Question about Motorola Mobility RAZR V3
Problem with volume
Sounds is low but setting is on high
  • 1 more comment
  • harrsea Aug 03, 2008
    recently the sound volume is low. The ring tone is fine but I am having to ask people to repeat themselves because I cannot hear clearly from the same locations that i previously could. I could not figure out how to adjust the sound volume.
  • franbr Aug 18, 2008
    I have the same problem - low volume on the sound during conversation but not on the rimg. It is better with the Bluetooth earphone but I don't want to wear this all the time.
    The phone is almost impossible to use outside or with any background noise.
  • Anonymous May 12, 2009
    Ring tone volume is on high but very hard to hear speech - impossible with any outside noise.
    Problem Solver:
  • 18 Answers
Make sure the speaker are is not cover..sometimes inside they leave a little pastic.
use headphones and speaker to see if the sound still low.
that way we know what might be the problem
Paulo
Posted on May 30, 2008
The volume on my acer aspire 6530 is to low although the control
if you have external speakers, try adjusting the volume there!
If you don't, then click on 281bf5a1-868f-4ef8-aedd-d25642705e45.png icon, click 'Mixer', adjust the levels.
Or click on Start, write in "Sound",4b2d9ebd-91e4-43cf-8490-3de18c6bc30c.png
Adjust the settings for device/s you use to hear sound.
Dec 18, 2013 | Acer Aspire 6530-5143 Notebook PC
Nokia 6303ci -low speaker level.Volume bar-on max.After clean -same.Someone told me that for this model is normal low speaker level,but I don`t think so.
If the original recording is on low volume then you will get louder sound on the player device while if the recording is at high volume the you get low levels on player. try recording at lower volume settings on the phone. Then when you play it it will sound louder on increased volume.
Oct 26, 2013 | Nokia 6303 Cell Phone
Is it possible to hook up 2-6x9 and 2-12in.subs to the 7540a and still pack a nice punch
yes it is however the hookup for it requires something a bit unorthodox
you have 4 outputs (bridgeable)
channel 1 and 2 must be bridged (to lower the ohms) then connected to the 2 6X9 in Parallel..
this must then be set to the high pass frequency (eliminates bass)
lower all the settings as low as possible then turn them up slightly to increase volume to a level where its the hardest and clean sounding..lower volume after
this eliminates the bass and keeps the 6x9 pushing your mid range and high range frequency
now you have 2 channels remaining,, set 3 and 4 to low pass and connect each 12" to an individual channel. (this keeps the bass and ohms high so you will get a clean bass to match with mids and high's. Dont set or bridge for a low bass as it will jam out the 6x9 and your music will sound terrible.
so there u have a simple hookup that will work and keep you sounding clean. remember not to raise the volume on the 6X9 too much as you will blow them..
Mar 29, 2011 | Infinity 7540A Car Audio Amplifier
Hello there,i have a samsung cell phone model SCH-R351.My phone is on silent mode.What can i do to get it off silent mode and turn the ringer on
In the Settings menu, select Sounds. The Sounds menu appears in the display.
Select the Master Volume sub-menu which allows you to set the default volume for incoming
calls, messages and alarms. You can set the volume to Silence All, Vibrate, Low, Low/Medium, Medium, Medium/High, or High. The Vib. on soft key allows you select vibrate in addition to the sound.
Hope this helps. If so, please rate this solution.
-best regards,
M
Mar 10, 2011 | Cell Phones
THE U &L SOLO PANEL PLAYS VERY LOW NO VOLUME YOU CAN HEAR IT VERY LOW WHEN VOLUME IS SET AT HIGH AND SWELL IS AT HIGH ALL WORKS JUST NO VOLUME
Who would have any idea of what make or model device you have? Sounds like some brand of organ. We are not mind readers on this forum.
Oct 14, 2010 | Music
Sound volume is very low on incoming calls. Have set volume to max in settings and still no difference!
Send your phone to service, my nokia is dead too, so far 6 friends that have NOKIA TOUCH mobiles 5230, 5530 and 5800 all of them lasted around 6-8 months before the sound from incoming calls is very low with all the settings on volume set on high.
Things that will NOT fix the problem: Reseting phone, isntall up to date software.
BEST SOLUTION GET YOUR PHONE TO SERVICE
Oct 04, 2010 | Nokia 5230 Cell Phone
My mobile Nokia 6300 call sound is very low
First Option:
You Go to Phone Settings and In the Sound Setting and Set the High Volume IF Volume Setting Ok But Sound very Low
So
Secend Option:
Your Phone Ringer Default So Please change Ringer
And High Sond Will Solved
Aug 24, 2010 | Nokia 6300 Cell Phone
How do i get the Audio to work?
  1. Check the volume control located on the front or side of your computer to be sure that it is not set at the lowest level. If the problem is not resolved, proceed to Step 2.
  2. Step 2 Right-click on the "Volume Control" icon located on the Start menu taskbar and then select "Open Volume Control."
  3. Step 3 Remove all checkmarks beside "Mute" in the Master Volume and all other visible categories. If the sound problem is not solved, proceed to Step 4.
  4. Step 4 Right-click on the "Volume Control" icon and select "Adjust Audio Properties."
  5. Step 5 Go to the Volume tab and adjust the "Device Volume" by moving the slider within the range from Low to High.
  6. Step 6 Click on "Speaker Volume" under Speaker Settings and move the slider within the range from Low to High to reset the left and right speaker volume. If the sound problem is not solved, proceed to Step 7.
  7. Step 7 Go to the Hardware tab and highlight the device with the sound issue and then click "Troubleshoot." Follow the prompts until the issue is resolved.
Mar 02, 2010 | Computers & Internet
Poor Sound
Audio amplifier IC faulty that why you get very low volume. Else check audio driving circuit to the audio power amplifier. Contact service centre. as there is no rectification process from user part
Nov 19, 2007 | Samsung TXN3245FP 32" TV
Motorola Mobility RAZR V3 Logo
288 people viewed this question
Top Motorola Mobility Cell Phones Experts
Virgil Wolter
Level 1 Expert
vince
Rami Obeid
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
