Question about Sony Televison & Video
Tv lost picture and sound while playing. The green power light flashing. This happen almost every few minutes. Then the picture and sound come back after 10 to 20 seconds and the green power light back to steady.
  • 2 more comments
  • calupad1 Oct 05, 2010
    Here is the Model #KDF-50WE655. I hope this help.
    Celestino Calupad
    I have one question. Why is lamp the reason for my problem? I thought by reading the manual, lamp only need replacement when the picture becomes dark.?
    Anyway, I will go ahead and read the manual and see if I can do it yourself replace the lamp. When i am ready I'll buy the lamp.
    Thanks
    One more info I read in the Manual when the lamp needs replacing. It says the lamp needs to be replaced when the indicator on the fornt panel blinks in red. My problem, the indicator on the front panel doesn't blink in red, but blinks green.
    Thank you. I'll go ahead and replace the lamp.
  • 10,594 Answers
I need model number of your Sony tv to confirm its problem, apparently it seems lamp problem that has been reached to end of its working life and requires replacement.
Let me know model number of tv to provide you more info.
Thanks.
Posted on Oct 05, 2010
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics Oct 05, 2010
    Yes, KDF-50WE655 is valid model number that help very much.
    TV needs lamp replacement.
    If lamp has not been replaced in last 2-3 years then its time to get it change.
    Lamp replacement procedure is easy and written in user manual, click Sony Support link to download related user manual copy if required.
    Required lamp part number is as follows:
    A1606034B...
    LAMP BLOCK XL-2100U
    Please buy Sony original lamp for bright and good picture.
    Thanks.
    lamp available in Sony Accessories Store for $200
    Yes, its good question and I will happily answer it.
    Manual discuss dead/ broken lamp and tv will show lamp light on front but weaker lamp that is still not dead nor broken will act as you seen it in tv.
    Replacement of lamp will solve your tv problem, I been replaced many for said problem because I'm Sony qualified tv tech :)
    As I mentioned before, broken or dead lamp can blink lamp light on tv front.
    Your tv is just fine and has no other problem except weak lamp.
    No problem, I will wait good news that tv is OK
Tv shutdown
check your lamp door interlock switch.
Jul 31, 2010 | Mitsubishi WD-65733 65" HDTV
Flashing green light
Did you try this yet
SYSTEM RESET
If the TV will not respond to either the remote control
or the front panel controls and/or will not power Off,
press the SYSTEM RESET button with a pointed item
like the end point of a paperclip. The TV will turn Off
and the TIMER light will flash quickly for about one
minute. When the TIMER light stops flashing, you may
turn on the TV again. Changes you made the last time
the TV was On before you used the SYSTEM RESET
button may be lost, however, the changes you made
previously are not lost.
POWER/TIMER Indicator
The green light is a multi-function indicator. This light
will flash rapidly for about one minute each time the TV
is plugged into the wall electrical outlet, when power
is restored after a power failure, or using the SYSTEM
RESET button. Do not attempt to turn on the TV again
during this period. Wait for the flashing to stop and
the light to turn off, before attempting to turn the TV
on. While the TV is powered on, the light illuminates
steadily. If the TV has been programmed to turn on
automatically using the Timer feature,
Sep 21, 2009 | Mitsubishi WS-65515 65" TV
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Sound and picture on and off green light blinks
1st try this....unplug tv...hold power button for 10 seconds...wait 2 minutes....plug back in, if this doesn't fix it you probably need to replace the lamp
Jul 13, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Picture gone
Is the set completly dead...does the green light flash then go off. or when you plug it up does it come on for a moment?
Jan 02, 2008 | RCA HD52W56 52" Rear Projection HDTV
Flashing Green Light on Front of 73" Projection TV
on the signal board replace the caps by the 5/9 volt regulators. c2p04 is the main culprit. 6 caps in total can be changed. I believe c2p05 also.
Oct 12, 2007 | Mitsubishi VS-50707 50" Rear Projection...
Continueus green flashing light
i have seen weak lamps do this. this would also be the first thing the servicer would replace. worse case scenario you would have a spare lamp on hand...
Oct 11, 2007 | Sony Grand WEGA KDF-60XS955 60" Rear...
Sony FWD50PX2/S 50 in. Plasma Television power problem
It does sound like a power supply problem but that can be misleading because a problem somewhere else in the TV can be "holding down" the power supply. This can usually be determined by using some isolation techniques.
Aug 08, 2007 | Sony FWD50PX2/S 50 in. Plasma Television
TV Picture Goes Black
I had the same exact problem.
I removed the bulb and cleaned it. There is a small screen at the top of the bulb and it was covered with dust. Once it was cleaned I replaced the bulb and it solved the problem.
Thanks to those who posted the solutions
Jul 28, 2007 | Sony Grand WEGA KDF-60WF655 60" Rear...
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Televison & Video Logo
52 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
