Question about Foxconn G31MX-K socket LGA775 motherboard
Foxconn G31MXP & G31MV motherboards won't post. No video signal. Power comes on, fans & leds work but no post. Have tried 2 different CPUs - Intel Celeron D 3.2 GHz 352 533 512k cache & Intel Pentium Dual-core 2.2Ghz E2200 800 1 MB cache Using Kingston memory 2 x 1GB DDR2 Dimms - KVR800D2N5/1G. PSU 400 watts. I have built dozens of PCs before but never had one that would not post! Lost as what to do or try next. Hoping you can help. Best Regards, Steve.
  • 3,083 Answers
A friend of mine used to build computers for his boss. I stopped by to see him one day, and he had problem getting one booted up- he'd swapped out everything, as it unfurled, except the power supply. I asked him if he had another one, and when he swapped it out the computer booted and ran perfect. Other than checking all your connections, I guess the video board could be suspect. Here's a blog about this exact problem:
http://forums.pcper.com/showthread.php?t=446077
In a similar problem, the board turned out to be faulty:
http://www.tomshardware.com/forum/256259-30-4pin-8pin-motherboard-fails-post-foxconn-946gz7ma-8ks2h
Good luck, and hope this helps you.
Posted on Oct 05, 2010
EVGA Geforce 8400GS is compatible with FOXCONN G31MV-K Motherboard?
Check your installed ram sticks. (one at a time) the card is compatible with your board But the problem may be with your operating system and not the hardware. on start, press F8 and select "Last known good config" if the system still fails you may have a duff card.
Jul 21, 2012 | Evga GeForce 8400 GS Passive 1024MB DDR3...
I have a foxconn mobo model g31mv and has a problem with the video, well it shows nothing at all. Ive changed the memory, power supply, jumped the bios and check all the wiring and nothing. So.. what...
Try this motherboard troubleshooting beeping code first.
No beeping means short circuit,loose parts.
One beep means everything is working good.
Two beeps means CMOS error.
One long beeps,two short beeps means video problem
Three long beeps means keyboard error.
Continuous long beeps means memory not detected.
Continuous Hi-Lo beeps means processor overheat,loose blower fan heat sink.
If no beeps need to change capacitor parts of motherboard for burn, short and open leakage.
Jul 16, 2011 | Foxconn G31MV-K Motherboard
I was updating my BIOS on my Foxconn G31MXP when I had a power surge and the pc shut down now it won't boot up and just makes a beeping noise what can I do to get back into it
the only thing you can try to do would be too take the cmos battery out of it however chances of that fixing the problem are slim thats why manufactures warn not update firmware unless needed because many things could go wrong leaving you with a useless motherboard
Sep 23, 2010 | Foxconn G31MXP-K Core 2 Quad/ Intel G31/...
Pc doesn't boot up
do you have the right memory to match the cpu
Mar 31, 2010 | Foxconn G31MXP-K Core 2 Quad/ Intel G31/...
Hello, I need g31mv-k free, tanks
Here's the link to your the G31MV-K on FoxconnSupport's site:
http://www.foxconnsupport.com/download.aspx?models=en-us0000376&category=C000000001&Series=en-us0000002&keywords=&sort=
In the "File Download" on the page select the little link 'drivers' and it will display only the driver downloads, instead of manuals and stuff.
They have different drivers for XP, Vista & Windows 7, so take note of what operating system you have so you end up with the correct drivers.
I noticed that their site gets 'busy' and they'll shove you off to an 'error' page... just go back and try again.
I hope that works for you.
Mar 23, 2010 | Foxconn G31MV-K Motherboard
I have the same problem. "No Input Signal"
may be the power button get stuck when you pressing to switch on.just change the power button cable with reset button and see. also chek the **** aslo just remove it and clean it and fix it again.
Sep 10, 2009 | HP L1706 17" LCD Monitor
Can a Foxconn G31MV-K work with a Intel Pentium Dual Core 2M/800
Yes. This motherboard can work with the Intel Pentium Dual Core 2M/800 E5200 (2.5G) processor.
Below is a link to a page that lists the specs for this motherboard:
http://www.foxconnchannel.com/product/motherboards/detail_spec.aspx?ID=en-us0000376
Jul 26, 2009 | Foxconn Computers & Internet
Foxconn 915 motherboard - no POST sound
Your motherboard does not support the Intel Core 2 Duo cpus. That is why it will not post.
Dec 27, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Cooler CPU Fan
Here is a list of the compatible CPUs. Is yours on the list? Did it come with the CPU installed? Steve Medley C:\Users\Stephen J. Medley\Documents\Downloads\200811030909521886G31MV-CPU-A85.mht
Nov 16, 2008 | Computers & Internet
Foxconn G31MX-K socket LGA775 motherboard Logo
735 people viewed this question
Top Foxconn Computers & Internet Experts
Rommel Balcita
David
David
Gareth Cockram
Gareth Cockram
Are you a Foxconn Computer and Internet Expert? Answer questions, earn points and help others
