Question about Apple iPhone Smartphone
Iphone touch-screen My Iphone touch screen has stopped working and I am unable to calibrate touch screen - it just won't work. Whenever I select pen calibration and it takes me to the screen to perform function, when I click the screen with stylus nothing happens-it remains at that screen. Comment by Guest, posted on May 26, 2008 my iphone touch screen is not working.i am able to release the lock , but unable to access the menu or any of my contacts. This is my problem and I have been unable to locate the solution or answer that was given to the previous poster. Please respond with help----even if the help says; 'get a new one'! I need service to function in my work/life. Thank you, Bobby Cutsinger II bcutsinger@msn.com
  • Marccucci Jan 19, 2009
    After switching on my iphone when i try to enter my password some numbers do not work and some does! Even if i try and switch it on without sim it still gives me problems cause i can't use the touch screen as well!
    Your help will be apreciated
    C.Jay
    C.jay@webmail.co.za
  • Anonymous May 15, 2009
    i ha ve the same problem
    my model is I 9
    Sergeant:
  • 154 Answers
Sir whats ur model\????
Posted on May 28, 2008
How do enable my touchscreen?
This is one link that shows how in pdf (however if you provide your exact model and operating system, you can get a clearer answer) https://www.lenovo.com/shop/americas/content/user_guides/a720_ug_en.pdf
touch screen starts on page 12
2.1 Touch Screen Calibration Prior to first use or whenever the touch screen reacts in a different place where you are touching it, start the calibration program. The procedure is as follows: 1. In Windows 7, Select "Start" - "Control Panel". 2. In Control Panel, select "Hardware and Sound". 3. In "Hardware and Sound" window, select "Tablet PC Settings". 4. In "Tablet PC Settings" dialogue, click "Calibrate" button. 2.2 User Gesture Instructions for the Touch screen The Touch screen supports single touch and rotational movements, enlargement and reduction multi-touch operations, and the user can transmit position information to the computer via touch. The touch screen uses a very low pressure movement recognition method, which only needs the finger to move lightly on the computer display screen or make a simple hand gesture to be detected by the main computer processor.
Nov 24, 2015 | Lenovo Computers & Internet
Hi, I am having trouble with my LG Ku990i mobile phone, the touch pad calibration won't work & screen has frozen
Touch screen problem
If your touch screen is not working, there are just 2 major causes of such, either a hardware cause which might be either the phone falling on a hard object or in water which could damage the sensor board and either the screen is malfunctioning and needs to be calibrated.
If you can access the menu of the phone, i will advice you calibrate the screen first before you send it to a repair shop. There is no updates to download for such problem as updating the firmware of the phone would do nothing but change the settings of the phone.
To calibrate the screen, you will have to go to the phones menu, go to settings, then you select the calibrate screen, it will show you some stars to touch and once you touch them properly, then your screen will be able to work effectively.
But if you cannot access the menu because of the touch, then i will advice you send it off for repairs, and what to repair on the phone is the sensor board.
Hope this helps you.
Jul 13, 2011 | LG KU990i Cell Phone
Calibration is working on my iphone but only on the middle of the screen. the calibration is not working. could you please tell me how to fix the calibration or touch sensor on the screen,
Normally, such of these strange issues in iPhone get resolved by resetting the iPhone (by pressing the Sleep/Wake Button and the Home Button both simultaneously after which iPhone restarts slowly with the apple logo on the screen). Please try.
Oct 11, 2010 | Apple iPhone Smartphone
What should i do if my iphone touch screen won't work, i try to slide it to unlock it but nothing is happening
Try calibrating the screen. If that doesn't work, open the iphone and reseat the touch-panel connector. If that doesn't work either, replace the screen.
Oct 28, 2009 | Apple iPhone Smartphone
Touch Screen and Remote Problem
My remote stop working. I replaced the 2 AA batties by still does not work
Oct 31, 2007 | Garmin StreetPilot 2620 GPS Receiver
Messed up with garmin
(1) Disconnect any external GPS antenna. (2) Do not turn on auto engine. (3) Turn off any other peripheral devices. (4) Simultaneusly hold down the PAGE and MENU buttons while turning on the 2620. A prompt box will appear asking if you really want to delete all user data. Touch the NO selection. Then turn off the 2620. (5) Simultaneously hold down MENU & ROUTE buttons while turning on the 2620. (6) A self-running diagnostic program will appear. Allow it to run for a couple of minutes; check to see that all parameters indicate "PASS" or other indication of being OK. If any parameter is not OK, make a note of it for potential communication to Garmin, then proceed with the following steps (7) Turn off the 2620. (8) Simultaneously hold down the PAGE, MENU & ROUTE buttons while turning on the 2620. A SCREEN CALIBRATION adjustment screen will apear. Quickly touch the points indicated as the calibration program runs. At the end of this procedure, the screen will display a window indicating that the calibration either "PASSED" or "FAILED." If it "PASSED," continue to steps (8)-(9). If it "FAILED," turn off the 2620 and repeat this step. If, after three calibrations attempts, each one is "FAILED," then also turn off the 2620 and proceed to steps (8)-(9). (8) Turn on the 2620. Press the "OK" button each time prompted to do so. Wait for maps to load and for the 2620 to initialize, acquire satellites, and display your position. (9) Press FIND button, then touch the right-hand vertical screen position adjustment to scroll screen display down to reveal WAYPOINT selection box. If unable to select WAYPOINT, or if attempting to do so only selects an adjacent box, then repeat step (7), and return to this step. (10) When various waypoint selections appear, attempt to scroll down to a selection not visible when the list of waypoints first appears, and select one of them. If still unable to select WAYPOINT box, unable to scroll screen down (or if trying to do so selects a stored waypoint instead), once again repeat step (7). If successful,then proceed to step (11). Also proceed to step (11) if you have repeat step (7) but then still can't select WAYPOINT, can't scroll down after selecting WAYPOINT, or can't select a particular stored WAYPOINT. (11) Press the upper-right hand "X" to close out the FIND screen or sub-screen within that function. If unable to close the screen, press the PAGE button. (12) Press FIND button, and when selection screen appears, touch ADDRESS. On next screen, touch the STATE line and touch the ENTER A CITY in (name of state). When keyboard appears on screen, use it to enter your city, then touch OK. Continue this procedure to enter your house number and street name, then press "OK." If all screen keyboard keys not responding, repeat step (7), turn the 2620 off and on again, wait for it to initialize, and then attempt this step again. (13) Repeat this procedure several times if not initially successful. By the second or third run-through, the touch screen should respond fully and accurately. If, after many runs through this procedure, the touch screen still will not respond, the screen sensor probably will need to be replaced ($255). The foregoing procedure brought my touch screen back to life last evening, much to my delight. Do not be too concerned if the SCREEN CALIBRATION step does nto produce a "PASS;" on my third calibration attempt it produced a PASS but all of the touch screen points still had not returned to functionality. I was unable to get a PASS during the screen calibration step after that, but the many repetitions apparently nonetheless made the difference, as by patiently following the above prcoess for five cycles, full screen functionality was restored.
Sep 03, 2007 | Garmin StreetPilot 2620 GPS Receiver
Iphone touch-screen
Solution i tried on Unlocked 1.1.3 and 1.1.4 versions. Just follow the steps they have been explained really easy way. Dont think this is too hard. Just follow them it will work:
1) download WinSCP on your PC (google it) and run the application
2) download new general.plist file on laptop
3) download OpenSSH on your iphone (its not show on iphone but its there so dont worry)
4) connect the laptop and iphone through the same wireless network and both will have separate ipaddress.
5) write the ipaddress from the iphone (Settings>Wifi>network details to which you are connected to shows you the ipaddress)
6) Goto laptop on WinSCP type the ipaddress of the iphone in host name field and username:root and password: alpine and then hit Login.
7) it will open like an explorer view of your iphone files on laptop then click on root left side. Click Applications> preferences> replace the general.plist file with the one you downloaded. Done the major part.
8) unplug iphone click Settings> General>Touch and reduce the senstivity to 0. 0 gives you the highest touch sensitivity.
9) Now be happy it works....
Aug 18, 2007 | Apple iPhone Smartphone
IPaq won 't respond to screen calibration.
So far no fixes. It's just been collecting dust. I think it's a screen response issue, and will probably cost more to fix than to replace (at least for me) in my situation. I'm thinking iPhone....
Jul 08, 2007 | HP iPAQ RX3115 Pocket PC
Touch screen does not work.
Jun 18, 2007 | Garmin StreetPilot 2620 GPS Receiver
Apple iPhone Smartphone Logo
853 people viewed this question
Top Apple Cell Phones Experts
Lesley Cameron
Lesley Cameron
Ed Nelson
Ed Nelson
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
