My LG wm2688hnm 4.0 ultra capacity steam washer drum light stays on after cycle is finished and wont run another cycle. I unplugged and replugged and the light was on but I could run the cycle. But once finished same thing. Unplugged and held the start button for ten seconds but same thing happened. Can you help me figure what the next ste should be?
  • trhodes77 Oct 05, 2010
    Thanks! Is this something I can do myself? I concider myself fairly adept at these kind of things when presented with instructions and there is no need for specialised tools or the like.
  • 2,272 Answers
This is most always a bad relay on the control board or the faulty main control board as there would be an error code coming up if it were anything external to it. Best thing to do in this case is to replace the control board. if you want to buy new board, you can buy it from link below:--
buy control panel here
Thanks. Keep updated for any more query. You can rate this solution and show your appreciation
Posted on Oct 05, 2010
  • raj somaiya
    raj somaiya Oct 05, 2010
    yes when you buy the parts from the link i gave you above. they will also provide you with the instruction sheet to replace the part.you can follow those easy instruction and replace the board yourself.
What is the button combination to put the LG washer in test mode?
i believe it is the power button along with the two center buttons on the right.
Mar 30, 2015 | LG WM2701HV Front Load Ultra Capacity...
How do I set spin only cycle
with alot of LG washers they dont a have a spin only cycle, i dont know why they dont but it confuses alot of people, if so you should see a button that allows you to change the spin speed what you do is when you turn it on DO NOT select a cycle just press that spin speed button then press start and it will do a spin only cycle :)
Oct 11, 2014 | LG Ultra Large Capacity White Front Load...
My LG front-loading washer WM2501H drum light comes on at the end of the cycle and won't shut off. Additionally the control buttons cease functioning. If I unplug the machine and plug it back in, the...
I am having this same issue. I have to unplug and replug back in every wash. Very annoying. Especially because I am short and can't reach the plug without a step stool.
Sep 12, 2011 | LG WM2501H Front Load Stacked Washer/...
I have a front loading LG TROMM Steam Washer, serial No. WM2688HNW, 4.0 Ultra Capacity, Direct Drive System. My problem is a rubbing/scratching noise coming from the drum as it rotates. I ran my fingers...
Sorry. I doubt anyone on this forum would be able to give you that information. It's just made up of ordinary guys and gals, probably at home, from all over the world, with experience of addressing problems and giving guidance for free on the web but not supplying engineers or spares ;-0)
You will either have to search in telephone directories OR stay on line and search for '(make) washer service' for instance or '(make) washer spares' and hope that you can find someone reasonably local.
Sorry again ;-0(
Good luck,
John C
Mar 23, 2011 | LG Washing Machines
LE error on LG wm1814CW
My wife and I had the same LE error on our LG washer intermittently in the past. We have already been down the road to replacing the Hall Sensor only to find the washer not spinning and displaying the LE error again. Here is what we have found to be the remedy: Being that the Hall Sensor is a "Position" Sensor, we made a conscientious effort after unloading the washer to place the drum in the same position as when it finished its spin cycle. It has now been about 3-4 months with NO "LE" ERROR on the washer!!! One other thing - if you currently have the error displaying, you will have to unplug the washer for at least 2 hours to erase the memory of the drum position. This way you start fresh with a good position. Just leave it unplugged overnight. Hope this helps out!
Mar 14, 2009 | LG WM1814CW Front Load Washer
Washer wont rinse
you have a pump problem, need to lean washer back ageist wall go under washer. front left take off both hoses stick finger in pump remove all items from pump &hoses should work now
Aug 04, 2008 | Maytag MAH2400A Front Load Washer
Washing Machines Logo
154 people viewed this question
Top Washing Machines Experts
