Question about HP Mini 1000 Netbook
My new hp mini won't connect to the internet. It shows full signals to our wireless connection at home but won't fully connect to the internet. We have another laptop in the house which never has that problem. What's up?
  • HP Master
  • 4,340 Answers
Check for password access to the router. When you do not have the correct one, this is what manifests.
Posted on Oct 05, 2010
  • karleyn Oct 05, 2010
    Thank you very much,
    Do you mean just the regular sign in password after the username for the wireless? Because I have that.
    If you mean something else, then sorry.
    I'm a little big computer not savvy.
    Thanks again
Poor signal with WiFi on my zeepad
Having a wireless Internet signal in your home allows multiple devices to use the same Internet connection without having to run lengths of Ethernet cable to each device. Given that the wireless network is transmitted over the air, the consistency of your Internet connection depends on the strength of the wireless signal. If wireless signal strength is not strong enough to give you a consistent Internet connection, there are a few simple steps for finding the problem and improving your signal strength.
Reset all devices. The majority of Internet issues, including poor wireless signal strength, are very often solved by a simple power cycle of all the devices in the network. Locate the power cords of both your modem and your wireless router and remove them (if you use a modem/router combination, simply unplug the power to that device). Leave them unplugged for a full 30 seconds, plug them back in and restart your computer. When your computer fully reboots, check your wireless signal strength to see if it has improved. If it has not, further troubleshooting is required. Move your computer closer to your router, or your router closer to your computer. Wireless routers do not have unlimited range. One reason your computer may be getting a weak signal strength from your wireless network could be because your computer is simply outside of the router's range. Typically, ISPs (Internet Service Providers) will install your modem in one specific location in the house and the modem will not work at other locations, so moving the modem or modem/router combination may not be a possibility. If this is the case, you may need to move the computer to a location that is within the range of the wireless router's broadcast. If you still get poor signal strength, your router may be experiencing a malfunction. Contact the technical support department of your router manufacturer. Router malfunctions often are not the result of a bad or broken router, but of something much simpler, such as the router's needing a firmware upgrade or an incorrect setting on the router's internal setup. If your router manufacturer is unable to improve your wireless signal strength, it may be time to purchase a new router. Purchase a new router. Wireless routers are priced in part based on how widely their wireless signal broadcasts (in other words, the more expensive the router you buy, the larger a wireless signal the router will broadcast). Included in the packaging of each wireless router is the approximated range, in square footage, of that router's wireless network. A good rule of thumb is to know the square footage of your house and buy a router that can accommodate that square footage. That way, as long as the router is functioning properly, you will have strong wireless signal strength throughout your entire home. Hope this helps.
b>
Dec 13, 2012 | Computers & Internet
My hp mini 1000 will not open internet explorer
Go to control panel then click on internet options after the internet options window opens click on the advance tab then look at the bottom you will see reset. Click on reset then try to launch the IE again.
Sep 25, 2012 | HP Mini 1000 Netbook
Dell Inspiron Mini won't connect to wireless- won't ask for wireless password and therefore cannot connect. Help!
Learn easy Steps To Set-Up A New Dell Inspiron mini. If you need assistance with issue, Call immediately -18002044427 Dell Laptop Technical Support number, Read More http://www.delltechnicalsupportphonenumbers.com/blog/steps-to-set-up-a-new-dell-inspiron-laptop-for-the-first-time
May 08, 2017 | Dell Inspiron Mini 10 Notebook
It won't connect to the internet.It show full bars when you look at the wireless connection.
the bars only show your connection to an access point, like a router. Probably you should reset that device (router) and then try reconnecting... Or try connecting the computer up to the router with a cable and see if it works.
Sep 14, 2011 | Dell Inspiron Mini 10 Notebook
Wireless internet connection
go into start, connect to, show all connections, click on lan connection, right click on it, repair connection
Oct 17, 2009 | HP G60t Notebook
HP laptop shows full internet signal, wont let me connect
First, the "Network Cable Is Unplugged" - don't worry about that. That is just informing you that your WIRED connection is unplugged, which is fine because you are using wireless.
Now the actual issue of no internet...first try by unplugging your internet modem for 20 seconds, and plugging it back in. Next do the same with your wireless router. At this point your computer will disconnect form the wireless network and you may need to reconnect it. After the reconnect see if you still have the same issue, but chances are it should be fixed :-)
If that does not work let me know and we can further troubleshoot the issue!
Apr 23, 2009 | Teac USB2 TV TUNER (USB2TVTUNER) Video...
My HP mini laptop will not connect to my wireless network.
check you wireless router settings if the wireless is enable on the router then , if this is done disable the firewall on your wireless laptop and if you cannot still connect to the wireless uninstalled and reinstalled your wireless driver software.
Adeyiga Shitu
Apr 17, 2009 | HP MINI 2133 NOTEBOOK PC - 1.6GHZ PC...
Cant connect laptop to internet
Hi!
I think that maybe you are using and incorrect password to connect to your wifi network.
Feb 18, 2009 | HP Compaq Evo n610c Notebook
Wireless connection
In order for me to deal with this query for you, could you tell me what brand and model it is the Laptop?
Fran10
Apr 10, 2008 | Dell Inspiron 6400 Notebook
HP Mini 1000 Netbook Logo
1,083 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
