There is a break in the inner cable somewhere. have the flex replaced or if the break is near the connection to the vac get it refitted removing the faulty section. Get a competent person to do this !
HI jLAFORCE 1. Other possible causes include: Loose, Dirty or Disconnected Spark Plug in Your Lawn Mower: Check it out, clean off debris, re-connect and tighten. Fuel Not Reaching the Engine: Tap the side of the carburetor to help the flow of gas. If this doesn't work, you might need a new fuel filter.
The motor running slower was the motor starting to burn out. The "almost start" is the brushes making intermittent contact with the armature in the motor.
Your machine needs a new motor Pam.
Start by checking to insure you're getting proper voltage through the cord. Make sure the bag emptor and front brush roll nozzle are installed properly as each must activate the switch for it to run. It could have a defective switch.
