Question about Samsung Washing Machines
Samsung VRT front load washer, loud and shaking. How can I reduce the noise and shaking? It is completely level.
  • 3 Answers
SOURCE: Samsung VRT washing machine
nF means that washer tried to fill but was unsuccessful. Water supply valves needs to be fully open. Lines may be kinked or screen by the hose hookup at the washer end may be restricting flow. Check to ensure the screens are cleaned by removing hose and pull screens and clean them then try the washer again
Posted on Jan 18, 2008
  • 184 Answers
SOURCE: Front Loading Washer LOUD NOISE
IF IT ROARS LIKE A JET PLANE TAKING OFF, THE SPIN BEARING IS FAILING. PROBABLY, THE REAR SEAL HAS FAILED ALLOWING WATER TO GET INTO THE BEARING.
THE BEARING HAS LOST ITS LUBRICATION SO IT IS GETTING DRY. IT WILL CONTINUE TO GET LOUDER AND LOUDER THE LONGER REPAIRS ARE PUT OFF.
THE ENTIRE BACK HALF OF THE OUTER TUB WILL HAVE TO BE REPLACED. THE BEARING IS PART OF THAT ASSEMBLY. CAN BE A COSTLY REPAIR.
Posted on Apr 05, 2008
SOURCE: kenmore Front load washer model
I have a kenmore front load washer, model: 417 42042100
It makes loud noise and becomes louder during the spin cycle.
The drum is loose when I inspected through the front door.
My problem is how to open the cabinet and replace any broken parts.
Thanks.
Posted on Aug 30, 2008
the_admiral6
  • 14 Answers
SOURCE: Washer drum shakes excessively during fast spin
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Posted on Mar 07, 2009
huuum
  • 750 Answers
SOURCE: Front load washer shakes violently during spin cycle
On something like this you will need to remove the washer wrap to inspect the suspension springs & base assembly. Please see the link provided for accessing the inside of the washer. Be sure the shipping pins have been removed. The tub should float freely.
Posted on Apr 03, 2009
Samsung vrt front loading washer loud noises and not spinning
The washer tub has dampers to absorb this spin cycle vibration, your machine must have some broken dampers for the tub.
Oct 26, 2016 | Samsung Washing Machines
Why is my samsung vrt steam washer leaking from the bottem right model #WF331ANW/XAA
Locating And Repairing A Mystery Leak In A Front-Loading ...
? 3:55
www.youtube.com/watch?v=3D5q1ynWb-U
Jul 28, 2012 - Uploaded by SamuraiRepairman ... source of a leak in a front-loading washing machine and then mercilessly repairs it. ... LG Washer Repair & Diagnostic -Leaking Water from front & bottom ... Samsung Front-LoadWasher Disassembly - Washing Machine ...
Samsung vrt steam washer leaking - Fixya
www.fixya.com/support/t13638559-samsung_vrt_steam_washer_leaking
Jul 15, 2012 - Samsung vrt steam washer leaking - Samsung WF338AAB 4.0 cu. ft. ... I have a vrt ... I hope this helps.... Take of that little door on the front. Have a ...
Oct 29, 2015 | Samsung Washing Machines
Wash shakes on the spend cycle
I would check to make sure the washer is level, the drum sounds like it's not spinning evenly and if the load isn't unbalanced it might just not be level front to back and side to side.
Mar 01, 2015 | Samsung 3.5 cu. ft. High Efficiency VRT...
Samsung washing machine wobbles on spin.
The feet of the machine have to to be leveled. When reading the instructions, leveling is important for the very reason you are having difficulties.
Sep 19, 2014 | Samsung 3.5 cu. ft. High Efficiency VRT...
My Samsung vrt washer when on spin cycle is becoming a walking washer completely loud and I tried to adjust the feet and get it leveled but it didn't help out what could be the problem
It sounds like you're putting too much clothing in the washer. It can only wash a certain amount at one time. Try washing less in one load.
Aug 01, 2014 | Washing Machines
Samsung washer -front load -noise wobble
Sounds a lot like a bad rear bearing. I replace them all the time
Feb 19, 2014 | Samsung WF330ANW 4.3 Cu. Ft. Front Load...
Frigidare front load washer has loud banging on spin cycle. After much work we reallized one shock was broken of which we repaced both now it still making the loud banging shaking motion. Also the washer...
Thanks for choosing FixYa and welcome. Since the suspension is ok and it is level, check your drive motor and spin bearing. Usually, these are the trouble parts when loud noises are associated with the spinning cycle. Your drive motor controls the spinning. Since the noise is during spinning, that is probably where your problem lies.
Apr 29, 2011 | Frigidaire GLTF1670A Front Load Washer
Washing Machines Logo
612 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
