Remote control codes not working
My remote control worked for the TV before but now I put new batteries and the control will not work. I have tried the oneforall website and looked up the codes but none work. My tv is a Samsung Dyna Flat 4 in 1.
  • Anonymous Mar 24, 2014
    The no on the back of the TV is N11652
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 105 Answers
First check the I-R of your RCU just resoldered it to the PCB coz this is a very common problem which is easy to solve,if not check also the battery terminal of your RCU.....I would pressume that you are using a new battery....
Posted on May 28, 2008
Mitsubishi tv remote will not turn tv on. put in new batteries already . only the red light on the tv button turns on.
You should reprogram your remote. Start with the tv on. You have got to find a code that will operate all of the functions you want it to. In others some code will only turn on the tv. Some codes will work with volume and the channels. Once you find a code that works you should be able to operate the tv with the remote. It sounds like to me when you put new batteries you erased the function of your mitsbishi remote. So once the tv turns off you have found your code.. but make sure before you save it you write down on something; and, it works all of the functions that you want it to. I hope that this helps a ton...
Jun 29, 2014 | Mitsubishi New Original 290P137C10 Remote...
NEW REMOTE
If it is a universal remote control, after battery replacement, you have to set it up with the set-up codes to your TV. If you wish to get more; check the site linked here. It has set-up code list & set-up procedure to many popular brand remote controls. See it in "Mosaic" view. It will make surf easier.
http://electrohelponline.blogspot.com/
Mar 23, 2014 | Sansui 19" Class LCD 720p 60hz Hdtv,...
Remote won't work
1) replace the batteries by new one alkalines
2) clean the contacts batteries very wells
3) retight the springs contacts with pliers, for better contacts.
4) try again, reset the code.
5) open the remote control and clean the keypads with contacts cleaner for diryt, dust, and oxide.
6) resolder all points from board rremote
7) if this not work, you must go to the repair shop TV for fix it.
8) the SYSCOM can be defective. remember they send I.R emission.
God bless you
Aug 30, 2012 | Clarion New Original ARX5470 Remote...
Will not turn tv on and work the volume
Your batteries are low or the metal connections where the batteries touch need to be cleaned.  Also, sometimes these remotes lose their input code.  So put in the input code for your TV again after putting in new batteries.  If you have dropped this thing a lot or it has been water damaged it won't work for you.
Oct 30, 2009 | RCA RCR450 Remote Control
Remote Contol will not work, though batteries are new and red light is blinking
if it is a universal remote just look up your t.v. in the instuction book that came with the remote,and follow the instructions in the book on how to put in the code for your t.v.
Jun 03, 2009 | Insignia I-LC23Q1 23 in. HD-Ready LCD...
RCA remote
Could it be possible that the remote needs reconfigured? If none of the buttons work, the it could possibly be that you need to re-enter the TV code back into the remote.
Sep 24, 2008 | RCA 244889 Remote Control
Universal remote-rcr3273
Pop the batteries out and use brand new batteries then try the code again. Sometimes its good to let the remote sit for a few hours with no batteries after locking up the codes.
Apr 30, 2008 | Televison & Video
REMOTE CONTROL UNIT DOES NOT WORK
you need to enter the 3 digit code in the manual
hold the set and tv buttons, then enter the code and it should work
Nov 03, 2007 | Samsung TXN2730F 27" TV
Remote control #15-2147
Toshiba 0749, 1749, 0790, 1285
If that doesn't work then:
If your device does not respond to the remote after
trying all codes listed for your brand, or if your brand
is not listed, try searching for your code. For example,
to search for a code for your TV:
1. Press TV once.
2. Press and hold P until the red LED blinks twice,
then release.
3. Enter 9 9 1. The LED blinks twice.
4. Aim the remote at the TV and press Power. The
remote sends IR codes from its library to the
selected device, starting with the most popular
code first.
5. If the TV responds, go to step 6. If the TV does
not respond, press CH+. The remote will try the
next code. Continue until the TV responds.
NOTE: Press CH- to try the previous code.
6. To lock in the code, press P once. The LED
blinks twice.
7. To search for other device codes, repeat steps 1
to 6, substituting the appropriate key for the
device.
IF that doesn't work, I know a great place to find sledge hammers.
Oct 04, 2007 | Radio Shack (15-2147) Remote Control
Vizio 50 inch plasma -- remote not working
You can also try to take out the batteries and push all of the buttons with the batteries out of the remote. Then put the batteries back in and push the power button on the remote. If this doesnt work press the two TV buttons at the same time and the remote should be fine.
Sep 14, 2007 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
