Need a replacement front cover - Heating & Cooling
  • 4,350 Answers
Go to a local appliance store and order one there. OR go to the manufacturers site and try there.
Posted on Oct 05, 2010
I lost my lower front bumper (the black plastic part) i have a new one but not sure how to put it on
There is a simple procedure to do that.And basic tools are required.
Click the link below for detailed procedure:----
How to Replace Front Bumper? http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-front-bumper-on-audi-a4.html
How to Replace a Front Bumper Cover? http://technoanswers.blogspot.com/2011/07/how-to-replace-front-bumper-cover.html
How to Attach the front bumper cover to the fender? http://technoanswers.blogspot.com/2012/01/how-to-attach-front-bumper-cover-to.html
How to replace Bumpers?
http://repairhelpcenter.blogspot.in/2011/11/how-to-replace-bumpers-on-acura-car.html
This details will help.
Thanks.
Oct 09, 2012 | Cars & Trucks
I want to replace the oil pumpin a 1996 buick lasbre. need diagram
Removal:
  1. Disconnect the negative battery cable.
  2. Remove the front cover from the engine.
  3. Remove the oil filter adapter, pressure regulator valve and spring.
  4. Remove the oil pump cover-to-front cover screws and the cover. Remove the inner and outer pump gears.
Installation:
  1. Using petroleum jelly, pack the pump and assemble the gears in the housing.
  2. Tighten the oil pump cover-to-front cover screws to 97 inch lbs. (11 Nm).
  3. Install the pressure regulator spring and valve. Install the oil filter adapter.
  4. Install the front cover to the engine.
  5. Connect the negative battery cable.
Mar 15, 2011 | Buick LeSabre Cars & Trucks
When i turn it on it says turn off and on again
I have just had exactly the same thing on my daughter's NV3. In this case the lens cover would not open but if you power on the camera with you finger on the display button you can view stored images. If the lens cover is jammed you need to open the casing and maybe take the lens cover assembly apart. You need a very small cross head screwdriver (No.00 should be OK). There are 5 screws in total, 4 screws on the outside of the case (3 plus1 under the headphone socket cap) and 1 inside the battery compartment. You need to remove all 5 to remove the camera front casing. There are some retaining springs top and bottom on the front cover, gently prize off to reveal the lens cover assembly. Check to see if the lens cover will operate by switching on and off - if it works then the camera front casing is preventing it from opening and is probably bent out of shape. A little careful bending back into shape should resolve the problem. If it still does not work with the casing removed, read on. This is the tricky part. There are two extremely small, black retaining screws to the left hand side which hold the assembly onto the lens cover motor. Remove these screws and the front of the lens cover assembly to reveal the lens cover and the back plate of the assembly. Lift off the lens cover and switch on the camera. If the motor is still working, you will see a short black peg move from side to side as you turn the camera on and off. Thoroughly clean the lens cover and assembly, remove any obstruction and replace the lens cover making sure you locate the hole in the lens cover over the motor peg (described above).
The motor is magnetic and will attract the screws away from their holes if you replace the assembly front straight away, so when you replace the front of the lens cover assembly, place the screws in the correct holes before lowering it into place and then screw onto the motor/assembly back. Test that the lens cover opens and closes and replace the Camera front cover taking care not to bend it too much - if this becomes distorted it can stop the lens cover from operating resulting in the same problem.
Apr 01, 2010 | Samsung NV3 Digital Camera
Have 44k on a 2008 chevy uplander. Front left
I have a 2008 as well.. with 39K and the front right needed replaced.
it was covered under the 100K warranty
Mar 19, 2010 | 2008 Chevrolet Uplander
My dryer is making a high pitched squeal?
it could be the rear drum bearing,the front drum glides/rollers or the drum belt is glazed,or the tensioner for the belt needs replacement,all of which require you to remove the front cover by removing the lower front panel screws near the floor, then lift up front cover like a car hood and there are spring clips that will let go, then remove top cover these screws are underneath top cover in front and you can replace those items
Nov 13, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Need to replace the front bumper cover on a 1995 ford escort
its just the bumper cover.. once you buy the bumper cover it will replace your broke one,, however you my need to buy a bumpercover support..i think its only about $30 more..good luck keith...
Mar 15, 2009 | 1995 Ford Escort
1991 front speaker replacement
ok, i don't have pictures but i'll see if i can help. usually the covers over the speakers either have two srews holding them down or they just need a flat screwdriver to pry them up. if they have srews, you'll need a very small screwdriver to fit in between the window and speaker cover. some screws are star screws which need special star tool to get out. but most are philips screws. if you can get the covers off, you'll see the speakers, now you'll just need to take the two screws holding them down, out.pull the speaker up and out, unhook the wires and replace them. if you have the kind of covers that just pry off, just be careful not to hit the glass, i put up a piece of cardboard to be safe..i hope this helps you.
Nov 28, 2008 | 1991 Toyota Corolla
Replacement Front Cover
u can buy a new one
they usally sell it at wallmart can u anser my wii queston as well
Aug 22, 2008 | Nintendo Wii Console
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
