Question about Canon MultiPASS MP730 All-In-One InkJet Printer
Waste ink warning
I tried the process that you numbered out and it didn't work for me. Could you please detail out every little step to the process. Also, do you know how to empty the waste ink tank???
Thanks
  • Anonymous Jun 05, 2008
    product canon multipass 700 : waste ink near full ... what does that mean? How do I fix this problem . and also, check printer: how do I check printer?
    My printer is not working and I need to print documents!!!
  • 4,041 Answers
Hi you can try this.
To reset waste tank full error in MP730.
1. Hit the "menu": Key
2. Hit "Copy" Key
3. Hit "#" Key
4. Scroll thru the menu headings until you come to "Test Mode" - 12th heading
5. Hit the "3" button- this will bring up Eprom Clear
6. Hit "0" button
7. Hit the "Stop" button
Can only try then your printer go on longer but some time the other you need to clean out the waste ink it inside the printer go to open up all.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Feb 11, 2010
End of service for epson wf 7610
If your Epson WorkForce WF-7610 printer shows error message "The Printer's Ink Pads at the end of Their service life" and Epson WorkForce WF-7610 printer has a red light blinking problem: You should be download and reset Epson WorkForce WF-7610 printer Waste Ink Pads Counter with Epson WorkForce WF-7610 Resetter.
Go to this link, you should be able to download the resetter and follow the procedures step by step.
Reset Epson WorkForce WF 7610 End of Service Life Error message Wic Reset...
Jul 22, 2017 | Epson Office Equipment & Supplies
Canon multipass pixma mp500 waste ink absorber full
printers are cheap buy a new one or look in a dumpster where university students live and have been throwing out junk cuz they are done with school.
Nov 23, 2013 | Canon MultiPASS MP730 All-In-One InkJet...
"ink absorber is almost full, contact service center" - what does this mean?
Inkjet printer has waste ink absorber inside, sponge alike. The function of waste ink absorber is to localize and keep waste ink safe inside the printer and does not harm the electrical parts.
Waste ink is produced from print head cleaning process and borderless printing. When capacity of the ink absorber raise to about 90% then warning message appears.
You need to bring your printer to the nearest service center to get waste ink absorber replaced.
Source:
Printer Clinic: Printer Tips,tricks,troubleshooting
E-manualshop: Online source of service manual
Aug 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
How do I empty Waste Ink Absorber?>
Please check the following steps:
Step 1: Open your printer.
Step 2: Wear gloves to protect your hands from Ink.
Step 3: Locate the Waste Ink Pads on the inside of your printer. They are on the right hand side and are quite small.
Step 4: You can remove the pads and the holder with a gentle pull.
Step 5: Using a tissue, soak up as much ink as possible and clean the area around the waste ink area.
Step 6: There is one more waste holder in the right back bottom of the printer. A kind of sponge. There are few screws and plastic parts to be removed and this sponge needs to be washed, dryed and placed again. Be careful and patient. This is no understatement. On the iP1500 this requires the dismantling of most of the printer. Take a photograph (even with your cell phone) so you can trace back your steps. On the iP1500 the drive motor on the side (Just behind the waste ink pads) has to be removed to get to the main sponge. You also need to take care as you lift the slide/carriage. Below this you find 5 little springs.
Step 7: Carefully replace the holder and the pads. Close printer.
Step 8: Whilst printer is disconnected from the mains power, press and hold the power button and reconnect to ac power.
Step 9: Release the power button.
Step 10: Press the power button again.
**If this works please rate else let me know in case of further help.**
Jul 05, 2010 | Canon PIXMA MP130 All-In-One InkJet...
Printer warns waste ink near full. Cannon
Hi
The waste ink are in the inside of your printer you need to get at it to clean out, but after this you got to reset it or it will still not work, I not know about your printer I have only looked it up for you. It may be screwed down inside so you need to open all up or get a shop to de it for you.
I not find your model printer on the internet but I found one and it same type of printer as yours MP210 but a different number it canon MP190 and it have a reset waste ink for it you can try it may work for you, try resetting it first before you try clean it, if this not work you will have to find the right reset for it.
Ok here it is.
You have to do so:
1) Enter service mode by pressing: MENU, COPY, SCAN, COPY, COPY
2) Select TEST MODE
3) Select (8) PRINTER TEST in TEST MODE
4) Select (3) (eeprom clear)
5) Select (0) (ink count)
6) Press the SET key
7) Press the STOP/RESET key, then press power key to power off
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on Helping.
Feb 03, 2010 | Office Equipment & Supplies
Won't print. I get a message that waste ink absorber is full. What do I do?
Hi
Thanks for using FixYa. Open the cover, move the cartridges to the centre, and then press the pad of absorbent paper towel onto the waste ink pads. You can locate the waste ink pads to the right of the cartridges. This will absorb a lot of ink in the pads and that will remove the warning after you reset the printer waste ink tank counter. To reset your Printer please tell me the model number of your Unit so that I can provide you with model specific information.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 05, 2009 | Canon Office Equipment & Supplies
Waste ink tank full
Here's the steps for reseting "Waste Ink Full" problem at iP1000
Step 1: Manual for Service mode (1st method)
1. Unplug POWER and USB cables.
2. Open door, PRESS and HOLD the POWER button.
3. Connect the POWER cable.
4. Close door, then release POWER button.
5. Power ON your printer a usual (It should not blinking anymore)
Step 1: Manual for Service mode (2nd method)
2. PRESS and HOLD the POWER button,
3. Release the the POWER button
4. Power ON your printer a usual (It should not blinking anymore)
Step 2 : Software for Permanant (1st method)
1. Reconnect the USB cable and turn ON your Printer
2. Open "General Tools for iP1000",
http://www.printersiam.com/data/download/iP1000%20Service%20Tool.zip
3. Select (USB PORT)
4. Choose (SET DESTINATION 1)
It should be reseted already, but somehow it start blinking again if you ever unpluging AC POWER cable. So try the 2nd method by using ServiceTool for IP1500
Step 2 : Software for Permanant (2nd method)
2. Open "General Tools for iP1500",
http://www.printersiam.com/data/download/iP1500%20Service%20Tool.zip
4. Choose CLEAR WASTE INK COUNTER - MAIN
5. Choose CLEAR WASTE INK COUNTER - PLATEN
It should be working, coz my printer now now work normally
I tell you what. Before you decide to reseting the waste ink counter, you should really clean up the ink absorber, or else you will find the ink watse absorber overflow...
Aug 25, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Continue printing greyed out
Hi there
You can try this it some times works.
Super Canon User's method of resetting IP1600
1.Press Resume button hold for 1 - 2 minutes (count to 1 to 15-16)
2.Open the cover right away
3.Release Both cartridges out and then put cartridges them back again
4.Close The Cover
5.Turn Off Then Turn On again.
You can download the Resetter tools program from my website.
Click Link = http://www.4all2sell.com/reset-tools/ip1600st-RESETTER-TOOLS.zip
1. Download software for Canon iP1200, iP1600, 2200 Printers.
2. Unzip downloaded file by etc
3. Run GeneralTool.exe
4. Select the connected USB port number from USB PORT
5. Click LOCK RELEASE, and select the applicable model name in SET DESTINATION
6. In CLEAR WASTE INK COUNTER, select MAIN or PLATEN. The selected waste ink counter will be reset. MAIN resets the main waste ink counter, PLATEN resets the platen waste ink counter.
If both the main and platen waste ink absorbers are replaced, reset both the main and platen waste ink counters.
Free WinZip http://www.winzip.com/downwz.htm
Please call back to vote
All the best: Pineworks
Jul 01, 2009 | Canon PIXMA iP1600 Printer
My canon mp 150 has a warning ink refill cartridge
After so many prints the printer gives you this warning because it is possible that the waste ink pads (that collect any spilt ink in the bottom of the printer) are full. You have two options. You can either reset the waste ink counter and the printer will run but might get some ink leakage if it has had a lot of use or replace the pad and reset the counter.
A waste ink kit for this printer is Canon part number QY5-0149-000. A quick search on the will get you the part for about £5. Too fit it you will need to take the printer apart but that is easy with a service manual from here: http://www.tradebit.com/filedetail.php/4589462-canon-pixma-mp150-printer-service-manual The manual will also tell you how to reset the waste counter.
Hope that helps.
Nov 07, 2008 | Canon PIXMA MP150 All-In-One InkJet...
My prixma IP 1000 has message "Waste Ink Tank full, contact Service Engg."
Please try below steps on your Printer and let me know the result. I hope this should work.
Steps are:
 Reset waste ink tank counter CANON PIXMA iP 1000
STEP 1:- Disconnect printer from AC power
STEP 2:- Press and HOLD the POWER button, and connect printer to AC power
STEP 3:- release the the POWER button
STEP 4:- Press the POWER button again
This should work. please let me know the result.
Bye.
Oct 18, 2007 | Canon PIXMA iP1600 Printer
Canon MultiPASS MP730 All-In-One InkJet Printer Logo
44 people viewed this question
old marine
old marine
