Question about Whirlpool Duet GHW9150P Front Load Washer
Have whirpool Duet dryer....leaves brown streaks just like everyone else's. What do I do to fix the problem? Can I do it or am I going to have to pay someone? Company should have a FREE kit to repair....it is an obvious flaw in design and/or manufacturing. So what do I do....tired of closes getting messed up.
  • Whirlpool Master
  • 3,051 Answers
Hello there:
If your clothes get marked or torn in your dryer, check these: Rollers Your dryer may use rollers, or wheels, to support the rear of the clothes drum. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the rear of the dryer interior. When the rollers wear out, you need to replace the whole set. Rear seal Your dryer may have a felt-like seal at the rear of the drum. If this seal is worn, torn, or missing, clothes can get caught and torn in the space between the clothes drum and the rear of the dryer interior. When the rear seal wears out, you need to replace it. Front glides Your dryer probably uses nylon or plastic glides at the front of the clothes drum for support. When these are worn out, they may cause the clothes drum to drop down slightly, which can pinch the clothes between the top of the clothes drum and the front of the dryer interior. When the glides wear out, you need to replace them as a set. Front seal Many dryers have a felt-like seal at the front of the drum. If this seal is worn, torn, or missing, the clothes in the dryer may get caught and torn in the space between the clothes drum and the front of the dryer interior. When the seal wears out, you need to replace it.
Posted on Oct 05, 2010
I have a whirlpool duet washer and it is leaving brown streaks on my whites. What do you think is causing this problem?
The brown stains are likely coming from the felt drum seal. The OEM adhesive is tar based - and after time and use - breaks down.
You'll need a new felt seal - and the adhesive that is used should be silicone based... eliminating the brown streaks.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Aug 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Brown streaks on my clothes after washing them
O.K. Here it is, I solved it. After calling whirlpool who was of no help at all, reading all links about the Duet washer and/or the Duet dryer, I finally solved the problem myself. I too, thought it was the washer but, upon close inspection, found the felt on the dryer had worn out in one spot. The thin brown lines always showed up on whites and more so on anything very thin. I took the dryer apart and found a small burn line on the drum (brown and thin). I replaced the felt ($60) and used Simple Green to clean off the brown. Works perfect, no more thin brown lines. If you can't take the dryer apart, I called for repair and found the price with parts to average $250.
I was ready to sell the darn thing after it ruined about $300 worth of clothes. All in all, it's been three weeks and still working fine.
May 19, 2010 | Washing Machines
Whirlpool duet dryer mod gew922507pw1 lleaving brown streak on cothes
Jan 27, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a 2006 Whirlpool Duet Electric Dryer that leaves brown marks on my cloths. I have cleaned the inside of the dryer per the manual's diretions, but it still leaves the marks. They almost look like...
Usually, if you are getting brown streaks or marks on clothing, one or both of the drum seals are going bad. Clothing will drag between the bulkhead and the drum, leaving brown marks. If you want to do the repair yourself, I can provide instructions, otherwise call for service.
Dec 30, 2009 | Whirlpool GEW9250 Electric Dryer
Whirlpool Duet Washer/Dryer get brown streaks on clothing
Jul 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Dryer - Series 80 - Model 96586200
the brown streaks are from the seals most likely from the front seal ... if your handy it will be an easy fix..
Oct 12, 2008 | Dryers
Dryer is leaving brown streaks on cotton clothes
To all victims of the brownish colored streak marks: I share your frustration!!! I have the same problem with my dryer which started when my dryer was only 3 or 4 years old - - totally unacceptable for an expensive top of the line dryer! A repair guy showed me how the brownish streak marks come from the felt liner which goes around the drum. Look inside your dryer for the beige or tan colored felt which sticks out around the circular drum. If you rub the felt with an old white t-shirt or paper towel, you will see the same brownish colored marks. My repairman recommended getting the felt replaced eventually, but until then, he gave me the following tips which really help avoid getting the streaks: For white or light colored clothes susceptible to the brownish streak marks: I dry these items as part of a very lightweight dryer load - with just a few other lightweight items. By doing a small lightweight load, clothing is less likely to get caught up & rub against the felt edges. For example, I dry 4 light colored men's dress shirts with 2 or 3 other lightweight shirts. OR for white or light colored athletic "dry fit" type athletic apparel, I dry 6 - 8 total lightweight shirts/shorts. If I throw my white Nike top or white pair of summer pants into the dryer with all my "whites", they will be doomed to getting brownish streaks due to the heavy load pushing them against the darned felt liner! Whenever possible, I wash susceptible items on permanent press to avoid wrinkling, then hang dry. Prior to putting these clothes in the dryer, I also "pre-clean" the felt with an old white cotton t-shirt by reaching into the dryer and rubbing along the felt edges until I'm not getting as much brownish color on the t-shirt rag. For a permanent fix, call a repairman or see the following do-it-yourself YouTube video on "Dryer Repair - Replacing the Lower Front Drum Felt Seal": http://www.youtube.com/watch?v=XoYP_YsGP68 . I have a repair person coming today to fix 2 other appliances, so I'm finally getting my dryer fixed, and I will post an update soon.
Dec 30, 2007 | Dryers
Brown streaks on clothes
Check an earlier post of mine. This problem was killing me and Whirlpool was of no help at all. They claimed to never have heard of these thin brown streaks. Well, it was the dryer and as proof, I found where the thin brown lines were coming from. The felt had worn out in one spot allowing thin, whites and other thin items to slide in between the drum and the backing, resulting in the transfer of a thin brown line randomly on my clothes. Replace the felt (rollers and bearings if necessary) and with the drum apart, clean off the burnt brown streak of the backing with Simple Green. No more problems.
Aug 12, 2007 | Whirlpool Duet GHW9150P Front Load Washer
mich, The brown streaks are probably caused by worn drum guides and lower basket seal. I've seen this quite often on Frigidaire dryers. Part numbers 5303937139 upper felt guide and 5303283286 lower basket seal. This can be a task for an inexperienced person but can be done. It requires removing the top panel and front panel/door assy. The old guides have to be scraped off. The upper felt guides and lower seal glue on. Catriver...post back.
Nov 19, 2006 | Frigidaire GLEQ642A Electric Dryer
Whirlpool Duet GHW9150P Front Load Washer Logo
533 people viewed this question
Dan Webster
Dan Webster
Sal De
