Question about Canon DR-7580
Canon dr-7580 error 32
  • 490 Answers
According to the service manual if 6080 and 9080c cpu/motherboard are interchanged this appears.
Posted on Nov 01, 2010
Canon dr-6080 getting an error a01 and won't feed paper?
As per the manual it is "In the event of a pick-up error, the document
was fed to the front registration sensors." Clean all the Sensors and try. Use isoproyl alcohol only.
S. Mohan, India
Oct 28, 2013 | Canon DR-7580
Canon dr 7580 error code E30
E30 is a Error related to Exhaust Fan. Pls check if the Fan is working, replace if required. If the scanner was used in a dusty environment, the dust can clog the free movement of the blades. It may require cleaning.
S. Mohan, Chennai, India
Nov 18, 2010 | Canon DR-7580
Canon dr 7580 erroe 32
If the main board (CPU PCB) not installed properly you get this error.
S. Mohan
Oct 11, 2010 | Canon DR-7580
I have a canon dr-7580 with a P00 error. I've blown it out but no paper found. what next
Use Qumatool to check if all the sensors are working okay. Normally sensors dont fail, there must be a small piece of paper (like the 'dot' of pre-printed stationery) sticking somewhere.
S. Mohan
Aug 31, 2010 | Canon DR-7580
Canon dr-7580 scanner how to initialize cis
If the Black lines are jaggered and are vary in size with different levels of brightness, then most likely it is scratch on the glass. If the lines are sharp and perfect and does not change when different brightness is chosen, then it could be failure of CIS module (Try this under B&W mode). To the best of my knowledge there is no concept of initialising the CIS, you may need to clean the Shading sheet.
Apr 10, 2010 | Canon DR-7580
Canon Dr-7580 not scanning two sided.
Check if you have chosen the 'duplex' option.
S. Mohan
Jan 11, 2010 | Canon DR-7580
Scanner 7580 error P00
Clean the Scanner thoroughly and start doing your work with scanner.
Jan 15, 2009 | Canon DR-7580
CANNON SCANNER 7580...ERROR P00
Canon error numbers are logical! Error starting with 'P' is paper related. If there is already soem paper inside the scanner while inititalising, u will get this error. Check for shreds of paper in the paper path. (Error starting with 'C' is Cover and 'E' isn Engineer reqd)
S. Mohan, Chennai, india
305 people viewed this question
old marine
old marine
