Question about Whirlpool Duet GHW9150P Front Load Washer
Washer is stopped mid cycle - Whirlpool Duet GHW9150P Front Load Washer
  • 4,340 Answers
Is there buzzing? Check that BOTH water inlets are turned on. A common issue is the hoses get reversed, and machine runs fine until Dad gets the hot water bill, and turns off the hot faucet, and the machine will wait forever for the water....
Posted on Oct 05, 2010
Everytime I start the washer it pauses halfway through the cycle why is that
If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design. Door Lock Motor and Switch Assembly
If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design. Water Inlet Valve
If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Main Control Board
If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Timer
If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer
Sep 28, 2016 | Washing Machines
Doesn't work. Why does it stop mid-cycle?
washing machine stopped mid cycle, won't drain : DIY - Reddit
https://www.reddit.com/.../washing_machine_stopped_mid_cycle_...
RedditSep 3, 2014 - helpwashing machine stopped mid cycle, won't drain (self.DIY). submitted 1 ... I get home. Any ideas on how I can just drain the water out of it?
Troubleshoot - washer stops mid cycle, won't drain or spin ...
? 1:58
https://www.youtube.com/watch?v=6Gc0ZgLD6a4
Jun 20, 2012 - Uploaded by searspartsdirect
Troubleshoot - washer stops mid cycle, won't drain or spin .... I agree, this was not helpful, and did not address the no spin issue. like thanks. ... how to fix a Kenmore / whirlpool washing machine that wont drain agitate or spin ...
Washing machine stops mid cycle - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Sep 9, 2013 - Possible causes when washing machine stops mid cycle by a ... If thewashing machine can't drain the water out then it will stick on the rinses, ...
Why does my washer stop half way through cycle - Ken
Dec 18, 2015 | Washing Machines
Washer stops mid cycle
Look under the machine cabinet for
a bag with the diagnostic manual
Oct 16, 2014 | Samsung WF218ANW 4.0 cu. ft. High...
The water starts to come through then just stops and then alarms go off
see this causes and fix it. God bless you
Timer If the washer stops mid cycle the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components
Water Inlet Valve If the washer stops mid cycle the water inlet valve cold water side may have failed. Most washers have a cold water rinse and so if they can't fill with cold water they just sit indefinitely waiting for the cold water to enter. If there is cold water to the water inlet valve and the cold water works in other parts of the cycle - or to make warm water - the valve is not the problem.
Door Lock Motor and Switch Assembly If the washer stops mid cycle the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
Lid Switch Assembly If the washer stops mid cycle the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design.
Oct 05, 2012 | LG WFT1071TP Top Load Washer
Washer stops during rinse cycle and beeps at me
Main Control Board If the washer stops mid-cycle the main control board might be defective. This is not common. Check other causes first such as the lid or door switch and other components.
Oct 02, 2012 | Fisher and Paykel WA37T26G Top Load Washer
Whirlpool 1000 w100 stops after filling with water
Sep 30, 2012 | Creda W100FW Front Load Washer
Agitator continuously on
see the diagram
Sep 30, 2012 | Frigidaire GLWS1233A Top Load Washer
Washer stops at rinse cycle and give the ul code F1
Sep 28, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Hoover six 1100 stops at certain points during the cycle until i turn the dial to skip to next part of cycle?
Sep 25, 2012 | Washing Machines
Whirlpool Duet GHW9150P Front Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
