I have a Proview 3200 lcd.... The set ,sometimes loses the picture and at the same time still has the sound. Any Ideas Jeff
  • jffryjrdn Oct 05, 2010
    Thanks for your response... i'll check the inverter Jeff
  • 736 Answers
The first thing that needs to be done: Determine whether or not this is a problem with the tv or a problem with the signal definitively.
How to do this: When the picture goes out see if any of the television's display information can be pulled up and seen while there is no image on the screen and while there is still sound.
Connect a DVD player or try to play a DVD on one that is already connected to this television if it (the DVD player) is connected to another input. If you are using another device i.e. a VCR or a gaming system you can see if you get an uninterrupted image on it as well.
If you have determined that it is not the signal then you can assume it is loose inverters or a similar problem. You can get a service manual if you need it so you can have an image of the board assembly and get parts from a parts distributor. You may need to replace the inverter board.
If the problem is a signal problem that would be great. The settings on the device that is connected to the television would have to be changed or the cable(s) connecting the television and the device would have to be changed.
Posted on Oct 05, 2010
How to fix a proview 3200 HD TV with no sound?
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. Surf the site with patience.
Aug 10, 2014 | Proview Televison & Video
Where is reset button on a 3200 pro view television
Consult the owner manual to see if it has a reset feature (will not cure dead set or sound but no picture) or call the maker for assistance.
Apr 30, 2012 | Proview PA-32JK1A 32 in. LCD Television
Comes on ,but no pic or sound.light blue screen. i think the blub is gone
You can tell if the bulb is out by powering up the TV and holding a flashlight to the tv. Put the flashlight close to the screen and see if you can see any picture. If you can see picture, then it's the backlight. If you can't see pictures it is probably a more serious issue and would likely need to be repaired by the manufacturer.
Feb 24, 2010 | Proview PA-32JK1A 32 in. LCD Television
Proview 32' without picture or sound
hi first of all u should check ur transistor connections.Check your Horizontal and vertical output transistors.You should also check the horizontal and vertical yoke connections as well as your low voltage regulators.... if any of these got damaged u should purchase a new one.. but try to purchase with the help of a tv service assistant...
thank u!!!
rate me
Jul 07, 2009 | Proview PA-32JK1A 32 in. LCD Television
No picture
bad capacitors in the power board area these can be replaced and soldering is required to replace them
Nov 30, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview 3200 RX-326 LCD TV loses BLUE
Digital brd has a heat related problem..If you did not get a extended warranty then it could be cheaper to just replace the TV...
Aug 28, 2008 | Proview PA-32JK1A 32 in. LCD Television
Proview 3200 HD TV
as you are using the ch3 , have you previously scanned and locked in all the channels for cable,
Apr 25, 2008 | Proview PL913S 19" Flat Panel LCD Monitor
Televison & Video Logo
78 people viewed this question
Top Televison & Video Experts
Electro Med Services...
