Question about Intel Motherboard
Problem of Window XP installation
28th May 2008
Dear Mr. Mellomania,
Thanks for a prompt reply and nice interactions.
As recommended by you I have reformated the C drive of hard disc and started loading Window Xp professional service pack-2. After copying all files when window installation was in progress following message appeared and Comp shut down :
QUOTE :
"A problem has been detected & window has been shutdown to prevent damage to your computer.
IRQL_NOT_LESS_OR_EQUAL
If this is the first time you have seen this stop error screen, restart your computer, if this screen appears again follow these steps
Check to make sure any new hardware or software is properly installed. If this is a new installation ask your hardware or software wanufacturer for any windows update you might need.
If the problem continue disable or remove any new install hardware or software disable BIOS memory options such as caching or shadowing. If you need to use safe mode to remove or disable component restart your computer, press F-8 to select advanced startup option and then select safe mode.
Technical information
*** stop: 0X0000000A (0X408CE160, 0X00000002, 0X00000000, 0X80818652)"
UNQUOTE
Following are the difference in the message on monitor on 26th and 27th May 2008
On 26th May before formate :
PAGE_FAULT_IN_NON PAGED_AREA
and after reformate on 27th May 2008 the message displayed was :
Kindly give me further advise
S C Rawal
  • 121 Answers
Usually when installation of windows fails is from more than one reason and lets hope that ur hard drive is not damaged (contains bad sectors).
try these steps :
1- use a different windows cd and a different cd rom if u can find one.
2- change the sequense of drives by changing their jumper positions and data cables ( master, slave)
3- try to clear cmos with the jumper located usually near the mainboards battery (short it for 3 seconds)
4- try ( low-level format) to ur hard drive and reinstall windows.
if the message is still seen then your hard drive could be seriously damaged.
Posted on May 28, 2008
My Defender pro 2012 want install
what is it if its purchased in 2008 and it a 2012 version ?
how is this possible will need more information or clarity on problem
post a reply
hope it helps
May 15, 2012 | Take 2 Interactive Defender Pro 5-in-1...
Error 2738
Please clarify and also what is the brand and model of your pda?
Sep 28, 2008 | Computers & Internet
My laptop comes on but the only thing that happens is the screen is black can only be started in safe mode to see anything
The window is corrupt, You need Window fresh installation. Do you have genuine window Xp cd, if you have window xp cd, then reply me back. I will send you an instruction on how to install Window Xp. Thanks.
Jan 19, 2011 | Computers & Internet
C language is not running in full screen mode
Windows Vista takes away a lot of support and convenience for the sheer attractive of flashy user interface. One major feature is the ability of open full screen window for command prompt shell in Windows Vista. When you attempt open or run DOS .com applications, .bat batch scripts or games that relies on command prompt, and including cmd.exe itself, you will encounter the following error message:
This system does not support fullscreen mode. Choose “Close” to terminate the application.
The lack of support for full screen DOS command prompt in Windows Vista is a big annoyance especially for those who still playing games for DOS and Windows 3.1/9x era, use legacy software such as WPDOS or programmers who frequently switch to command prompt to use DOS based programming language such as PASCAL.
There is no simple solution to this no support for full screen window in Windows Vista. In almost all possible workarounds, you are almost guaranteed that your Vista will be broken in some way, at least on the part on Windows Aero. You will lose the nice Aero Glass interface if you attempt any of these trick, plus other unknown side effects.
Workaround to Run or Open Full Screen Window Mode
Workaround 1: Use XDDM driver instead of WDDM driver for video graphics adapter
In another word, install the Windows XP video card driver for use in Vista. If the video graphics card hardware supports Windows XP driver, you can download the Windows XP driver for your video hardware and install it under Vista. However, be warned that using XP driver on display adapter may crash your Vista system randomly, so save your works before proceeding and use with care.
Note: This solution has been recommended by Microsoft in KB926657.
To install a Windows XP video driver under Vista, just follow the procedure listed in the guide below. The steps should work for both NVIDIA and ATI video graphics accelerator card.
Download the Windows XP driver installer for your graphics card from NVIDIA or ATI. Run the installation setup program just downloaded. Confirm any User Account Control permission warning when prompted. The installer will first extract and unpack the files required by installation to proceed to a folder/directory. Note down the path to the folder. For ATI, the folder for these installation files usually located in a directory with a name that resembles C:\ATI\SUPPORT\7-5_xp_dd_46743\Driver or C:\ATI\SUPPORT\7-5_xp_dd_ccc_wdm_46743\Driver, with the only different been the number to indicate the version and build number of the driver
Jul 31, 2009 | Computers & Internet
How to install window xp on dell laptop
1.You need the disk
2 insert it into the cd/dvdrom
3. reboot
Follow the prompts..
if its not booting from the CD/DVD you need to set it in the bios the boot order to the CD/DVD
Thanks
Apr 23, 2009 | Dell Inspiron 1525 Notebook
Cannot login to configure Belkin SMB KVM-over-IP swith
This happened to me until I installed the activeX control. Were you prompted for that, and did it install successfully?
After the activeX installed, did it also prompt you to install the secure certificate to access the site without IE prompting about invalid certificates?
Since you've tried multiple machines, I doubt security settings on IE are causing the problem. But my switch did these two actions before I was able to login successfully.
Jan 30, 2009 | Computers & Internet
How to uninstall Adobe 8
Select [Start} then [CONTROL Panel] then select [add or remove programs] ..find ADOBE and select it, then choose REMOVE program.. that should remove that software correctly. Please get back to me if that fails to work for you..
Sep 25, 2008 | Computers & Internet
28th tele pest codes
This is 28th July 2008 time: 14:35
KEY 00 7E 42 DC 21 A5 C2 98
KEY 01 F4 9D B7 BC B1 09 98 06 new today
Jul 28, 2008 | StarTech.com StarView SV211K 2-port KVM...
Problems in Downloading & installation of Driver 640c.
Hi Deepak,
I think you have downloaded the driver for windows XP 32 bit OS, and i think that your PC supports Windows XP 64 bit Operating System.
Click here to download the software for Windows XP 64 bit Operating System.
DOWNLOAD (x64Drv5.64.0.17.exe)
Installation Instructions: USB Connection
1. Download the x64Drv5.64.0.17.exe file.
2. Once downloaded, choose Open or just run the x64Drv5.64.0.17.exe.
3. Follow onscreen instructions listed below.
Note: There may be a long pause between each of the steps below.
4. Choose Direct Connect.
5. Power on the printer, and connect it to the computer when prompted.
6. The "Found New Hardware Wizard" will be displayed.
7. Select No, not this time.
8. Select Install the software automatically (Recommended).
9. Depending on your product, you might see one or more Windows' warning screens.
10. Click Continue anyway or Yes each time these Windows warning screens appear.
11. Click Finish.
12. Reboot your computer (Highly Recommended).
Installation instructions: Wired and Wireless Network
2. Once downloaded, choose Open or just Run the x64Drv5.64.0.17.exe.
3. Follow onscreen instructions listed below:
4. Choose Network.
5. Choose your printer after the installer has identified it on the network.
11. Click Finish.
Thanks
Rizz
Jul 26, 2008 | HP DeskJet 640c InkJet Printer
Windos installer..
Go to RUN in the start up and enter command 'msconfig' it will popup an window, select startup tab and unchack the programes which is not requried.
Feb 26, 2008 | Microsoft Windows XP Professional With...
Intel Motherboard Logo
103 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
