Question about HP LaserJet 4L Printer
Unable to use manual feed. The paper advances about one inch, stops and the red Paper Light illuminates. How can I correct the problem? Thanks Jerry
  • jerryfrang Oct 05, 2010
    I appreciated your reply and understand the problem. Unfortunately, the service manual replacement description appears rather difficult or I may be looking at the wrong page. Can you identify the page? What should the typical cost to replace the rollers parts plus labor?
    Jerry
  • HP Master
  • 19,396 Answers
Hi Jerry.
Ensure that there is no foreign object inside the printer, like a small screw. If an object gets in the paper feeder path you can get the same problem.
Ensure that the paper drawer is fine, and that the guides inside drawer are well placed and not obstacling the paper path.
If that does not fix the problem, then the rollers that push the paper inside the printer have lost their grip. This normally happens after years of usage, as the rollers surface gets hard and slippery, loosing its grip.
Solution is replacing the rollers. Parts can be ordered from HP. Below the service documentation:
Service manual.
Part manual:PRG Parts List.
Posted on Oct 05, 2010
  • Ginko
    Ginko Oct 05, 2010
    Hi.
    Effectively the replacement of the rollers is not considered a user level operation. Replacement involves disassembly of the printer to a certain level.
    If paper stops before getting completely inside the printer, then part to be checked is the pickup feed roller and the registration rollerI, if the paper is stopping after entering almost entirely inside the machine, check also te transfer roller.
    Refer to diag.at page 33 to identify parts. Assembly is explained from 6.42 to 6.49.
    Before going for the roller disconnect cables, remove drawer, remove toner, turn printer upside down and shake it gently (be careful, it is an heavy and delicate piece of electronic). If you hear a loose object, that is the problem.
    The replacement roller is $30/$40, more parts may be needed, small HP gears go for about $5/$10.
    Here the part.
    Sometimes is it possible to give new life to an hardened rubber roller by using very thin abrasive paper on the roller (feeding the printer with it several times). Even if the method sometimes work, there is a good chance to inflict more damage to the printer. I suggest not trying this method unless you really want to get rid of the printer (do at your risk).
Red "Paper" light stays on; printer will not print.
Paper light flashing could mean several things on this machine.
There could be a paper jam in the machine. Open the front cover remove the drum and toner and look in the machine. You can also check in between the drum and toner by removing the toner from the drum. Open the back cover and look for a Jam as well.
Try putting a piece of paper in the manual feed tray which is right above the paper tray, sometimes on certain documents the margins are too big and asks to go into the manual feed slot.
Apr 11, 2010 | Brother HL-2040 Laser Printer
Samsung 1710 stops before printing
to fix the problem you have to press the plate that the paper sits on down until it clicks into place once you do that it should work fine.
Oct 29, 2007 | Samsung ML 1710 Laser Printer
Everytime I turn my Zebra TLP 2844-Z printer on,
The red light means out of paper or ink ribbon. Some people chose not to use the ink ribbon and get thermal direct paper which requires no ink ribbon but the printer has to be told by the driver not to expect ribbon or the red light will come on. Also not having the correct paper height set in the driver will make the red light come on as well so check the advanced tab in the properties of the driver then click printing defaults. In the ZDesigner driver height and width are entered there. In the zebra universal, click paper output and enter the size.
Oct 01, 2009 | Zebra TLP 2844-Z Thermal Label Printer
I have an okidata 320t that is loading wierd. The alarm light is on when I put a paper in the top feed the alarm light goes out, but the paper doesn't load untill you push the SEL button and then when you...
1st try the easy stuff is the leaver set as paper feed or tractor feed if that is set correctly then you most likley have a gear problem and they need to be replaced.
open up the printer replace all the gears on the right side and the large gear on the left
they cost about 8 euros each and if it does not park correctly just clean out the bits of paper stuck under the paper load leaver the leaver is small black and bobs up and down if it does not bob up and down it means that there is a bit of paper stopping it. (to do this you have to remove the large black roller that feeds the paper)
thanks Hackeridis
Apr 16, 2009 | Okidata 320 Turbo Printer (Remanufactured)
Paper will not feed through - epson DX4000 printer/scanner
Did you check the thickness? My printer won't feed paper that's to think or thick properly it sould say in the manual what thickness of paper you should use.
Mar 24, 2009 | Epson Stylus Multifunction Inkjet Printer/...
Zerox WorkCentre XD125f E2 red paper jam light
This machine problem can be very involved.
A paper jam as described can be in any locations of the copier.
First of all when the toner-developer falls on the base of the paper feeder, it can contanimate all paper feed shafts and even sensors, and plug connections.
Worn feed rolls can cause the machine to jam. Clean the rollers and see if it corrects the problem.
A bent paper tray can cause the copy to skew, causing jams.
Sometimes the plasic paper path baffles are warped leaving narrow gaps in the paper feed path not allowing the paper to go through properly.
A bad paper feed sensor can cause inttermittant paper feed jams. This sensor is located just above the feed rolls. A involved process to take out without breaking the plastic components.
The machine has paper feed clutches located at the back of the feed rolls. To get to them it is also involved. Sometimes these clutches slip and will cause paper feed problems. There paper feed solinoids may operate intermittantly not allowing the paper feed clutch to operate correctly.
The main board can also cause these types of problems, not allowing the correct signal to operate the paper feed solinoids.
There is so much in this area to locate and isolate for paper feed problems.
If all else fails, call Xerox for a service repair.
Oct 26, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Not printing
The red light, along with the paper light being lit indicates that it is having a problem feeding the paper OR it is set wrong for duplexing. Check your manual on page 3-4 or download a manual at:
http://www.brother-usa.com/ModelDocuments/Consumer/Users%20Manual/UM_HL_5140_5150D_5150DLT_5170DN_5170DNLT_EN_1295.PDF
I can't tell which of the error conditions fits your situation, but this should put you on the correct path to figure it out.
May 22, 2008 | Brother HL 5150D Laser Printer
RED LIGHT BROTHER 2040
light explain link check first!.... paper jam light indicates a few things ie paper mismatch.
possible dirty feed roller, confirm by using bypass slot.
slightly damp rag on rubber feed roller to clean if the issue
Dec 22, 2007 | Brother HL-2040 Laser Printer
Paper doesn't advance through the printer
Hi, Sounds very much like the feed rollers are worn out. If you can get to them without too much trouble you can clean them up with regular rubbing alcohol and a rag which will help the paper feed. You might also want to try unpluging the printer and trying to roll the paper feed buttons by hand and seeing if a piece of paper will feed through without catching anywhere. If it does catch somewhere, then you may very well have a small piece of paper jammed in the paper path causing the jam. Good luck.
Aug 25, 2007 | Lexmark Z31 InkJet Printer
HP LaserJet 4L Printer Logo
Seeker5211
Seeker5211
