Question about Whirlpool RF365 Electric Kitchen Range
Part number for lower heating element on RF365
  • Whirlpool Master
  • 3,051 Answers
Hello there:
Here is the info and a pict for you this is from repair clinic.com all you have to do is enter the model number you supplied to me and the parts list is listed for this oven
Item #
1028468 Price
$50.15 In Stock?
Yes Oven bake element assembly with push-on terminals
Recommended related tool(s): 1164336
Posted on Oct 05, 2010
Why is my oven not heating properly? After a loud POP! and a tripped circuit breaker, the oven does not heat properly. I suspect the lower heating element is not functioning although the top element
Does your lower element light up when it is heating? If not, time for a new element which is really easy to install - you pull it straight out and then install a new one. With the make and model number you should be able to easily fine the right element online.
Jan 09, 2018 | Kitchen Ranges
Oven won't heat, all burners work
I suggest that you remove the upper and lower heating elements to the oven, turn the oven switch to on, then use a good digital voltmeter, and check the plug that the lower heating element was in. If you have good (200 volts or more) then purchase and install new heating elements. Turn the oven switch to Broil setting and check the same way for the top heating element.
May 09, 2011 | Maytag Kitchen Ranges
How do you replace the heater coil on this unit
First of all you did not even begin to mention a model number. They are not all the same. Having said that the concept of changing a heating element is pretty much the same for those with through the lower tub mounts.
1. Turn off all power to the unit
2. Open the lower kick panel
(It is usually in 2 pieces) The top piece being fixed and the lower piece being adjustable to the floor. Remove BOTH panels.
3. Locate the 2 heating element terminals that pass through the bottom of the tub and disconnect the wires.
4. Losen the retaining nuts on the heating element. Push up on the elment to make sure it is free before totally removing the nuts.
5. Remove the nuts and then lift out the old element by opening the door and lifting out the element.
6. Note the position of seals and washers on the OLD element
7, Assemble the new element with the tub side seals and washers. Leave the under side washers off until after you place the new element in the dishwasher.
8. Install the underside seal and washer then install the nuts loosely.
9. Check the position of the element inside the tub. (Align as necessary)
10. Tighten the heating element retaining nuts on the under side of the tub. (DO NOT over tighten as you can damage the element.)
11. Install the 2 heating element terminals makeing very sure the connections are TIGHT. A loose connection will cause the new element to fail prematurely.
12. Connect power and test for leaks.
13 Leak test complete install both lower kick panels.
Task Complete!
Thanks for choosing FixYa,
Kelly
Oct 04, 2010 | Kenmore Dishwashers
Replace heating element for Duet Dryer GEW9200LW1
First disconnect the power to the dryer by unplugging it from the wall. Then remove the 3 screws on the lower panel of the dryer. This should expose the heating element in a metal housing on the right side of the dryer. Disconnect the 2 wires going to the heating element and slide it out of the housing. The heating element part number is 3387747.
May 25, 2010 | Whirlpool GEW9200L Electric Dryer
Lower heating element will not heat up
check the element for continuity if there is continuty on the element then you need to replace the electronic control. you can also take the two wire from the bake element and move them up to the broiler element and try to turn on the broiler using the bake button this will confirm bad board or element.
make sure to unplug the unit will doing the wire change and then plug it back in
Mar 13, 2010 | Whirlpool RF365 Electric Kitchen Range
My oven is a la germania f6 50 l2x i want to know the meaning of the symbols on my oven
Oven functions
Oven light.
Upper and lower heating elements.
(Conventional cooking).
Upper and lower heating elements with fan.
(Fan assisted cooking).
Lower heating element with fan.
Inner grill heating element.
(Radiant grill).
Full grill heating element with fan.
(Fan grill)
Rear circular heating element with fan.
(Fan forced cooking).
http://www.sampfordixl.com.au/lagermania/specs/f969d5x.pdf
Oct 10, 2009 | Ovens
Lower heating elements on double oven will not work
This is most likely your control board is bad. Give us a call with your brand and your model number and we will send the correct part out to you right away! We hope this gets you going before the upcoming holiday season.
Oct 09, 2009 | Ovens
Need part number for lower heating element in a JBP26 oven
That doesn't appear to be a complete serial number. You can go to repairclinic.com and click on repair help, or go straight to this page: http://www.repairclinic.com/0089.asp?apptype=13
to find the correct serial number.
Jul 20, 2009 | GE Spectra JBP78 Electric Kitchen Range
Electric Oven doesn't cook evenly
back plate inside oven may be distorted or some of the vents blocked with crud
Mar 13, 2007 | Whirlpool RF365 Electric Kitchen Range
Whirlpool RF365 Electric Kitchen Range Logo
94 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Ismael Rodriguez...
Sal De
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
