Question about Robin Subaru R1100 Portable Power 1100 Watt Generator
I have a robin engine with a rruning problem it starts up and runs fine for about two to three minutes then shuts off you can choke it and pull it once and it will start right back up and do the same thing. the fuel is clean and so is the air filter the carb is getting plenty of fuel just wont run for long under a load or not it is a presure washer 265 cm 4fjxs2652ga ex270000500216316 9.0 horse power ex27
  • jmacl9518 Oct 06, 2010
    no this was not the problem this is a power washer not a generator.
  • jmacl9518 Oct 10, 2010
    the oil level is where it should be un pluged the oil sensor same problem.
  • 1,041 Answers
The problem you are describing sounds a lot like the link I'm sending you. Even though it's not for generators,it still may e the problem:
www.fixya.com/support/r6081786-trimmer_weed_eater_only_runs_10_15
Good Luck!
Jim
Posted on Oct 05, 2010
  • Jim Parker
    Jim Parker Oct 06, 2010
    Have you checked the oil level? It must be full. If the oil level is where it should be, then you may have to replace the oil sensor.
    Jim
Power mate 6250. Starts and runs fine until I take the choke off, then why does it die?
Coleman engine starts runs short time quits Power ... - Fixya
www.fixya.com > ... > Power Generators
Coleman Powermate 6250 only runs with choke closed/air restricted ...starts and runswith full choke, but dies with choke off. ... some gas in the cilinder through the plug hole)and start the engine until it runs constantly. bestregards ... Ad ... I use a fuel stabilizer ... ...engine runs fine but produces no power at all to the breaker.
Coleman car starts but will not stay running Power ... - Fixya
Question about Powermate Premium Plus 6250W Portable Generator ... squirt a little gas in the carb it will run until gas is gone doesnt seem to get gas from . ... ...starts and runs fine for about a minute, then dies as though starved for fuel. ... load up on fullchoke and stay running around 3/4 choke HI, Turn off the gas and take ...
Generator runs then shuts off - YouTube
? 8:17
https://www.youtube.com/watch?v=6esHkPyygWw
Sep 6, 2011 - Uploaded by mainblind
How to make Generac generator run bypassing the low oil sensor and ... Remove all; Disconnect .... My ...
Jan 13, 2016 | Coleman Electrical Supplies
Reliant Robin stalls when going up hill. Float bowl seems fine. Any suggestions? Engine starts fine, runs great at idle....
it sounds like the fuel pump is lazy i would replace it ,i take it that it runs fine when going downhill.
Oct 18, 2015 | 2009 Piaggio MP3 Three Wheeler 400
Robin Subaru EX40 engine will only run at idle. Increasing the throttle causes it to stall.
Try blowing your gas line out.. sounds like your getting gas but not enough
Oct 13, 2014 | Motorcycles
Robin Subaru (14 hp) engine will only run at idle. Increasing the throttle causes it to stall.
I had a similar problem on a weedeater one time, have you checked the exaust for a blockage?
Oct 12, 2014 | Motorcycles
Acts like the choke is stuck closed it won't stay started and runs ruff until engine warms up then its fine. What do i do?
Well the choke has an electric part that heats up and makes the choke open in a few minutes. As soon as the engine starts the choke should open about 25 percent by way of a vac pull-off.
You can take the air cleaner off and watch the choke while someone starts the engine cold. If the choke does not open after it starts, check the choke pull-off. You can also open the choke with a screwdriver to see if the engine clears up.
Jan 29, 2013 | 1987 Chevrolet Caprice
Lt1050 black smoke after 15 minutes
The black smoke and black spark plugs indicate that the engine is running very rich (ie too much fuel). This could be caused by the choke not opening fully after the engine starts and the fuel mixture is too rich OR the fuel mixture setting is opened too far.
Check the choke lever, make sure the choke is fully open when the choke is in the running position.
When the engine is running with the throttle is in the 3/4 rev position then adjust the fuel mixture to get the highest RPM.
Apr 19, 2012 | Cub Cadet Garden
How to start the generator
Hi Joe, I had asked for a little clarification and have not received any information. I will answer this question based on the generator is in good working order and it is a recoil start. Open the petcock, (this is the fuel valve) and give it about a minute to fill the fuel bowl on the carburetor. If your generator has an engine an on/off kill switch, set to on. If the generator has an auto idle switch set it to off. If the engine has a throttle lever located under the carburetor, push it all the way down (full throttle). Pull the choke knob out completely, there is a detent on the choke for half choke, pull it past this for full choke. pull the recoil starter rapidly. As soon as the engine starts running push the choke knob to half choke, this will allow the engine to run smooth while it's warming up. Depending on the climate that you are in, warm up time will vary. After a minute or two in cold climates start pushing the choke knob in, if it starts to run poorly pull it back out too the half position and let it warm up some more. When you can posh the choke in without the engine faltering it is ready to go. In warmer climates you might be able to start the engine without the choke or in the halfway position. Robin Subaru makes some of the finest small engines available. I would choose a Robin over a Honda every time. I hope this gets your generator going, and once again this is based on the generator being in good working order. Good luck, Michael Burke.
Dec 03, 2011 | Coleman Powermate Subaru 5000W Portable...
My 9N is having trouble starting. It turns over fine but seems to be flooding. When it finally sputters to a start, it takes a while to run smooth. Also the idle seems to be fast and there is no change in...
Shut off fuel to carburetor, drain carburetor. Open fuel and count to three then shut off fuel. Crank engine then pull choke for 1 second then push in. If engine starts open fuel valve at tank. Also try lowering float level in carburetor. Good luck.
Jun 26, 2009 | Ford 8n,9n,2n, Tractor Starter With Drive
Open Questions:
Robin Subaru R1100 Portable Power 1100 Watt Generator Logo
1,181 people viewed this question
Top Robin Subaru Electrical Supplies Experts
Jim Parker
Jim Parker
John Trevino
Bill Boyd
Are you a Robin Subaru Electrical Supply Expert? Answer questions, earn points and help others
