Question about Brother HL-4050CDN Printer
Error Message: Fix Jam Tray 1 Remove jammed paper from Tray 1. Where is Tray 1? & how to remove jamed paper
Cops
  • 64 Answers
SOURCE: paper jam in tray 2
the most common problem for a paper jam in tray 2 is that either the pick up rollers and separation pads are worn or that there is something stuck to the rollers that transfer the paper up through to trat 1.(most commonly from if people have been printing on stickers/labels) just eyeball it to see if anything looks to be stook and try wiping it off. DO NOT SCRATCH IT OFF as this will only make things worse!!!
Posted on Oct 05, 2007
  • 2072 Answers
SOURCE: rx tray full remove paper
That is an easy one.
Look into the area where the paper comes out. You have to look toward the upper rear area rear area. There is a white plastic flag, about 2 inches wide and 1 inch in height.
On each side of it you will see 2 areas where the shaft snaps into, that flag has popped out of those clips and is not seeing the sensor making the machine think there is a piece of paper in the output tray.
Reach in and gently maneuver that back into position and carefully snap it back into place.
That is an odd shaped actuator you can't see, but with some patience you can snap it back into place. Maybe also gently take a pair of needle nose pliers and slightly tighten those clips that it snaps into. I suggest that with a lot of concern so that you do not snap the plastic clips, they are part of the frame that if broken would be expensive to replace. Use your discretion as to whether they need to be tightened. If it snaps back in and feels solid DO NOT try to tighten them please.
Posted on Jan 03, 2008
SOURCE: Paper jam Brother MFC-215C
Thanks, your suggestion led me to the solution, the jam not in the rollers or a senser, but it's in the dock of the printer head, when the printer head moved across, I shone a torch into the dock and saw a black thing, so eventually pulled it and realised that it was paper and it had been dyed black by the ink so that's wht it would be hard to spot!!!! Thanks again
Posted on Apr 29, 2008
SOURCE: paper jam, open back cover, then remove paper jam
Remove the paper tray. Check that the paper length adjustment is set correctly for the paper you are using. It's the small blue dam at the center 'back' of the paper tray.
Posted on Jun 25, 2008
Cops
  • 64 Answers
SOURCE: when i try to print anything, i get a message 241 paper jam,
this is most likely to be worn pick up rollers. these are the two rubber wheels that you can see underneath the printer when you remove the tray. you should be able to source these from a local suplier and are very easy to fit. just make sure your gentle with the clip that holds them in place as if they break then you will need to buy a whole new pick up assembaly which is significantly more expensive.
hope this helps
Pete
Posted on Nov 25, 2008
MP 640 paper jam message that wont clear
door. 3 Push down on the green lever. 24x Paper Jam, Check Tray 1 Gently open the ... Jam, Check MP Feeder Gently pull the jam straight out of the multipurpose feeder. 202 Paper Jam, Open Rear Door 1 Open the ... side to locate a green lever. Note: To clear the Paper Jam error message, you must remove ... above Tray 1 when the duplex function is in use. To clear this type of jam, follow the instructions under the appropriate paper jam message. Lever 4 Gently pull the jam toward you. 5 Insert the tray. Note: Make sure... under the print media is locked down. 23x Paper Jam, Remove Tray1, Pull Down ...
Jul 29, 2012 | Canon MP640 All-In-One InkJet Printer
HP 3005dn Printer Tray 1 paper jam error
If message in display panel reads [13.XX PAPER JAM [LOCATION]]Media is jammed at the specified location (and possibly at other locations). If the message persists after all jams have been cleared, a sensor or sensor lever might be stuck or broken.
Soln.
For all jam messages, do the following: 1. Remove jammed print media from the specified location. Check the entire paper path for other pieces of media in the path. 2. Open and close the top cover to clear the message. 3. Check sensors and flags in the paper path for proper operation.
For message 3.0 PAPER JAM [LOCATION]
means
A non-specific paper jam occurred.
Soln
1. Remove jammed media from the specified location. 2. Verify the paper tray is fully closed. 3. Inspect and/or replace the feed and separation rollers. 4. Ensure there is no obstruction in the path, such as a torn piece of paper. 5. Open and close the top cover to clear the message. 6. Check sensors and flags for proper operation.
For more help check yhis site
http://www.printertechs.com/tech/error-codes/error-codes-0-19.php
Nov 26, 2010 | HP LaserJet P3005n Printer
Paper Jam cleared but?
It sounds like the paper sensor in the paper try is broken or jamed. Remove the paper tray and locate the paper sensor. Check if it is jamed in the up position or if it is broken.
Jan 21, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
I have a samsung scx 4200 am getting the papaer jam error even when theres no paper jamed up there
Good Day Sir,
when paper jam occurs, Paper jam appears on the display.
Message Location of Jam
[Paper Jam 0] - In the paper input tray
[Paper Jam 1] - In the fuser area or around the toner cartridge
In the manual feeder
[Paper Jam 2] - In the paper exit area
hope this will help you. god bless
Nov 06, 2009 | Samsung SCX 4200 All-In-One Laser Printer
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
When printing paper continues to jam.
  1. Take out paper tray 1.
  2. Remove any jammed sheets of paper you find there.
  3. Once you have done this, reinstall the paper tray and try printing again.
    Note: You may receive a message informing you that another sheet of paper is jammed elsewhere in the printer. If so, please open the front door and remove the toner cartridge. Also open the rear door of the printer (and the duplex option if a duplex unit is installed). Remove any and all jammed sheets of paper you find. Then try printing again.
  4. If the printer jams again with a 241 Paper Jam error message, look to see if it has tried to feed a sheet of paper out of the tray.
Dec 16, 2008 | Office Equipment & Supplies
Lexmark t640: paper jam in the back door. I can see the edge of the paper. How do I release the tension on the rollers so I can slide it out? Now it is in there tight and to grab it just tears off a piece...
Hope this helps....
Explanation of the paper jam message
A 241.09 Paper Jam message indicates that the printer thinks a sheet of paper has jammed at the front of the printer. The jammed sheet of paper is most likely to be found in one of the paper trays or under the toner cartridge.
NOTE: If you select Show areas on the operator panel, you can view one or more images to help you locate and clear the jam.
Clearing the jam
To resolve the paper jam message, you must first clear the entire paper path. To access the jam area, you will need to open one or more of the paper trays. Follow the steps in the table below to help you locate and clear the jam.
Step Action Image 1 Open the printer paper tray (tray 1), and remove any jammed media you find there. pattlnk_10222007_1922-enus28872_24109paperjam1_t64x_en_us.gif 2 Open the front cover and remove the toner cartridge. Examine the area inside the printer and remove any jammed media you find there. pattlnk_10242007_159-enus28872_24109paperjam5_t64x_en_us.gif 3 If you have a duplex option installed, also remove the duplex access tray and remove any jammed media you find there. pattlnk_10302007_1559-enus28860_24x17paperjamduplex_t64x_en_us.gif 4 If you were printing from an optional paper tray, such as tray 2 or tray 3, open any optional trays, starting at the top, and remove any jammed media. Pull the print media either up or down. If it does not pull easily one way, try the other way pattlnk_10222007_1957-enus28872_24109paperjam3_t64x_en_us.gif 5 If you are printing from an optional 2000-sheet feeder, open the front door. Press the elevator button (A) to lower the tray. Remove any partially fed media from the feeder.
NOTE: Make sure the stack of print media is straight and pushed all of the way into the feeder. Incorrectly loaded paper is the most common cause of paper jams from a 2000-sheet feeder option.
For a larger image, click here. 6 Finally, reinstall all of the paper trays and press the pattlnk_10222007_2117-select_button.jpg button to try printing again.
NOTE: You may receive a different paper jam message informing you that another sheet of paper is jammed elsewhere in the printer. If this occurs, the error code will indicate the location. Click here for a diagram showing the error code locations. The paper path will vary, depending on the paper source and number of paper feed options installed.
Remove any jammed sheets of paper you find and try printing again.
Dec 12, 2008 | Lexmark T640 Laser Printer
Optra 2450 error 241
24X Paper Jam message displays, Paper jammed over the Pass
Thru Sensor. (The printer displays the value of X for the paper tray
where the error occurs. Example: 241 is a Paper Jam Tray 1)
That is a quote directly from the service manual. You have a paper jam, or some tiny bits of paper stuck over the pass thru sensor. Remove debris and clean out to fix your problem.
Thanks and please take a moment to rate as fixya.
Nov 10, 2008 | Lexmark Optra S 2450 Laser Printer
Brother HL-4050CDN Printer Logo
159 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
