Question about Coleman Roadtrip Grill LXE 9949-750
Cleaning How is the best way to clean the grills and the stainless parts? Sheri
  • 9 Answers
I've used a mixture of a degreasing detergent and baking soda.  With the two I make a paste.  The baking soda is abrasive enough to scrub the baked on food from stainless steel without scratching it.  The degreasing detergent cuts any left over grime.  You can use it in tandem with a plastic or nylon scrubber to loosen the larger bits.
Clean the solution off with clean cloth and water.
Posted on May 01, 2009
I have a one burner that doesn't ignite - what do I do?
Assuming the igniter to that burner is working properly, the best bet is that the burner is clogged an not getting gas. This will require removing the burner to clean it and the venturi valve (which is part of the burner), as it can become a haven for spiders.
Since removing the burners on a Ducane grill can be a bear to do. I have included a link to your Owner's Manual, in case you have misplaced yours, that you can download and print for future reference. Pay particular attention to the Annual Maintenance section. As it will walk you thru how to remove and clean the burners.
I hope this helps you and thanks for choosing FixYa. Happy Grilling!!
Jul 26, 2011 | Ducane 30400040 Stainless Steel Grill
I replaced the porcelain enameler flavorizer bars on my Weber genesis gas grll less than a year ago--four out of the five bars are bent and misshapen--no longer straight. Why??? They still look brand...
You are overheating the grill - make sure the thermometer is working on the right side of the grill lid. You should not heat above 550F (preheat) and you should not cook above 500F.
Secondly, you must clean out the drip tray (not just the aluminum foil tray but the bigger tray it is attached to (it slides out the front of the grill too). The grease that piles up on this tray can catch fire and overheat the grill (including the flavorizor bars).
Last suggestion is to get stainless steel bars next time (make sure you get the size that fits your grill because the stainless steel sizes also come a bit longer). The stainless bars are high temperature stainless steel and do not corrode. They are a bit heavier and cost about 30 to 50% more but well worth it. They clean up very easily and transfer heat to the cooking surface well. Keep them clean to keep the cooking surface hotter.
Jul 16, 2011 | Weber Genesis Silver B Grill
I want to clean the grill but cannot find the owner's manual to determine how to take it apart and clean it properly. How can I get a manual?
Here's a link to the Owners Manual for a Ducane Stainless Steel Grill, that may be a little newer than yours. Never the less, the maintenance and cleaning are the same.
Happy Grilling!!
Jul 15, 2011 | Ducane 30400040 Stainless Steel Grill
Should the flavorirzer stainless steel bars turn a color or should they stay the stainless color after cooking ?
No, they will not remain the same color, despite being stainless steel. The grease drippings coupled with the high causes the discoloration. The good part is that when properly maintained (cleaned regularly), they will not rust out. The discoloration will not affect the flavor of the food.
Hope this answered your question? Happy Grilling!!
Apr 17, 2011 | Weber Genesis E-310 Gas Grill
Cleaning product
Use DeBruce Polish, we use DeBruce Polish on all of our stainless steel. DeBruce Polish also works on glass cook tops. We get DeBruce Polish at
Apr 18, 2010 | Coleman Roadtrip Grill LXE 9949-750
Clean stainless steel grates with wire brush
wire brush, heat up grill to warm and clean with wire brush. After you get the built up food and grease off remove grates and clean with soap and water to finish the job.
Sep 03, 2009 | Grilling
Cleaning the grill grate
The best thing to use to clean the grill grating is a brass brush these may be bought at most hardware stores and even wal mart.
Jun 07, 2008 | Weber Q Grill
Coleman Roadtrip Grill LXE 9949-750 Logo
509 people viewed this question
Top Coleman Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Coleman Grilling Expert? Answer questions, earn points and help others
