Question about Philips Televison & Video
DVD MODEL MSD 708...PLACE A DISC IN, AND IT STAYS ON 'LOADING', NOTHING ELSE HAPPENS. AND I'VE TRIED OTHER DVDS
sandrew
  • 2961 Answers
SOURCE: Won't load or play disc or dvd
It's a well known fact PS2's had a cheap lazer fitted to them, that's why when it gets chiped to play copy games, not long after it starts playing up. The lazer may just need aligning, purchase a cd/dvd cleaning cd rom as these can check audio, lazer alignment and clean the lens.
Posted on Jan 07, 2007
  • 583 Answers
SOURCE: DVD Player stopped working... will not LOAD/PLAY dvds
its the problem of fuse in the main board of the unit.due to which shut off and in that shut off the lens got faulty which needs replacement.as the faulty lens cannot load or play disc.
Posted on Mar 03, 2009
Beignorant
  • 51 Answers
SOURCE: WHEN DVD IS PLACED IN MACHINE IT KEEPS TRYING TO LOAD BUT NO PLAY
yes that is very possible. cleaning the lens of the dvd player should happen atleast once a month. it can also be that the lens itself is scratched or the lase does not reach the disk tracks due to dust or bad handling
Posted on Mar 30, 2009
srinivasb81
  • 51 Answers
SOURCE: dvd reads 'load' but nothing happens
This issue will occur only when there is a tray with the motor lens problem so you need replace the entire tray with the motor lens set to resolve your issue.
Posted on Apr 12, 2009
SOURCE: lg rc797t dvd drawer will not close consistently
I have a Compaq Presario desktop running XP Media Center. The DVD tray would open on power up, and kept openinig when pushed shut.
I discovered that the tray would frequently remain closed when I held open the flap (the flap with the open button). A few days after discovering this, I got to add some more tracks to my MP3 player - I only mention this intermediate stage in case it is material in curing the problem, as the next thing that happened was a power failure whilst the PC was on. Since then, the CD/DVD drive has behaved perfectly. I did have a temporary problem with AVG INternet Security being unable to load the necessary DLLs to run correctly in MS Outlook 2003, even complaining of a corrupt installation, but this dissappeared after a proper restart and AVG update.
So,
Compaq users: try holding the flap open when you attempt to close the tray.
Generally: with PC running and all applications closed, switch the power off at the wall socket.
HTH
Roger
Shaftesbury (UK)
Posted on Jun 17, 2009
Sharp DVD 'cannot read disc'
Sounds like the laser is bad.
May 29, 2013 | Onkyo HT-SR800 System
Dvd pplayer will not play but vcr is fine
If both connect at same exact place on set the player itself may be bad--you get sound from the DVD unit?
Dec 12, 2012 | Televison & Video
"Loading" error. RCA DCR69702 DVD can't read discs anymore.
Replace unit - the laser assembly has lost the ability to focus on surface of disk.
May 04, 2017 | RCA Televison & Video
My coby dvd player will not load dvds. After trying to load, I get a message that says "Wrong Disc". I have tried to put in other dvds, but get the same response. These dvds work in our other dvd...
its probably the laser is misaligned. somtimes you can maually reset it by takeing the disc out and sliding the "eye" toward the center. this will possibly break it, but a misaligned laser is not going to work so you;ve got nothing to lose. put in a disc you know is good, no scratches, and turn it on again.
good luck!
Jan 31, 2011 | Coby TF-DVD1021
Playstation 2 won't play DVDs
if it's a fat PS2 and
model SCPH 30001, SCPH 35001
(not including the models with an 'R' after the model #.
these models need the following to play DVDs:
- PS2 DVD remote with IR unit
- PS2 DVD disc player (sold with DVD remote w/ IR unit)
- PS2 memory card
you copied the DVD disc to the memory card. you used the memory card to play DVDs.
later models didn't need the memory card to play DVDs.
hope this helps :D
Jul 16, 2009 | Sony PlayStation 2 (PS2) Console
Will not read dvd, says loading, will stop and say no disc
Yeah I ve heard many people saying this. It is mostly because either the disc is damaged or the dvd lens reader has been damaged ..that is the only way by how it says "no disc" so better check with some shop around..or with the authorized dealer itself..ok
May 25, 2009 | Audio Players & Recorders
Mar 29, 2009 | Toshiba SD-5000
Home burned DVDs won't load, commercialy produced DVDs load OK
Try using a programme called dvd flick http://www.dvdflick.net/ to author your dvds and use imgburn http://www.imgburn.com/ to burn them. I had similar kind of problem with dvds burned with nero and now use dvd flick and imgburn all the time and have had no problems. They are both free programmes so hopefully they will sort the problem out for you :)
Shaz
Sep 30, 2008 | Philips DVP5140 DVD Player
No Disc
Check on sony.com for a service center in your area.
Aug 01, 2008 | Sony DVDirect (VRDVC20) DVD±RW Dual...
Mizuda dvd player wont read dvds
A couple of things To try.
1:) The DVD Player May be Region encoded, can only play certain region Dvds. ** Try different Disks**
2:) The Disk May Be Dirty-Scratched ( Towards The Centre )
** Clean The Disk With A Soft Lint-Free Cloth**
3:) The Laser Head may have a speck of dust or debris on it.
** Try a Laser Cleaning CD**
Hope this works For You.
Mike @ Compurepair.
Mar 01, 2008 | Shenzhen Mizuda DVD-999 DVD Player
Televison & Video Logo
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
