice. (The red light will blink once and then twice)
4 Press 9 9 1. The red light will blink twice .
5 Now slowly, alternate between POWER and TV, over and over, until your television turns off. You may have to press these keys many times (up to 150!), so please be patient.Remember to keep pointing the TOTAL CONTROL at your television when you press these keys.
6 As soon as your television turns off, press SET UP.
The TOTAL CONTROL remote should now be ready to operate your device. Turn your device back on and try all the remote’s functions to ensure they are working
properly. If some of the TOTAL CONTROL’s commands are not operating correctly, try the search method again. You may be using the wrong code.
Once you have Set-Up your TOTAL CONTROL, you can blink back your SET-UP CODE for future reference.
Example: To blink out your Television code:
1 Press TV once.
2 Press and hold SET UP until the red light blinks twice (The red light will blink once and then twice).
3 Press 9 9 0. The red light will blink twice.
4 For the first digit of your four-digit code, press 1 and count all the red blinks. If there are no blinks, the digit is "0".
5 For the second digit, press 2 and count all the red blinks. If there are no blinks, the digit is "0".
6 For the third digit, press 3 and count all the red blinks.
7 For the fourth digit, press 4 and count all the red blinks. If there are no blinks, the digit is "0". Now you have your four-digit code.Make sure you write your Television code for easy future reference.
Aug 12, 2010 | Televison & Video
Missing Code
Try this : If your device does not respond to the remote control after trying all
codes listed for your brand, or if your brand is not listed at all, try
For example, to search for a code for your TV:
1. On the remote control, press TV once.
2. Press and hold SET until the LED (red light) blinks twice, then
release SET.
3. Enter 9 - 9 - 1.The LED will blink twice.
4. Aim the remote control at the the TV and slowly alternate
between pressing POWER and TV. Stop when the TV turns off.
NOTE: In the search mode, the remote control will send IR codes from its
library to the selected device, starting with the most popular code first.
5. To lock in the code, press and hold SET until the LED blinks
twice, then release SET.
6. To search for the codes of your other devices, repeat steps 1
through 5, but substitute the appropriate device key for the
device you are searching for.
Sep 14, 2009 | One For All URC-6011 Remote Control
Can I use the Smart Remote 15-2104 for a Cyberhome DVD Recorder?
The product manual doesn't list the Cyber home product. You might want to try a code scan, that might turn up a code set that is close. Here are the instructions:
USING MANUAL CODE SEARCH
If your home entertainment device does not respond
to remote control commands after trying all of the
codes listed for your brand, or if your brand is not list-
ed, try searching for your code.
Follow these steps to search for codes manually.
1. Turn on the desired device.
2. On the 6-In-One Remote, press the appropriate
device key once.
3. Hold down P until the red light blinks twice.
4. Press 9 9 1. The red light blinks twice.
5. Aim the 6-In-One Remote at the desired device
and slowly alternate between pressing POWER
and the appropriate device key. Stop when the
device turns off — a working code has been
found.
Note: In the search mode, the remote sends IR
codes from its extensive library to the selected
device, starting with the most popular codes.
Because of the library’s size, this procedure may
take some time. When the red light blinks three
times, the search of every code is complete.
6. Press P once to lock in the code.
Mar 20, 2008 | Radio Shack 15-2104 Remote Control
32PFL5232D/37
The code is 0081 and this is how you do it.
'4 digit' or 'Brand Set' method
1. Turn on your TV.
2. Press TV on your Sky remote control.
3. Hold down select and the red button together for about two seconds, until the red light on the Sky remote control blinks twice.
4. Press TV on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV. The light on the Sky remote control blinks twice.
If the light blinks once only, re check the code for your TV and start again at step 1.
6. Press the on/off button (power-top right button on your Sky remote control).
If your TV switched off, press select . The light on the Sky remote control blinks twice.
If your TV did not switch off, press TV , then press the on/off button. Repeat this (press TV , then on/off) until your TV turns off, then press select.
If the light on your Sky remote control blinks three times, your Sky digibox has checked all the possible settings for the code you used. Check that you have the right 4 digit code and start again at step 1.
7. Press TV guide .
If you see the TV Guide screen, the remote control setup process is complete.
If you did not see the TV Guide, you must now set the TV Guide function as follows:
8. Press TV on your Sky remote control.
9. Hold down select and the green button together for about two seconds, until the red light on the Sky remote control blinks twice. The remote control setup process is complete.
Mar 11, 2008 | Philips 32PF5320 32 in. HD-Ready LCD...
Sky code for remote
The code for you sky remote is 0125.
4 digit' method
1. Turn on your TV.
2. Press tv on your Sky remote control.
4. Press tv on your Sky remote control again.
5. Key in the Brand Set code for your brand of TV then press select. The light on the Sky remote control blinks twice.
If your TV did not switch off, press tv , then press the on/off button. Repeat this (press tv , then on/off) until your TV turns off, then press select.
7. Press tv guide .
If you did not see the TV Guide,you must now set the TV Guide function as follows:
8. Press tv on your Sky remote control.
10. Key in the number of the channel on your TV that you use for watching satellite TV (For scart switching, this may be one of the other buttons on your remote e.g. help, i or a colour button).
11. Press select on your Sky remote control. The red light blinks twice. The remote control setup process is complete.
Feb 13, 2008 | Televison & Video
No power
It sounds like the backlight or an inverter board on the television may have failed. Check your warranty status on the television to see if you can get it repaired by the manufacturer for free.
Sep 06, 2007 | Sony KDL-32S3000 32 in. LCD Television
Sony FD Trinitron WEGA KV-32FS120 32" TV Logo
48 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
