Question about Car Audio & Video
Amp not working right
I need help with my amp. its an older amp. it is 1400 watts and the brand is magna audio. got it off ebay a long time ago. it would make my sony xplod p5 700 watt 12inch subs hit good but it started to make a fuzzy noise from the amp itself. when it is supposed to hit it sounds like i am running a 2 watt amp or something. i do not know jack about ohms and rms or any of that stuff. i do my own wiring and have been for 7 years now. please help.
  • 109 Answers
It sounds like it is just time to replace the amplifier. Sorry
Posted on Jun 07, 2008
Connecting a 3000wat amp to a 14000wat dual woofer car sterio
Connect the dual woofer coils in series = 4 + 4 = 8 ohms. The home amp is safe at 8 ohm load.
Aug 16, 2014 | Sansui Audio Players & Recorders
Hello im sorry but not speak english a litle, im need picture of power amplifier crate model spa-1200 made in u.s.a.fabricated for slm electronics,1400 ferguson ave. st louis mo. 63133 and not found...
Hi,here is the one upper version of it as "Crate SPA1400 model " 1400 watt Stereo Power Amp.they are identical ..
Hope this helps! Take care and please Remember to rate/vote and give me 4 Thumbs Up for me to continue for Helping out the Community :) Thanks
Crate SPA1400 Stereo Power Amphttp://cgi.ebay.com/Crate-SPA1400-Stereo-Power-Amp-/270771488929?pt=LH_DefaultDomain_0&hash=item3f0b3d08a1
Jun 25, 2011 | Audio Players & Recorders
How much does a jl audio 1400 watt cost brand new?
Prices range from £200 to £750. All depends on how many channels, what OHM it can tollerate and where you shop. Ebay usually has good deals on car amps brand new from independant ebay shops.
Hope this helps and please rate thanks
Mar 19, 2011 | Car Audio & Video
I have a boss rt645 2ch 1400 watt amp would this amp properly push a pair of 12 inch mtx terminators.
That all depends on the wattage of the subs. also the independance of the subs. If your amp is 1400 watt, maximum you want is 2 600watt subs. if your subs are higher you will blow your amp eventually as your amp isnt powerful enough to pump out to that level.You should never have your amp fully turned up to max, 80% is perfect and will not make your amp blow. Hense why you want your subs less than the max output of your amp.
Mar 04, 2011 | Boss AUDIO RT-645 2-Channel Riot Series...
I have a cvt12 kicker 400rms 2ohm, ssl 1400 watt amp, and a boss 2.0 cap. do i need a second battery for 1600 watt amp. the volts is real low even with the truck is on the highest it goes is 12.2 volts...
you shouldn't need another batter. You aren't going to be disipating that much power all of the time. Your 2 Farad capacitor will help when the amp demands a lot of current during large bass hits. Just a question though, you say you have A CVT12 which is rated at 400 ohms rms and you are driving it with a 1400 Watt amp. Does this strike you as odd?
Jan 11, 2010 | Car Audio & Video
Best car amplifier
I've got a boss 1600 watt 4 channel amp ,720rms watts. up for auction on ebay right now that would work great. brand new in box. check it out. http://shop.ebay.com/?_from=R40&_trksid=p3984.m38.l1313&_nkw=boss+1600w+amp+4+channel+with+level+remote&_sacat=See-All-Categories
Oct 05, 2009 | Cars & Trucks
Amps on woofers are fine just won't hit
your probably making your amp run to low ohms if its a 2 channel amp bridged to one channel you can probably only run it at four ohms
Also seeing as your subs are 2ohm dvc you can't wire them individually to 2ohm and use each channel separately. So i'd recommend buying a 2ohm stable monoblock or running it at four ohms. a 1400 watt amp'll still pound at 4ohms and it'll extend your amp's life span
Aug 29, 2009 | Pioneer GM-7200M Car Audio Amplifier
Circuit diagram of 1400 watt woofer amplifier
www.the12volt.com/ subwoofer wiring diagrams and then find out what ohm of sub u have and how many voice coils and what ohm your amp is stable at.
Jun 10, 2009 | Beyma WOOFER, 1400 WTS, 18" => Model...
What would be the best amp for my 2 12''kenwood w3514 dvc 1600
Your sound system requires a 3000w amp. The best value for money amp I can find to help you is on ebay.Follow this link - current price is £149 http://cgi.ebay.co.uk/NEW-3000-W-WATT-1-CHANNEL-CAR-AUDIO-POWER-AMPLIFIER-2-4_W0QQitemZ260408043705QQcmdZViewItemQQimsxZ20090511?IMSfp=TL090511131001r33597
Jun 03, 2009 | Kenwood KFC-W3514DVC Car Subwoofer
What would be the best amp to run two kicker cvr 12 12" subs. would i need a second battery?
Do not buy a second battery without first upgrading your alternator and wiring for the added draw. Adding another battery will make the already stressed alternator work even harder. Find an amp that has sufficient wattage to drive both subs at rms. If your subs are each rated at 600w rms then look for a 1200-1400 watt amp. Good brands are a dime a dozen these days and you don't necessarily need a kicker amp. If you wish to upgrade alternators i would suggest searching for OhioGen or Ohio Generator. .They make alternators for high current demanding systems and multiple alternator system solutions. As for amps look at names that have been around for a while like Mbquart,Soundstream (older stuff like rubicons...) ORION (older HCCA models are great) and such.
May 02, 2009 | Car Audio & Video
Car Audio & Video Logo
99 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
