Question about Honeywell HZ370 Space Heaters HEATER,CERAMIC,ELECTRIC
The heater no longer moves from side to side. It's an oscillating heater. How can I fix this?
  • Honeywell Master
  • 43,501 Answers
Check out this tip that I wrote about space heater problems..
DeLonghi Space Heater does not Heat
heatman101
Posted on Jan 16, 2011
New Dyson AM09 hot/cool fan does not oscillate
S Adams, return for refund or replacement, sound like plastic gear inside could be damaged or loose. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://www.dyson.co.uk/support/am09/am09-white-nickel/my-machine-is-not-working/my-machine-is-not-oscillating
https://www.dyson.com/support/am0112/am01-desk-fan-12-silver-iron/diagnosis-root-menu/my-machine-is-not-oscillating-am01
Dyson AM 02 Fan not working oscillating feature is broken
http://www.dysoncanada.ca/en-CA/support.aspx
Jun 20, 2016 | Dyson AM09 Hot Cool Fan Heater
How do i fix my GE washer machine oscilator.
Check machine belt drive for proper operation. Belt may have stretched.
Sep 11, 2015 | Washing Machines
Air purifier won't oscillate anymore... How do we fix that?
My is no longer oscillating as well. Took it apart and feel like its the small motor. I am unable to find it online. will call honeywell tomorrow. And probably bring the motor somewhere to ask what optional motor will work in its place. And put it all back together. a new motor should be about $10
Jan 09, 2014 | Honeywell Hfd-120-q Quietclean Tower Air...
Fan will not oscillate anymore. it makes a clicking noise like it's stuck
follow this steps and fix it. God bless you
f the fan doesn't work at all, make sure power is on at the outlet, then test the power cord . Test the motor and replace it if it is faulty. Clean and test the speed-control switch and service it if it is faulty . If the fan works on only some speeds, clean and test the speed-control switch .
If an oscillating fan doesn't move from side to side, check the clutch knob, then the gear assembly. If the gear assembly is faulty, you can service it (see below).
If the fan blades turn slowly, check the blades for a loose hub and tighten if needed. If the fan shaft is noisy or dry, lubricate it.
Nov 14, 2013 | Tower Aloha Breeze Fan
My Lasko 5307 oscillating ceramic tower simply does not "turn on" .... what's up?
Electricity is not suitable for use by you....
Check power point with another appliance. Check heater switch, high temp, etc....
Oct 16, 2013 | Lasko 5307 Oscillating Ceramic Tower...
Heat does not come out of defroster
An oscillator? :vibration, motion like a pendulum, pulsation, fluctuation, rotation...yeah, I can imagine Nissan calling a door that swings back and forth to direct air, an oscillator. Hope someone is not pulling your leg, though, or we've both been suckered ! Don't know what to tell you, except to find your nearest oscillator outlet supplier. In the meantime, check the controls to the various doors on the heater case. Are they vacuum controlled, cable controls, or electrical motor controlled? Usually all of one type. You may be able to see the offending part, a disconnected hose or cable, or the stem of an inner door that has broken or not moving the door. The oscillator might be hidden deep in the bowels there-be careful. Good luck, norman.
Feb 25, 2013 | 2001 Nissan Quest
I have a Raypak 2100 hooked up to my hot tub. It has always heated one degree a minute but now it is taking longer and longer to heat tub up. Anything I can do or do i need service?
Check your by-pass valves. You have one on the inlet and outlet pipes this should be closed or nearly so. And their is one inside the water header on the side of the heater. This is a spring loaded disc on a shaft and should move smoothly just from the water pressure coming into the heater. Sanding and cleaning the shaft and disc should fix this. Both of these keep the water from flowing to fast or to slow through the heat exchanger so it warms at the best rate.
Nov 25, 2010 | Raypak Hood shown but not included. A...
Tahoe 2001 4 wheel drive. above 60 miles an hour when driving over a bridge abunkment?? The front end shakes violently, my husband said the car felt like it was going to break apart. No one seems to...
You might jack up the truck on the side, leaving one front wheel on the ground, the other suspended. Have someone watch the steering components close to the suspended wheel while another moves the steering back and forth at a medium rate and look for 'unnatural' movements of joints. Do both sides to check.
This sounds like a tie rod end that is shot and these are fairly easy to spot since the joint will move in directions that are obviously wrong.
The reason it doesn't want to stop is that when one wheel is no longer being held rigidly, it will 'oscillate' causing the violent shaking. The boost from power steering worsens the problem. It can be dangerous; a friend had a worn tie rod end come apart while barreling down the Freeway. Steering with one wheel doesn't work. He survived but no longer ignores the signs.
If you had brought the truck to a decent front-end alignment shop, they would have found this while trying (it doesn't work) to align it.
Sep 07, 2010 | 2001 Chevrolet Tahoe
Honeywell HZ370 Space Heaters HEATER,CERAMIC,ELECTRIC Logo
156 people viewed this question
Top Honeywell Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
David Spradling
David Spradling
Are you a Honeywell Pool and Spa Expert? Answer questions, earn points and help others
