Question about Samsung SyncMaster 931B 19" LCD Monitor
The power light just flashes very slowly, and the screen is black
  • 11,361 Answers
Inspect the caps in the power supply section first.
If you are going to DIY and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Posted on Oct 05, 2010
No video no picture, caps look okay, what could be wrong or how to tshoot to determine which PCB is bad etc
Does the screen flash on briefly then go black when first switched on? See my posts in march for my answer to this fault.I traced the same fault on my own tv down to a faulty led in the backlight strip. Also my tv did the same thing,standby light flashed twice and then went out.Hope this helps
Feb 21, 2015 | LG 47LV5500 47-Inch 1080p 120Hz LED TV...
Work all days yesterday, this morning went out to van, got to work and it would not move, lights come on flash but will not move
The code 6 failure code is the toggle throttle [engager] isn't in the neutral position when power is applied to the scooter. If the engager doesn't return to the neutral position as soon as you turn the key on the scooter would start to move, that woul
Engager
1. Check connections on red, white and black wires at crimps and soldered joints. (Flash Code
7)
2. Use meter to check for:
- White & Red: 5k1 + 10%
- Red & Black: 2.5k1 (approx.)
- White & Black: 2.5k1 (approx.)
3. With meter between Red & Black, squeeze engager forward. Resistance should go from 2.5k
down to 01 smoothly.
4. With meter between White & Black, squeeze engager reverse. Resistance should go from
2.5k down to 0 1 smoothly.
5. Check voltages (with key on):
- Forward - Red- 4.5V + .1V
- Neutral - Black- 2.5V + 0.1V
- Reverse - White - .5V +.1V
If using a Test Harness - White & Red: 5k, Forward - Red & Brown: 2-5k, Reverse - White &
Brown: 2-5k.
1. Use Red & Brown squeeze engager slowly forward 25 down to 0 slowly.
2. Use White & Brown squeeze engager slowly reverse 25 down to 0 slowly. Make sure dial
speed is set to10.
Jul 25, 2012 | Pride Jazzy Select Gt Scooter
Screen black. Power light on unit flashes red slowly. Power light on switching adaptor power supply flashed green slowly.
Sounds like the battery might be low which would cause the red flashing light and dark screen. Let it charge for a little bit then try turning it on again. If it still does it with the power supply plugged in, make sure there isn't a lens cover on it, and switch modes or try getting into the menu to see if you can get anything to come up. If that still doesn't work then it sounds like there might be a problem with the camera.
May 03, 2011 | Cameras
MAG innovision LT-926W 900W problem! After I turn on my computer, the screen immediately begins to flash and then goes black. The power is still on thought and so is my computer. If I take a flash light...
this means your power inverter inside the monitor is dead. This little gizmo lights up the monitor backlight. They dont fail all at once, but slowly die and give problems like you describe, you can order these online for your monitor , or find one on ebay for under 30 dollars, but unfortunately there is no fix, other than replacing the inverter. sorry. Please use the thumbs up rating if you find my answer helpful, albeit bad news. Take care. .
Aug 26, 2010 | Mag Innovision LT576s 15" Flat Panel LCD...
Screen is black tv wont come on, power on lights flash
Replace Lamp ,Go to E-Bay lamp number is BP96-00224c, I just got one for $85.00.
Aug 20, 2009 | Samsung HLM5065W 50" Rear Projection...
OPC/DL light flashing Same problem of black screen and green lights flashing at power and OPC Help....
WHEN FLAT SCREEN SHARP LCD IS ON .. BLIKNING ON BOTTOM OF SCREEN SAYS OPC
Dec 08, 2008 | Televison & Video
Monitor blank
try to start your pc in safemode with vga mode with thjis faulty monitor
hope you know how to do it
start pc (powerr on)
then continuously press F8 key then it will show you boot menu
select safemode with command prompt
then if it show desktop on screen this means your monitor is having problem with resolution try to downgrade your monitor's resolution
rightclik on desktopgo to properties
select settings
here you can find screen resolution make it to 800X 600 just for one time
then restart your pc it will auto select proper screen resolution
Mar 29, 2008 | Dell E173FP (Black) (Dark Gray) 17" LCD...
Philips 30PF9946 D/37
You have sound but no picture. Green power light is on and NOT flashing. You get a screen flash or flicker on power-up or even a minute of screen before going all black. It is your inverter board. Common problem on LCDs (maybe more so on Phillips?). They are easy to replace (unplug-plug) and are available on the net.
Veritas
Feb 24, 2008 | Philips 30PF9946 30 in. HD-Ready Plasma...
Samsung SyncMaster 931B 19" LCD Monitor Logo
54 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
phoenix chi
phoenix chi
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
