Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Where is the idle adjustment screw on my 42/18
On the left side of saw above primer button is a hole going to the carb, the screw is there below switches.
Posted on Oct 06, 2010
Idle adjustment at carburator end
most older cars had 2 adjustments , a air screw for enrichment and throttle screw for engine idle speed, later models did away with the enrichment screw, to adjust set idle screw to 600 rpm, adjust air mixture screw to fastest rpm , reset idle screw to preferred idle speed.
Oct 03, 2016 | Cars & Trucks
Set idling via screws
Most older cars had 2 adjustments , a air screw for enrichment and throttle screw for engine idle speed, later models did away with the enrichment screw, to adjust set idle screw to 600 rpm, adjust air mixture screw to fastest rpm , reset idle screw to preferred idle speed.
It idles fast if I turn the idle down it stalls running rich on top end at fast idle sometimes it will drop to a very low idle and shut off
adjust the idle mixture screws first and then adjust the idle speed screw to compensate
adjusting the idle mixture screws will alter the idle speed but when properly adjusted then adjust the idle speed screw,
Aug 24, 2015 | Motorcycles
Continuous high idle and idle screw no help
Does your artic cat have a carb cable if so it will have an adjustment or a clamp on the cable where it attaches to the linkage..check make sure it is set to low idle..and your idle screw is adjusted to low idke..meaning cable adjusted to lowest possible position when the throttle is released..then make your final adjustment using you idle screw..good luck
Oct 22, 2014 | ATVs
How to Adjust idle RPM for a 2003 honda accord. some people were talking about a screw on the throttle body. but I can't find that screw. How do you go with adjusting this and where to find it ?
First, you shouldn't adjust the idle. If the idle isn't correct, that means there is an issue somewhere - not that the idle needs to be adjusted.
There isn't an adjustment screw. To adjust the idle, you will need to move the TPS (Throttle Position Sensor) forwards or backward. To do this, you will need to remove the tamper proof bolt and replace it with one that can be loosened and tightened.
Mar 04, 2012 | 2003 Honda Accord
How do you adjust the high speed mixture screw? I have a Ryobi RLH1100a MK III 31cc line trimmer, and after changing the fuel lines, it will start but not idle more than about 3 - 5 seconds before it...
Hi montex124, I will try to help. In the past few years carb makers have been making changes. Some carbs have no adjustment at all, the ports are all fixed inside the carb. Other carbs have only the idle speed mixture screw that can be adjusted, like yours seems to have. Is this screw you mention at the top and completely outside of the carb to adjust the throttle? If it is it's probably the idle speed screw which can be adjusted to any idle speed you want and has nothing to do with the air fuel mixture but If it is right next to the idle mixture screw, it might be the high speed mixture screw but is capped so it can't be adjusted. The low and high speed mixture screws should be marked next to each screw H and L.
The 1 1/2 turns suggested is sometimes just right but other times has to be adjusted, so you can try adjusting it to get your idle but maybe adjust the idle speed screw first to get a higher RPM so it doesn't stall on you. Like I said earlier it just adjusts the throttle, and is like when you are using it, and giving it gas as they say. I hope this helps just a bit. Regards and good luck. Get back to me if you need more help or just let me know how you did. Denis.
Feb 28, 2011 | Ryobi Garden
Member Discussion on Husqvarna 240e Chainsaw Idle Adjustment I have a new 240e and cannot keep it running. It will start, after many pulls, and one of two things happens. After running for 30...
Its not an idle screw adjustment issue, it is a mixture screw adjustment issue, unfortunatly there is a special tool to adjust the mixture screws, pt no. 530035560 ( available from Hysqvarna dealers ) once you have this tool you can make an adjustment to the L screw on the carb, undo ( anti clock wise ) this screw ten minutes on a clock face ,this will richen the muxture, and should make it more stable on idle.
Oct 07, 2010 | Husky Husqvarna Chain Saw 240E w 16in bar
The owners manual for my Ryobi 210 describes carburetor adjustment but the photos do not show which screw is the idle mixture adjuster.
The Low speed adjustment screw is the one marked as "L" and would be adjusted during:
1. Idle - to insure running smoothly, and
2. Acceleration - to transition from Idle to High Speed.
The High speed adjustment screw is the one marked as "H" and would be adjusted during:
1. High speed or Wide Open Throttle. Turn about 1/8 either way to gain top RPM's and then back off slightly.
The final screw is an Idle Set screw. This screw sets the actual speed of the Idle and is the screw attached to the end of the throttle cable as it terminates at the carburetor. Turning it:
1. Clockwise - increases RPM's (speeds up motor)
2. Counter Clockwise - reduces RPM's (slows down the motor)
Sep 28, 2010 | Ryobi Garden
Wont idle
Not knowing if you know anything about idle speed settings, idle mixture, etc., first check to see if all carburetor components are fully in place and are in good shape. A vacuum leak will cause the symptom you are describing. After doing that, adjust the idle stop screw. If it just won't idle even after doing that, take out the idle mixture screw, blow out the screw hole with compressed air, and gently screw in this screw all the way in. (DO NOT FORCE it.) Then open it 2.5 turns. Adjust this screw for a good strong idle while adjusting the idle SPEED with the idle stop screw. Get assistance if you don't know how to do this stuff. Good luck.
Jan 04, 2010 | RTO 110cc Basic Manual ATV # ATD-125C
Hyosun Scooter Carb Adjustments
Very good thought process on the adjustments. The throttle screw sets the idle speed and the air screw sets the fuel mix at idle speed. The stock setting is 1.5 turns outward. IMPORTANT > do not tighten these two adjusters down. Only screw these in until they LIGHTLY seat. Now turn each adjuster one and one half turns outward.
From this point you adjust the idle speed then adjust the air screw for fastest idle speed at that throttle screw setting. If the idle speed becomes faster than desired after adjustment, just reset the throttle screw and then reset the air screw.
A “very helpful” rating for this answer? Thanks!
Jun 27, 2009 | 2002 Hyosung Comet 125
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
239 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
