Question about i-mate JAMin Smartphone
Software required i have an imate jasjam but i not able to find the softwre required to connect it with the PC i beleive softwares name is i-mate JASJAM 3G Microsoft ® Windows Mobile ® 5.0
  • Anonymous Jun 17, 2008
    yes
    need software to run on windows vista
    Problem Solver:
  • 5 Answers
For XP its Active sync 4.5
For VISTA it shold be preinstalled on as Windows Mobile Device Manager, you can download both software from microsoft.com
Posted on Sep 16, 2008
I am using I-Mate Jasjam Mobile .I cant able to connect to WI-fi.and need to install the Google talk in it.
Posted on Oct 21, 2008
Jas jam for windows 7
how can i operate i mate jasjam
Jan 18, 2010 | i-mate JasJam Smartphone
Tip
Hi, i got new Imate-jaq. I am facing problem in synchronising the imatejaq with...
Your battery has been depleted past a chargable state.  This is a due to a bad design in the phone that doesn't monitor the battery power state well enough.  It actually allows the battery to be taken under the minimum amount needed to recharge the battery.
You can fix this, but do so at your own risk.
You can simply purchase a new battery, that will work, just been sure not to let it deplete the battery totally anymore.
Now, on to the fix
-Take out the battery.
-Get any usb cable you can find sitting around. (any usb wire will do, an old printer cable, anything with a usb end that can plug into your computer)
-cut one end of the plug off. You need to leave the side on that connects to your computer. Cut off the side that plugs into a device (printer, camera, web cam, etc)
-Strip the rubber off the wire and expose the wires inside.
-Separate the wires from each other. You will only be using the BLACK and RED wires.
-strip the very end of the black and red wires carefully using a wire cutter exposing the metal wire inside the red and black covering.
-Plug in your home made battery charger to your computer. Careful not to touch any exposed metal, as it will give you a small shock.
****WARNING****
DO NOT UNDER ANY CIRCUMSTANCES ALLOW THE RED AND BLACK WIRE TO TOUCH EACH OTHER
****WARNING****
-now carefully hold the black wire to the negative terminal on the battery (it should be noted with a black circle with a - in the middle). Then touch the red wire to the positive terminal (it will be noted with a red circle with a + in the middle).
Hold the 2 wires there for 20 seconds. Then quickly plug the battery back into the phone, and then plug it into a regular charger. Give it little bit of time, if you've done everything correctly the charge light should come on.
I had to repeat the last step again to get the light to turn on indicating it was charging.
You must not hold the wires to the battery for too long, 20 seconds should do it. You can overload a battery with this trick and actually make it explode if you hold it there too long. You are well within the few minutes needed to detonate the battery due to overcharging by sticking very strictly to 20 seconds.
Just be careful and you'll be fine.
One you get a charge light give it a few minutes in the off position, then try powering up the device and keep it plugged in until you get 100% charge.
Good luck,
Peter
on Dec 28, 2007 | T-Mobile MDA
IMATE jasjam software upgrade
My I mate jasjam is 6 yo and I cannot get it to sync with laptop
Jan 06, 2010 | i-mate JasJam Smartphone
Connect my imate jasjam to my new Toshiba
This was successfully acheived by opening Windows Mobile Device Center first from the Start Menu, then connecting the smart phone while the WMDC was still open. All the previous attempts I was expecting WMDC to open automatically when I connected the JasJam.
Sep 29, 2009 | i-mate Computers & Internet
Hai, can i upgrade windows 6.1 my imate jasjam mible it will work
yes it works it takes a lot of memory of the mobile but still it works ok.
Mar 09, 2009 | i-mate JasJam Smartphone
I-mate jasjam multi language(arabic)?
hi there!
thanks for using fixya.com!
If you have bought your PDA anywhere in the middle east, the software is already installed you just have to select your preference.
pls check this website for further information about your I-mate.
https://www.imate.com/Support_DeviceSupport.aspx
thanks and regards!
pls do not forget to rate me with my solution.
Feb 18, 2009 | i-mate JAM Pocket PC
Syncing
Hello Ansir
It depends on what operating system you are working on - MicroSoft Vista or 2000? or XP?
If it is any other than Vista then Please visit www.downloads.com and search for Microsoft activesync. You may download the latest activesync there and install it.
after installing the software you will then need to connect your i-mate with the PC, most preferably with a USB cable. Follow the instructions that come then and there you are!
Dec 10, 2008 | i-mate JAMin Smartphone
Outer Body of i-mate Jasjam
hi vengu, me too have the same issue. i hav learned that imate have very few service centres in India. the following name i have seen in clubimate website. hope u may find it useful Kaizer Telecom Sitaram Bldg., 1st Floor, 20/B
Above Peekay Wines
Mumbai 400001
India Phone: +91 (98) 21160515
Email: kaiser_electronics@yahoo.com
May 13, 2008 | Griffin Technology iMate - Universal ADB...
Computers & Internet Logo
188 people viewed this question
Top i-mate Computers & Internet Experts
Computer Repairing
Computer Repairing
Martin Murray
Are you an i-mate Computer and Internet Expert? Answer questions, earn points and help others
